Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
It keeps tripping the breakers or the GFI outlet.
It works for about 5 minutes, trips the breaker, then only works for 30 secs before it trips again. Even when I try plugging into a 20 amp breaker outlet, instead of the normal 15 most of my house has, still trips the GFI.
  • kclabarbera Jan 17, 2009
    I have tried that all over the house. thanks anyway.
    Genius:
  • 2,920 Answers
Try different outlets in another room to see if that dosent help you may have a shortin the cleaner but i think you may be overloading the breaker
Posted on Jan 17, 2009
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
Mar 11, 2014 | Hoover UH30010COM Bagged Vacuum
Kenmore canister - trips 15 amp circuit breaker
Check specs on unit and amperage. If it is less than 15 then the upstairs breaker is kicking off prematurely - Not uncommon event. If unit is drawing more power than specs there is excessive friction in motor bearings. Also check out brushes for good contact since they wear.
Sep 11, 2017 | Kenmore 25512/ 25513 Progressive Canister...
Dead Dirt Devil Featherlite
1. Power cord not firmly plugged into
outlet.
1. Plug unit in firmly.
2. Blown fuse or tripped breaker. 2. Check fuse or breaker in home. Replace fuse/
reset breaker.
3. Needs service. 3. Take to service center or call 1-800-321-1134.
4. Thermal Protector activated.
4. Unplug cleaner. Allow to cool for 30 minutes
Nov 03, 2012 | Dirt Devil Featherlite Bagless Vacuum...
No power
see this step: God bless you
check.gif Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset the circuit breaker. Then turn the central vacuum unit on. If the circuit breaker trips again, then refer to the following:
check.gifDetermine if the house circuit your vacuum unit is on has sufficient voltage required.
check.gifIf your unit has a reset button, press the button and try again.
check.gifCross the low voltage wire from the relay at the unit with a small screw driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
Jul 24, 2012 | Bissell 21K3 CleanView Helix Bagless...
Shark s3501 plugged
I had same problem with no steam... ready to throw in the dumpster!
I tried to it take apart. (kind of hard) still ready to throw it!
Then I thought about CLR!
I put about 1/2 cup in, turned on and let set for about 20 to 30 minutes.
I really did not think this would work but... Amazing! I actually got STEAM!!!!!!
Next I dumped out what was left, put in distilled water and ran for another 30 minutes on high.
Will use CLR again before final clean out and 2 full tanks of distilled water before I use again.
May 27, 2012 | Vacuums
My e wave microwave appears to be in fine working order until the door is opened. It then trips the breaker and ceases working. Ater the house breaker is reset, the power is restored to the microwave...
You may have a short circuit on the INTERIOR LIGHT BULB circuit in your microwave.
This might explain why the breaker trips every time you open the door.
If so, you would have to unplug and disassemble the unit in order to access the wires and light bulb socket inside the case in order to troubleshoot and repair the problem.
If you are unfamiliar with safe electrical troubleshooting and repair procedures, please be extremely careful or consider hiring an electrician to do the work. There are some hazardous components inside which remain dangerous even after the unit is unplugged.
Good luck.
Apr 19, 2011 | Vacuums
Inoperable electrical wall socket
The obvious would be a blown fuse or tripped circuit breaker. Go to your main fuse box and check for that. If you have a GFI outlet or circuit breaker, reset that. Some outlets protected by Ground Fault Interrupters are gang wired, so there may be another outlet in the room that has the GFI outlet that controls the outlet you are using. You may have to check for them. The GFI outlet usually has two small push buttons on it, one is TEST and the other is RESET.
If it is not easily fixed by those items, you will most likely need to pull the outlet from the wall box and see if you can trace it from there. First check these as they are the easiest fixes.
If you find my solution to be of help, I would appreciate a Thumbs Up from you. If my solution does not solve your problem, please contact me and we can go from there. Paul
Oct 08, 2010 | Vacuums
Using my wet/dry vac - less than 5 hours on the thing - it just stopped - can't get it to switch back on. Tried different plugs - different days. Although I purchased over 2 years ago, it has hardly been...
It may have gotten hot if you went too long before cleaning the filter. It sounds like you may have burnt it up. I hope not! You might also check to see if you tripped a breaker on the electrical panel. Try plugging it in an outlet that is not on the same circuit. If it works in another outlet, then you have just tripped a breaker.
Good Luck!
Jim
Sep 30, 2010 | Genie Company GV150 Wet/Dry Vacuum
Trips
The switch could be bad. Make sure there are no clogs anywhere that could be causing it to overheat. Try to bypass the switch and run it just long enough to see if you can go longer than the normal 5 min. you're getting. If you can then replace the trip switch. Do not continue to use the machine without the trip switch operating properly or it could catch on fire.
Jul 20, 2010 | Beam Industries 2900 Serenity Plus Central...
My Sebo hoover trips the house mains sockets every time I switch it on, yet doesn't trip the kitchen mains. Have replaced filters/bag to reduce load but still no good. What should I be investigating in the...
It sounds like your vacuum is fine if it works when plugged in the kitchen outlet. It is tripping the breaker switch in the other room because the circuit is overloaded (too many things plugged in this circuit). Try unplugging some things in that room and try your vacuum again.
If it only trips when using one particular outlet, then the outlet should be replaced. I would recommend having an electrician check your wiring out.
Hope this helps
Feb 01, 2010 | Sebo Air Belt C2.1 Bagged Canister Vacuum
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
722 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
