Question about Frigidaire FRS26KR4A Side by Side Refrigerator
FILTER CUP&HS CRACKED,WATER LINE FREEZE
MY WATER FILTER HOUSEING CRACKED AND LEAKED WATER INTO FRIDGE,WHY?.WELL THE WATER FROZED,AND FOOD ON THE SHELVES WOULD FREEZE,WITH THE SETTING AT IT'S LOWEST..IS THIS A DIY,OR CALL IN A TECH.
  • jsphantom Sep 06, 2008
    I had the same problem. Don't know why the refrigerator side started freezing things but I believe that the filter housing cracked when it became frozen. Water leaked out from the door and ruined my laminate floor. I removed the lower back cardboard access cover and vacuumed loads of dust from the coils. Temperature settings are at factory default. I also bypassed the inside water filter and have an external water filter. I used Ace hardware parts 43009 5/16x5/16 compression union and 43055 compression adapter.
    President:
  • 1,462 Answers
Are you setting the stat right? lower the number, higher the temp. lots of folks think its the other way round. set stat to 2 or 3 and should be about the right temp
Posted on Jun 21, 2007
SOURCE:
My Daewoo FR-291 fridge with freezer at topleaks 1/2 cup or so a day & onto floor sometimes. Hired one for $150 as told to turn ours off for 2 days. Leaked nxt day again. Thxs NZ
a thorough inspection of the tubes, filter, solenoid, ice maker and water dispenser should reveal the leaking component
also a thorough inspection of the defrost drain, drain tube, and dryer pan
Apr 08, 2017 | Daewoo Refrigerators
Frigidaier Side by side Fridge FRS23R4A water leaking from filter casing and no water to water dispensor
Cracked filter head our water line. Best bet is to pull filter head down and inspect water lines and head. Replace if needed
Aug 17, 2012 | Refrigerators
I have a fridgidare model# FRS23KRAW2. Some how the water filter cup cracked and sprayed water inside the fridge when cycling thru and also when ustilizing the water despenser. I replaced the water filter...
If I'm understanding your question correctly. The 2 hoses don't have a particular location. Make sure both are on securely and without tension or restriction like bending. Good to go.
Sep 27, 2011 | Refrigerators
The water filter in my GE Profile Refrigerator leaked a large amount of water until we turned off the water to the refrigerator. We did not see any warnings on the LCD. It seems to me that if the filter...
Hi
The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section (not on all models, but this is the most common way), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 02, 2009 | GE Refrigerators
How can I change the water filter on a frigidaire fridge
Hi, The filter is in the upper right hand corner of the fresh food section. Turn the filter cup counter clockwise to remove it. There will be a filter cartridge in the cup that you replace.
Please let me know if this has been helpfull or if I can assist you further
Thanks
Vic
Jul 17, 2009 | Frigidaire FRS6R5EMB Side by Side...
Water on side by side not working
I had this problem too and my water line was frozen. We left the freezer door open for about 45 minutes and turned the control temperature to 2. After about 45 minutes, with the freezer door being open the whole time (don't worry the food won't freeze), the water spewed and then became a full stream. Two days later, it's working great. Maybe your setting is to high? Try this. It worked for us. Good luck.
Jan 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No water and no ice
First thing to do is make sure the water going to the Fridge is turned on. Then make sure you bleed all the air out of the line. Hold a cup under the water dispensor for at least 1 minute and if that doesn't work, then you have to make sure the water line going to the water filter didn't freeze. After checking all that, if that doesn't work we can go farther from here.
Let me know how you make out.
Bill
May 12, 2008 | Refrigerators
Whirlpool fridge model WF-NL300 ice maker not working. No water in icemaker. Black water supply tube that fills icemaker was frozed solid with ice. I thawed it in a cup of hot water. Unsure if line could...
Turn ice maker off for 24 hours to thaw out any additional frozen lines.
Make sure that you do have water from source to unit. Water valve grit screen may be clogged with debrie or water valve is bad.
Feb 29, 2008 | Refrigerators
Fridge area freezing food; water dispensor line freezing
sometimes when the cooler weather comes in you may need to chnge temp setings to a warmer setting to prevent some items from freezing ie: leafy vegetables, water bottles, eggs, etc etc.
now if you are having total freeze up of everything in the ref section then you could have bad temp control or damper assy.
Oct 22, 2007 | Frigidaire GLRS234ZA Side by Side...
The water filter keeps freezing and food in door and on shelves keeps freezing.
clean lint from coils in back. could also be low on refrigerant (freon)
Jul 09, 2007 | Admiral 26 cu. ft. Side-By-Side...
Frigidaire FRS26KR4A Side by Side Refrigerator Logo
235 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
