Question about Whirlpool Duet GHW9150P Front Load Washer
F 2 code
What does it mean? Washer quit at two minutes
  • 1,031 Answers
This problem is usually caused by what we professional appliantologists call, "panties in the drain pump." 'Course, that's just generic talk for something ain't opos'd to be there. Your hit list:
- Clean out the drain pump catchment.
- Pull the suction boot off the drain pump, clean out any gookus.
- Blow through the drain hose starting from the connection at the pump.
- If all else checks out, replace the pump.
Posted on Jan 17, 2009
  • Starnley Johnwells
    Starnley Johnwells Jan 17, 2009
    pls ill appreciate a fixyaa rating
    Starnley Johnwells Jan 18, 2009
    hope this helps do let me know
My washer is flashing f20 what do we do?
Why do i loose pressure after a few minutes
Quite often it means that your water supply is too small... not enough gallons / minute.
Jun 04, 2014 | Dewalt DPD3100 Gas Pressure Washer
Error code F-21
this code means a long drain meaning if it takes over 8 minutes to drain it will show this code and possibly "suds" code too,first try unplugging the washer for 30 minutes as this clears the central control unit if this is the case,if this doesn't help then check the drain pump located below the washer tub for any obstructions such as coins etc.if this isn't the case make sure drain pump is operating and not noisy,if it is then the drain pump needs replacing
Oct 20, 2012 | Kenmore HE2 Plus Front Load Washer
HE2plus quits with 1 minute left. Tried the rins/drain/spin several times. Sometimes get F-21 code. Checked the drain. However, the impeller in the pump seems stiff to turn - could this cause the...
Hi
Error code SD means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump.
Hope this helps... Please post back if you need more information.
Daniel
Jan 10, 2011 | Kenmore Washing Machines
Error codes
Here are the common error codes for the LG machines.
LG Washing Machine Error or Fault Codes
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
OE
This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
UE
This means that the load in the drum is out of balance causing excessive vibration when spinning.
IE
This means that the washer has not filled with water in 8 minutes.
LE
This means that the motor and the control panel are not talking to each other properly
PF
Power Failure – The power has gone out to the machine and then has come back on
FE
This means that there is too much water in the machine
PE
This means that the water level sensor is not working properly
CE
The washer motor has received and over current condition
TE
This means that your heating sensor is not working properly
SE
This means that you had a temporary sensor error
HE
This means that you had a temporary heater problem
DHE
This means that you had a temporary dry heater problem
This will give you a basic idea of what has caused your error code.
Heatman101
Mar 15, 2010 | LG WM2277H Front Load Washer
It quits on the drain cycle and a error code f02 appears
Error F02 code means Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed. Solutions: Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite calypso codes a C1 and quite working
Maybe "CL" From User Manual:
“CA” or “CL” (Current Limit)
Is the washer overloaded?
Press STOP/CANCEL to clear the display.
Jul 04, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
LG Tromm washer WM2077CW reading code LE
LE means "Overload in Motor" Unplug the washer, remove clothes, wait 15 minutes for motor to cool down. try again. If problem persists you'll need a certified technician.
May 31, 2009 | LG WM-2077C Front Load Washer
Duet washer code f 33? What does it mean?
the fault code indicates that your main data cable from the controller to the motor has miss-comunicated: unplug the washer wait about 30 minutes then plug it back in and, let me know if the code clears
May 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer code
Hi Keitha1
I'm Harvey the Master Plumber
You want to know what code dL means on a whirklpool duet washer.
This is what works for me 99% of the time:
Simply unplug the washer for ten minutes. The onboard computer will reset and work like new.
Please understand that you are not being shortchanged. There are hundreds of codes and with this new computer tech. they mostly require a repareman. To save you money the manufacturer has designed it to reset itself after ten minutes to solve most problems. Try this first, you can always call a local pro later if you want.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE5t Power and Errors
try hitting pause/cancel twice to clear the codes
May 17, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
