Question about Frigidaire Dishwashers
Frigidare dishwasher doesn't run
The motor doesn't start, no water pumping in.
If you have your dishwasher on an outside wall, the water line may be frozen, try opening the sink cabinet doors allowing warm air to circulate around the water line.
Posted on Jan 17, 2009
Lg dishwasher ldf7932st motor starts but doesn't work
Is the water turned off? Dishwashers normally start a wash by emptying any waste water tipped into them during loading. Problem could therefore be a blockage somewhere, most likely in pump inflow under the filters in bottom of machine. Lift these out to check. Also check your sink drain isn't blocked and preventing the water from being pumped out.
Jan 19, 2013 | LG LDF7932ST Builtin Dishwasher
Dishwasher will not drain
Hello there and welcome to fixya
Please check the following carefully
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing. Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it. Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced. Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced. Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Oct 05, 2011 | Neff 24 in. S5409X0 Built-in Dishwasher
My mother-in-law called and her dishwasher is making a loud noise when the motor runs. sounds like a bad bearing somewhere? the noise stops when it drains (motor not running?). does that sound like the...
There is only one motor -- it runs a water pump for recirculating the water when it's washing and runs a water pump when it's draining.
It sounds like the spray arm is making the noise -- this is the part thru which the motor / pump forces the water during the wash cycle -- the pumped water causes the arm to rotate -- a warn or loose spray arm or mount is likely the problem.
Or, it could be just some utensil stuck in the bottom of the dishwasher which the spray arm is rubbing.
More info, let me know.
Charlie
Jul 16, 2011 | Kenmore Dishwashers
Hello. after washing water still inside of machine. MAYTAG QUIET SERIES 300.
Hello there and thank you for choosing fixya
Drain line/air gap
Pump
Belt
Motor
Timer
Jun 29, 2011 | Maytag Dishwasher
I have an older model kelvinator dishwasher and there is water in the bottom of the dishwashwer and the diswasher will start and then stop but will go through all of the cycles. It just doesn't do the...
Pull the dishwasher out of the slot. There is a motor underneath that runs the pump to drain it. The usual cause is the it has a bad connection.
May 28, 2011 | Microwave Ovens
Dishwasher began leaking underneath when turned on. Humming as if trying to start, but nothing further exept water on floor
I don't know how old this dishwasher is but the symptom your describing sounds like the ceramic water seal on the bottom of the impeller assy but above the motor has failed. When the seal fails it allows water to run though the motor and then the bearings in the motor fail. Once water starts running though a dishwasher motor they are pretty much shot. The reason for this is that the leak starts out slow and it leaks for a long period before you ever see the water under the dishwasher. So by the time you see the leak water has been going through the pump / motor assy for weeks or months. By that time the service technicians only option is to replace the motor pump assy.
Kelly
Apr 14, 2010 | Bosch SHU5315UC Dishwasher
My frigidare dishwasher won't drain the dirty water
Look at repairclinic.com for your model. If the motor shows a reversing valve, that may be your culprit. Some D/Ws like Whirlpools drain by reversing the motor direction via the timer mechanism. Also look for a destroyed pump impeller/diverter that is keeping it from pumping water out. Check exit hose for obstruction, even at disposer or air gap.
Jun 09, 2009 | Dishwashers
Dishwasher not draining and making a noise
Ok, normally, when you hear abnormal noises and the draining has stopped, this will point to the pump/motor assembly. this assembly , basically, runs together in unison. the pump/motor are as one and if the motor is malfunctioning, the pump will not drain properly. this noise is coming from the pump housing. There are many parts that are located in this housing and one fragile part that can cause issues is the Impeller. this piece provides the pump action that moves the water during drainage. If the sleeve that connects to the Impeller becomes stripped, the motor drive bolt will simple spin freely, causing this noise and no drainage. The motors fine but, you will have to replace the pump assembly in order for this noise to stop and the normal draining cycle to return. just to be safe, check all the drainage hoses as well.
please rate and god bless:)
Apr 01, 2009 | Frigidaire Dishwashers
Dishwashers Logo
163 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
