Dimplex model D55804. Why doesn't it heat as well as it used to?
The fan works, the bulbs work but it doesn't heat up as well as it used to
Buffalo12980
  • 625 Answers
SOURCE: dimplex air heater
my guess is the power switch is shot.
Posted on Nov 04, 2007
buzzwood
  • 65 Answers
SOURCE: Dimplex Compact Electric Flame Stove Heater
call Dimples !-800-663-6663 ext 358 They will be able to help you out.
Posted on Jan 21, 2009
SOURCE: my dimplex night storage heater has stopped working.
...not too sure of your model but all dimplex heaters to my knowledge have an 'overload' cut out built into the system. Ours is more up to date but still goes now and then, problem is you have to get into the electrics and click the reset button, normally near or on the thermostat it's self, could be a small white plastic button, or a piece metal sticking up that needs pressing down to reset...but please before attempting make sure that you TURN OFF THE ELECTRIC / REMOVE THE FUSE/ WHAT EVER IT TAKES TO CUT ANY CHANCE OF AN ELECTRIC SHOCK!!!...because I can and will get you if it can ;-)... if your not a competent electrician please get hold of one !... good luck.
Posted on Feb 13, 2009
t1m130
  • 86 Answers
SOURCE: my dimplex wall fan heater fx20 switch broke and i
www.torreelectrics.co.uk/acatalog/Dimplex_wall_fan_heaters_FX20.html try this site
Posted on Jul 28, 2009
reddyanantha
  • 205 Answers
SOURCE: The heater on my dimplex fire appears to be
dear sir/madam
have you checked for the power supply before changing the bulbs,if not please check it then you come back to us we will help you.
Posted on Aug 06, 2009
I have a small wall heater, towel rack included, the fan & timer work, but no heat. Where do we find the model number
Usually on a small sticker on the back near where the wire goes into it.
If you know the make you can Google it and look at the images tab like this for 'Dimplex bathroom fan heater'.
dimplex bathroom fan heaters Google Search
Jan 22, 2016 | Heating & Cooling
Dimplex dakota heater is working but flame effect is not its led I think not bulbs.
Says you can turn it on and off? Did you knock the switch?
Can I operate the flame effect on the fire without the heat?
All our Optiflame and Opti-myst fires can be operated on a flame-effect only setting, as can the flickering flame effect on our freestanding bar fires.
Is the flame effect expensive to run?
No, to run the flame effect involves powering light bulbs and a small electric motor and in most cases costs no more than a couple of pence an hour. Some of our fires have LED lamps fitted which are even more energy efficient.
Some have bulbs, some have LED.
Example calculations:
Using UK standard average price of electricity of 14p/kWh (source: Energy Saving Trust Feb 2015)
Optiflame LED flame effect only (eg Danesbury) = 0.1p every hour
Optiflame conventional bulb, effect only (eg Cheriton) = 2p every hour
Opti-myst, flame effect only (eg Oakhurst) = 3p every hour
Opti-V single screen = 0.5p every hour
2kW fan heater, on constantly (no thermostat) = 28p every hour
Optiflame lightbulbs for sale. Remove the coals and check for bulbs.
https://store.gdcgroup.co.uk/dimplex/products/index.htm?product_code=FP03022
Dec 23, 2015 | Dimplex Heating & Cooling
I have a Dimplex Small Electralog Stove Fireplace CS1205, it's two years old but barely used until this winter. A couple months ago, the flame stopped working and now the heat keeps turning off after 5...
More than likely, the interior of the unit needs to be cleaned. When it's in operation, it sucks dust and link into the fan and heater elements. When it's not, spiders love to go into and build nests. If badly clogged, it can cause the heating element to over heat and shut off. Carefully, removing the back panel of the stove will give you access to just about everything. As far as the flame is concerned, the bulbs may need replacing. Although, it's unusual for all of them to go bad at one time. You or your nephew can replace them after the unit is cleaned. A vacuum that has a hose, brush attachment and crevice tool, will work well in the cleaning of the interior. Be sure to turn the Master ON/Off Switch to OFF & Unplug the unit, before attempting and maintenance on it.
If after performing all of the above, the unit still doesn't work properly, contact Dimplex USA, Technical Service 888-346-7539, for further advice.
Hope this helps to solve your problem. Please let me know.
Mar 17, 2011 | Dimplex Compact Electric Flame Stove...
Fan working heat coming out no embers
It's a bit unusual for all the bulbs that create the flames to go out at the same time. But, I guess it could happen. However, I thinks more likely the flame switch or its circuitry has failed. Not at all that uncommon in electric fireplaces and stoves, regardless of who the manufacturer is. It happens more than you'd suspect. If you don't know how to access the light bulbs, check you Owners Manual. If you know longer have your Owners Manual, go to the Dimplex USA website and you can download the Owners Manual in a pdf format and print it for future reference. Have your Model # handy when you do this.
Hope this helps you solve the problem.
Feb 16, 2011 | Dimplex Compact Electric Flame Stove...
Fan works but no heat
go to : www.dimplex.com or call: 1-800-668-6663 ext. 358 for custmer help
Jan 04, 2009 | Dimplex Compact Electric Flame Stove...
Heater fan stop working after a couple of muinutes
Dimplex Electralog Model 6901050600 Ser 17807D2F - 048 Blower and Heater Works fine, Flame has quit working. How do you find and replace the Bulb? Email cairoeichard@gmail.com
Jan 02, 2009 | Dimplex Compact Electric Flame Stove...
No Heat or fan on model DS4411 Or 6901050100
I had the same problem. One or more of the switches for the stove have melted and broken. You need to call Dimplex and request new switches. They should ship you out a 3 pack for free, and the pack will come with easy instructions for removing the bottom panel and replacing the switches.
Dec 22, 2008 | Dimplex DS5598 Mid-Size Heater
Heating & Cooling Logo
180 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
