Question about Garmin Nuvi 350 Car GPS Receiver
My garmin nuvi 350 displays "enabling Bluetooth" and will not move . What should I do
  • Garmin Master
  • 2,130 Answers
A Nuvi 350 does not have bluetooth capability. Do you mean Nuvi 360? If it is a 350, then the firmware is corrupted or was flashed with the wrong firmware.
- Jim
SHARCNET-USA
Posted on Jan 17, 2009
Hi, My Garmin nuvi displays 'gps is off' which means i am unable to de directed correctly as its saying im in the middle of no where. Please can you help? Thank you Laura
There are two possibilities as to why your GPS is not responding.
The first is to check your System Settings. Although it should not affect your GPS signal, check to see if the WAAS / EGNOS setting was turned off. If so, try turning it back on.
The other possibility is that the Garmin device is not reporting the status of your antenna properly. When the Antenna is closed on the nuvi 350, it disables the GPS functionality. Simply open the antenna to re-enable GPS. If the antenna IS open, there could be a hardware malfunction. This would require contacting Garmin for additional assistance.
Contact details for Garmin can be located at http://www.garmin.com/garmin/cms/site/us/support/supportcontact
May 27, 2011 | Garmin nuvi 350 GPS Receiver
Nuvi 350 Color does not show properly
Most likely the LCD needs replaced. Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Mar 20, 2010 | Garmin Nuvi 350 Car GPS Receiver
How do i pair my 265wt with my LG vx9900?
Garmin claims the nuvi 265wt (et al) supports the LG VX9400, which means it's also likely to support the VX990 (but one can't be certain).
1. From the main screen on the nuvi, touch Tools>Settings>Bluetooth.
2. Select Enabled.
3. On the VX9900, do the equivalent to enable its Bluetooth port.
4. Let your phone search for Bluetooth devices.
5. Select the nuvi from the list.
6. Enter the nuvi Bluetooth PIN (1234) into your phone.
You can do steps 4-6 from the nuvi if your phone is already enabled for Bluetooth.
Jan 17, 2010 | Garmin nuvi 255W GPS Receiver
I have a Garmin Nuvi 680 I would like to use it as a hands off cell phone in my vechile. I no little about blue tooth. How do I go about getting my cell phone to work with my Garmin. Thanks Joe
Hi Joe,
1. First, you have to turn your bluetooth function (power) on your phone on. See your phone manual.
2. On your Nuvi, press the wrench symbol, then the bluetooth symbol. Press the option to enable bluetooth on your Nuvi. You will know that it is enabled when you see the bluetooth logo at the main menu on your Nuvi.
3. While in the bluetooth menu of your Nuvi, press the ADD button. It will tell you to turn the bluetooth function on your phone, which you should have already done in step #1.
4. Your Nuvi will start searching for your phone and if it finds it, the brand name will show up on your Nuvi's screen. Select the phone model and press OK. It will then tell you the pass key code. On your phone it will ask if you want to pair with your Nuvi. Select yes and enter the pass key code into your phone. This is usually 1234.
That's it. Your Nuvi will say you can now make phone calls. When you unit is paired to your phone and the bluetooth is turned on your phone, you will see a telephone handset at the main menu. Press that and you'll be able to select options to speak the phone number, enter it manually, transfer your phone address book to your Nuvi, etc......
If your phone isn't recognized by your Nuvi, make sure you have the latest bluetooth firmware on your Nuvi. It can be updated with Garmin's webupdater program available on their website.
- Jim
SHARCNET-USA
Feb 19, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin 760 is stuck on enabling bluetooth
Seems they have been having the identical problem with the 660
Here's a link to the solutions..
http://www.fixya.com/support/t179960-garmin_nuvi_660_bluetooth
The 2 best suggested fixes were probably that you need to reset the garmin ( instructions at link)
Or update the bluetooth software ( Probably the best solution)
Sad that the left hand does not know what the right hand is doing but this is what happens when you have a marketing company in one country having their product made in another... :(
Aug 17, 2008 | Garmin Nuvi 660 GPS Receiver
GARMIN NUVI 350
Sorry to say the LCD display is cracked. You can find a replacement LCD display with tools on eBay but they are kind of pricey.
You might try finding one for sale that has an antenna problem or is completely that had a known working display at the time it died.
If you send it back to Garmin, it will cost you almost the same as a new one if your unit is out of warranty.
- Jim
Jul 09, 2008 | Garmin nuvi 350 GPS Receiver
Bluetooth
Try charging your battery.
Dec 25, 2007 | Garmin nuvi 350 GPS Receiver
Won't acquire satellite
There is currently an Update (Vers 5.10) available at Garmin.com Check only the Nuvi 350 click on it and the Nuvi 350 will appear. In the Upper Right Corner you will see a Category of Updates. Click on it and you will be advised that you need to Download UpDater. Do so, uncompress it, then attach your Nuvi to your computer and run Update. It's simple, just follow the instructions on the screen. However, it sometimes take a couple of tries before the Nuvi actually accepts and shows that it has been updated to Vers 5.10 I guess I was lucky. Mine accepted the new update with the 2nd install but it sometimes takes 4 or more. If you are uncomfortable with the foregoing or it doesn't work for you contact Technical support at Garmin. They are really helpful and you can e-mail them at techsupp@garmin.com
Dec 07, 2007 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 660 - Bluetooth
I fix this problem for my Nuvi 660 Europe. I found resources in Italian language only: 1 - go to http://www.garmin.it 2 - in the search texbotx (i the up left corner of the page) type bluetooth and press enter 3 - click on the 1st faq that will appear 4 - download the file FileBluetooth.zip 5 - unzip the file 6 - copy 006B055301.GCD in X:\Garmin\RemoteSW directory 7 - reboot your nuvi At this poin bluettoth would be ok newly. Bye
Aug 08, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
122 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
