Question about Kenmore 24032\24036 Top Load Washer
My washer is leaking into the bowl. How do I get the back off to fix?
  • 640 Answers
There 2 scews on the front or rear console...remove them there at the left and right corners..now flip the console back..and let it hang backward,,,good now you see a white connector that leads to your lid switch..it has 2 gray wires on one side ..and a brown and black on the other,,disconnect them...now at each end of the top at each corner theres a brass (gold) clip pop them out from top with a small screw driver,,now pull the hole cabnit..or body of unit towards you..your in...note the back do not come off on this unit...but you can see the drip...onthe job
Posted on Jan 17, 2009
Honda160gx fuel bowl leaking
Hi, there should be an o ring between the bowl and the carburetor, check for damage or if missing, also there should be fiber washers on the retaining and the draining screws. Check for a hole in the bowl if rusted, check if the bowl flange sits parallel to the carburetor and finally check for a rubbish in the bowl that will stop the float valve to operate correctly and cause the carburetor to overflow.
Apr 04, 2014 | Honda Pressure Washer PSI 3000
Brigs n straton pressure washer won t stay running unless you put or keep starting fluid in in
Loosen the carb bowl nut until it begins leaking into the shallow clear glass bowl you placed beneath it. It may take a minute to have drained the water out of the bowl and another minute or so to get some more from the gas tank. With the glass bowl you will be able to see the water in the bottom and gas floating on top of it. When you see the gas on top then tighten the bowl nut and try to crank. (Choking helps draw out water still in carb) Return gas collected. to tank but do not let the water go back in.
Sep 12, 2013 | Psi Blue Max 2200 High Pressure Gas Power...
Gas from the tank runs through the engine (when the motor is off)
Hi and welcome to FixYa, I am Kelly.
You can fix this yourself.
(Turn off the fuel selector)
Remove the carb float bowl nut and bowl. Note the gaskets upper and lower. Remove the float pin retaining the float and drop the float and float needle together.
Briefly turn on the fuel selector and then back off. You are flushing debris from the float needle seat. It is a good idea to use carb cleaner to ensure that the float needle seat area is clean.
ALSO spray carb cleaner into the threaded area where the bowl nut attaches. Your cleaning off the metering jet orifice up inside the threaded area.
INSPECT the float needle itself. The rubber tip should be tapered and pliable. If there are any nicks cuts or debris on the end of the needle first wipe it off and determine if you need a replacement float needle.
Reinstall float and needle ensuring you have the float pin properly installed.
CLEAN the bowl NUT along with the float bowl. Then reinstall the the float bowl. 2 gaskets upper and lower must be properly seated.
Turn on the fuel selector...
Test for leaks.
This should fix the leak but... if you still have the problem and did not change the float needle and seat. Change them. The float needle seat can be difficult to remove. I find that air in the fuel supply manifold fitting will blast most of them out but... sometimes I have to use a drill bit the size of the hole to cut the rubber material and then dig it out with a scribe or jewelers screwdriver. Just make sure to clean the hole with carb cleaner before installing the new seat. To install the new seat... reverse the drill bit using the flat chuck driven end and press it into place. Works great!
Thanks for choosing FixYa,
Kelly
Apr 22, 2011 | Honda 2500 PSI Gas Pressure Washer
Leaking from some where-hoses are dry
the way we fix this is put a small amount of water color / red /blue into the bowl take the back of and watch as it washes to see were the leak is
Dec 29, 2010 | Frigidaire GLWS1339AS Top-Load Washer
My toilet only leaks when flushed. It seems to be coming from the connection at the tank. The tank is not cracked and a new hose from tank to shut off valve has been installed. The toilet is only 4 years...
If you have 2-part toilet, then tank is attached to bowl with 2 bolts.
Look inside tank and you can see bolts with rubber washers located on either side of flush valve.
The 2 bolts hold tank and bowl together and between tank and bowl is a washer called the spud washer.
So spud washer could be leaking ... or 2 bolts could be leaking.
1) If bolts are leaking, there is usually dripping all the time, and drips are visible on bottoms of bolts
If spud washer is leaking, then tank could leak only when tank is flushed.
2) First thing to try is tightening nuts on the 2 bolts. Nuts may be loose. Tighten nuts a few turns, and check if toilet still leaks.
3) To fix a spud washer, you usually need a new generic one from hardware store.
Newer tanks with 1.6 gallon flush have special sized spud washer.
geno_3245_105.jpgTank is upside down and spud washer is fit over flush valve
If you cannot find new spud washer, re-use old one and smear retorseal on it during re-assembly to make sure it seals. Rectoseal is good for many home plumbing repairs. More about that in a moment.
4) To take apart tank: Disconnect supply line to tank. Empty water out of tank. Remove nuts from bolts. Lift tank off. Wash out tank with hose. Make sure there is no sand or sediment left in bottom that might clog up flush holes located inside bowl after tank is re-assembled.
5) Remove old spud washer, and put new one on. Do a google-image search for 'spud washer' if you need more photos. New spud washer fits over flush valve. That's it. And then reassemble tank.
If you want to apply rectorseal to washer, put washer on as shown in photo above. Then smear-or-gawm rectorseal over area of washer that sits on bowl. Rectorseal will make sure there is no more leaking.
Nov 24, 2010 | Bemis 1200 Slow Elongated Toilet Seat,...
Leak under toilet bowl. Water seeps out from under the bowl. It's not a drip from outside .I replaced the wax ring but no improvement.
1 - Check bolts and washer from the tank to bowl for a leak.It can leak and run down the bowl and pool around bottom of bowl. It will run down the back and under toilet and come out from under bowl in front.
2 - Does the flange sit below floor level some wax ring's differ in size. May take a wax ring with a horn to in the flange, You may try 2 wax rings stacked or get a jumbo size one to get a better seal.
3-Check water line and for possible crack in toilet some where a last resort. Was the flange secure and in good shape, inspect it for a possible crack.
Jun 07, 2010 | Home
Water is leaking from top loading frigidaire crown washer
go on line find model number on the back of washer
you should be able to fine seal kit and yes a new seal kit well do the job you well have to remove the drum unclamp hoses and remove you may want to have repairman come do this.
Nov 25, 2009 | Washing Machines
I have a WMA 31 washing machine. There is a serious leak from the white plastic bowl at the back. The bowl is fastened with a large bulldog grip. Could this have come loose? We bought the damned thing...
think you are referring to Sump/could be loose clip or damaged sump//if no transit bolts were fitted during transportation this can result in serious damage..Hope you manage to fix ok...
Oct 07, 2009 | Hotpoint WMA31 Front Load Washer
I fixed (I think) a broken flaper valve assembly. In doing so, I created a leak where the bolts affix the tank to the bowl. I can't find a rubber gasket assembly (I don't even know if that is the right...
Go to home depot and tell them you need a tank-to-bowl gasket. They have them at home depot and it may come with new bolts for the tank-to-bowl fastening. New bolts would be a good idea to pick up anyway. One rubber washer under each head, then a rubber washer at the bottom of the tank. Use a metal washer and nut to secure this to the tank, then use another washer and nut from the bowl to the tank.
Jul 06, 2009 | Sterling Home
Kenmore 24032\24036 Top Load Washer Logo
21 people viewed this question
Sal De
fordexpert
Robert Rankin
