Question about Whirlpool GEW9250 Electric Dryer
ON My whirlpool dryer the low limit thermostat keeps going out. all my other parts ohm out ok.
  • Whirlpool Master
  • 3,361 Answers
Replace the high limit thermostat and the thermal fuse. Clear any vent restrictions.
Posted on Mar 13, 2009
Hi, i have a whirlpool duet sport wfw8400tw03. When i run to normal cycle, it stop no error code no light. The washing machine just shut down. I can run it on delicate or sanitary.Is a balance trouble
if u can run it on delicate or fluff cycle with cool air more than likely its ur cycling thermostat or the hi limit thermostat going defective test it with a meter for ohms..
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Lastly check the moister sensor for OHMS according to ur schematic as it must show a certain amount of ohms as per ur unit. When unit has been on short while
Heating Element
A defective heating element can make a dryer too hot or not heat at all. . If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Whirlpool Kenmore Dryer Won Heat Test Replace Heating Element 279838
Apr 17, 2017 | Whirlpool Washing Machines
Fault code 8 on a whirlpool duet front load electric dryer GEW9200LW1
Could be bad heating element, bad high limit thermostat or bad cycling thermostat. All of which can be ohmed out with a standard ohm meter. If you replace one I would replace all of them, if you don't you will be going back in there later and replacing another one of those parts
Jan 16, 2017 | Whirlpool Dryers
Whirlpool dryer WGD5600SQ0,will not tumble..door switch activates light and timer..Control panel on/off switch changes states when tested with meter..thermal switch on bulk head measures short , belt ok
The issue is with the belt that is bad and so the dryer won't turn, to solve the issue you'll have to replace the belt.Hope this helps...please post back for further assistance.
Jul 17, 2011 | Whirlpool Dryers
Dryer will not get hot. All the vents are clean.
Check for burnt out heating element and electrical connections to element and thermostats. If okay check all thermostats, operating and high limit, with an ohm meter. All must be in closed position. If element,thermostats,and electrical connections good then check timer.
Mar 21, 2010 | Whirlpool LER4634J Electric Dryer
My dryer dont dry
Possible causes depend on the dryer model and type. Electric dryers work diffeently from gas dryer.
Both electric and gas dryers usually have a thermal fuse located at the back of the appliance. Check if thermal fuse/switch is blown or tripped , and eventually replace it.
If the fuse is ok, and appliance is running but not drying, then next part to test will be the thermostat.
A dryer thermostat can be tested using a multimeter , set to read impedance at RX1. If the thermostat is good, it must have low Ohms at room temp, and return no continuity (infinite ohms) at temp. limit.
At this points things are different depending if dryer is gas or electrical.
On a gas dryer test valve , fan and ignitor.
On electric test the heating element and fan.
On both gas and electric, last part to be tested is the timer control board. If all other parts are fine, go for the timer board.
Sep 17, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I looked at thermal fuse looked ok like a piece ofsraight caulkin
the thermal fuse can look good but shorted inside. take clip leads and jump it out. sometime they ohm out but cant carry voltage
Apr 08, 2009 | Dryers
Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Jun 28, 2008 | Whirlpool GEW9250 Electric Dryer
MAYTAG MDG6200 AWW flame keeps keeping going out
Your thermostat is broken.
I think the gas 5 wire or the heat limit
or what i would check first is the fuse on the blower housing which is a thermal fuse. A regulat ohm meter /resistance meter can do the trick. No resistance should be measured or very low on this fuse. If uninfinit restistance this one is broken.
It can also be the limit thermostat . Measure when cold. > low resistance.
This is another link for PARTS
Good luck
May 04, 2008 | Maytag Performa PAV2200
Thermostat, High limit and low limit thermostat or even a safety Temp limiter. All three are similar in cost and located on the back inside of the dryer and 1 by the airflow tube under the lint trap.
Apr 08, 2008 | Whirlpool LEQ8858J Dryer
Whirlpool GEW9250 Electric Dryer Logo
57 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
