Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite HT5E Steam Series Washer with an F20 erroe code.. can't find the users manual... can you advise what this indicates and a fix??
  • 640 Answers
No water in unit,,,check inlet hose,,or clean inlet screens...onthejob
Posted on Jan 20, 2009
Have a top loading Kenmore elite high efficiency washer model 796.2927, 2 years old this thanksgiving is showing erroe code LE? what do i do to fix?
On most Kenmore front load washers the LE error indicates a LOCKED MOTOR ERROR. This can be caused by:
  1. Loose motor harness connection.
  2. Failed HALL SENSOR.
  3. Failed STATOR.
  4. Failed ROTOR (cracked magnet).
Nov 06, 2012 | Washing Machines
I have a kenmore elite HE5t steam front load washer that keeps putting up f20 error the water lines are not plugged water is flowing into it i moved it out to check the water lines and it ran 3 loads then...
http://www.fixya.com/support/r3608632-f20_error_code
This code is tricky to troubleshoot, so jsrock516 advices to eliminate the easy common sense items first.
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer flashes F20. What can I do?
This code is tricky to troubleshoot, so jsrock516 advises to eliminate the easy common sense items first.
May 02, 2010 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite frontloader and when im washing it stops in the middle of the cycle and displeys F20 what does that mean
Nov 17, 2009 | Kenmore Elite 45986 Front Load Washer
Code F20 is appearing on me washing machine
May 27, 2009 | Kenmore HE2 Plus Front Load Washer
Hi
Error F 20 means "No Water Detect" error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed.
You'll need to check for the following--
1- Check the Inlet water valve if it is clogged.
2- Make sure water taps are working fine.
3- Check inlet hoses for kinks or clogs.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 26, 2009 | Kenmore HE2 Plus Front Load Washer
Have kenmore elite HE5t giving code F20 help pls
The following link explains the "F20" error code:
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
I recommend checking your washer installation for a possible siphoning condition and kinked fill hoses, first, as these are the easiest items to rule out.
If you have questions, please let me know. I hope this helps you.
Jan 05, 2009 | Kenmore Elite 45986 Front Load Washer
Error code F20
take the kick panel off inside you will find the tech sheet it will give you a list of error codes. i believe you have a bad pressure switch or it could be something stuck in your pump. untwist and check the pump filter. let me know how it goes
Dec 24, 2008 | Kenmore Elite 45986 Front Load Washer
F20 code.
in my fixing f 20 needs a new cpu main board in the top washer middle back side
Nov 16, 2007 | Kenmore Elite 45986 Front Load Washer
2006 kenmore smartwash quietpak4 he3t F20 code washer
F20 ERROR CODE ON A KENMORE HE2T FRONT LOAD WASHER.THE FIX FOR ME WAS TO REPLACE THE TUBE THAT RUNS FROM THE PRESSURE SWITCH TO THE BOTTOM OF THE WASHER.YOU MUST REMOVE THE TOP AND BACK COVERS OF THE MACHINE(EASY).REPLACED TUBE WITH3/16 INCH CLEAR TUBE.THE ORINGINAL TUBE HAD A PIN HOLE FROM RUBBING AGINST THE SIDE OF THE MACHINE AFTER 5 YEARS OF USE.THIS COST UNDER $10 DOLLARS TO FIX. NO SERVICE GUY=MORE BEER MONEY GOOD LUCK.
Nov 07, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
188 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
