Question about Canon Rebel XT / EOS 350D Digital Camera
Canon rebel xt
Where is the circuit board fuse?
Thanks; Steve
  • 489 Answers
Hi, sorry I dont' know I have a friend that I send them to for no power repair. Im going to ask him for details becuase he can no longer repair cameras for us.
Posted on Jan 17, 2009
I have canon rebel xt with promaster spectrum 7 70=210mm lens. i keep getting error code 99 on lots of shots, am i doing something wrong?
Check for bent CF pins. Remove back cover and make sure bottom right screw that holds the rear circuit board has not come out (a very common problem with this model) and is shorting out part of the board. Try another lens - if it only does it with this lens then the lens is bad, usually caused by a bad aperture unit. Promaster does not sell parts unfortunately.
Oct 06, 2013 | Canon Rebel XT / EOS 350D Digital Camera
Camera will turn on but screen stays black and wont shut off
These have problems with the bottom right screw on the rear board coming out and shorting out part of the circuit. Remove the rear cover and check to see if the screw is in place. Note that they can be anywhere in the camera and while sometimes they just short out fuses sometimes they blow circuit boards
Aug 12, 2013 | Canon Rebel XT / EOS 350D Digital Camera
Digital Rebel XT blinking "busy". Cannot reset!
This sounds like the screw that always comes out in these has shorted out the flash circuit to the main body ground and shorted out two or three circuit boards.
Mar 18, 2013 | Canon Rebel XT / EOS 350D Digital Camera
I am recieving a error 1 message on my Canon RebelXT/Eos
ERR 01 is a lens communication error. Try cleaning the contacts on the lens and in the mirror box.
ERR 05 is a flash error. It is usually caused because the flash failed to pop up. This can be casued by something as simple as the flash hitting the brim of a 'gimme' cap or impact to the flash or most likely spillage of sticky liquid around the flash and its pivots.
The XT also is notorious for having the bottom right screw of the rear circuit board come loose and short out some function of the camera, or even blow the main fuse or damage the circuit boards.
Jul 12, 2012 | Canon Rebel XT / EOS 350D Digital Camera
My camera went completely dead and it is not a battery or CF problem
The Canon digital SLRs have internal fuses on the main circuit board. These are soldered onto the main board and are not user replaceable. You will likely need the camera serviced by a professional repair shop or Canon USA. Check here on Fixya for someone local by zip code.
Feb 06, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Digital Rebel XT will not turn on.
It could be a number of things. The first thing you shouild do is remove the back cover and check for loose screws. If you don't find any, the problem may be a damaged battery door switch, a damaged memory card slot door switch, or worse- it may be a defective power board.
Dec 04, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS/Rebel XT won't power up
Joe, this happened to me, just tonight... I got a new CF card and stuck it in, turned it on and one CF card flash. Completely dead from there. I found one of the CF card pins bent over, shorted out the socket and blew the mainboard fuse. I took the camera apart, found the fuse (labelled K) about under the set button area) I bridged the fuse with a bit of solder, straightened out the pin in the socket, put it all back together and it's working fine. The fuse is under the right side shield cover, it's labelled with a letter K. There is another fuse on the power inlet board (below the shutter button) and it's labelled 'P'...
Aug 01, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon digital rebel 350D
The first thing to check is that the card door and battery door are firmly closed - press on them while the camera is on to see if it powers up. If not, there's probably a blown fuse - it will have to go to the shop.
Oct 08, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT
It is normal. Camera lightens surrounding to get focus point.
Oct 30, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
370 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
