Question about GE Energy Star WCVH6260F Front Load Washer
GE WCVH6260 Front Load leaking water from bottom of the door when the machine is running..What is the problem?
  • SarahDill Feb 04, 2009
    I had the same problem. I discovered that inside the seal, where the water drains, there were random items that were left in pockets, ie; wadded paper, a bracelet and coins. I removed them and all was good.
  • Anonymous Mar 24, 2014
    larger leak at hispeed and counter clockwise
    Genius:
  • 2,920 Answers
You have a bad door seal
Posted on Jan 17, 2009
Water leaks out front center of door during the
Check the door gasket for any damage. A rip or a tear could be the cause of the leak.
Jul 20, 2010 | GE WSXH208A Front Load Washer
Water is leaking needs a new seal?
The GE front load washer Front seal does have a common problem withe the front seal getting riped. Open the door and inspect the bottom half, you might find the hole. if not you will half to remove the bottom access area and locate the leak.
Jan 08, 2010 | GE WSXH208A Front Load Washer
Washer, Front load #WCVH6260 F W W - trying to
use a theromstat screwdriver,
ver small flat head, push it betwen the detent
and the clamp it should release right away
Oct 03, 2009 | General Electric WSSH300G Front Load...
Ge washer wcvh6260 ...... start/pause button flashes, won't start
Does the 'door locked' light come on? If not, check the switch and it's actuator (a pin that is part of the door latch).
Aug 22, 2009 | GE WCVH6260F Front Load Washer
My washer will not start. I press the start/pause button and it just beeps twice and does not lock door or start wash. ge adora model wcvh6260
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Aug 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
GE WCVH6260 stops unexpectantly
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped.
Check your drain with a good pour of water from a bucket, it must clear fast. It it doesn't snake it out; the prob lies there 99%. And don't push your exit hose too deep into the standpipe, 4 to 5 inches & not air tight.
Nov 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE WCVH6260
Quite possible your pump is clogged, you have to dismantle.
Try these sites:
espares.co.uk
RepairClinic.com
AppliancePartsPros.com
Pl rate me.....................
May 31, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
406 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
