Question about Kenmore 63012 Electric Dryer
Replace dryer vent hose
It is a Kenmore model 110.96584100 serial M00601906. Yes it is almost 15 years old. We have taken the screws off the back, tried the bottom but don't seem to be able to get to the hose. How do we get to the hose?
  • Kenmore Master
  • 3,361 Answers
The vent hose connection protrudes from the rear bottom center of the dryer.
Nothing needs to be removed to connect a new vent.
Posted on Feb 21, 2009
Kenmore dryer runs and heats for 15 minutes then shuts off
Hi, go around back of the dryere. The vent hose coming off dryer to wall outlet must not have any bad bends or kinks. It must run as straight as possible. Then go outside and check the vent for cleaning. If the dryer has run a long time like this you more than likely will need a control thermostat. If you'll send me the make and model number, I can get you the part number if you like. Hope this helps.
Jan 28, 2011 | Kenmore Dryers
Kenmore 80 series. No lint in the lint trap, going directly into flexible hose leading to dryer vent.
lint trap is blocked.Take off back cover, clean it out. un-plug it.theres about 15 screws
Sep 03, 2010 | Kenmore Dryers
Dryer is hot, clothes arnt getting dry. blower? less that 1 year old Kenmore
Remove the vent hose from the dryer and dry a load of clothes . If they dry , then dryer is pushed too far back , kinking vent hose , or the vent from the dryer to the outside is blocked somewhere . A dryer either heats or doesn't heat (except for maytag associated dryers ) in which the blower wheel could be stripped out . But Kenmores don't have blower problems .
Aug 09, 2009 | Kenmore 600 7965 Dryer
Kenmore washer dryer age?
The age is determined by the SERIAL number. If you post back with each appliance serial number, I can tell you what year they were manufactured. Include any letter designations that are in the serial number too.
Jul 23, 2009 | Kenmore 600 7965 Dryer
Kenmore Dryer won't heat up
thermal fuse is bad. replace fuse. clean out vent duct. thermal fuse usually blows when there is restricted air flow over heating element.
Jun 24, 2009 | Dryers
Clothes don't dry but dryer gets hot
ck vent to outside starting and dryer back to verify vent issue try drying a load with hose disconnected
Nov 24, 2008 | Kenmore 60172 Electric Commercial Dryer
Kenmore Dryer Model 66801692
at leas 15 yrs old??? think it's done its time, its a great machine andwould reccomend replacing with a whirlpool/kenmore unit again.no tworth servicing in my opinion, average call here in new york 150-225, anbd those are for simple issues. id rather put money into new unit! bit be sure to check your venting id say 85% of dryers taking too long to dry are vent related issues
Nov 13, 2008 | Kenmore 62872 Electric Dryer
Brown streaks
Hi thanks for the question-yes if the venting is not good ,you dryer will take 3 times as long to dry the clothes. its a must to have a clean venting. clean all venting thanks the appliance doc
May 12, 2008 | Kenmore 73952 Gas Dryer
Gas dryer
The problem you describe sounds like an airflow problem. Make sure the vent is clear and if you have a plastic vent hose make sure it is not kinked.
If the vent is blowing freely then it may be a thermostat cutting out to quickly.
Post back and let me know what you find or if you have any questions.
Nov 21, 2007 | Dryers
It starts and runs for about 20 - 30 secondds then stops
Pwolf, looks like the problem you?re having is not with the dryer. The vent line is probably clogged up, which caused the dryer to overheat. The hi limit thermostat opens up which shuts off the dryer. After it cools down and closes, you are able to restart the dryer. To make sure this is a vent problem, you can disconnect the vent hose behind the dryer and run it for one load with it disconnected. If it runs fine, then the vent line needs cleaning. Usually it needs special equipment and is very hard to do yourself. It would cost you around $90 to get a professional out to do it for you. If it doesn?t run with the hose disconnected, then you have to provide the complete model number, which is located on the door frame. Gendos....post back.
Dec 14, 2006 | Kenmore 64852 Electric Dryer
Kenmore 63012 Electric Dryer Logo
410 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
