Question about Lands Phones
While upgrading my Noka N72 cell phone's firmware using usb cable software encounterd an error and got hanged and ever since my phone would not switch on.Any workaround while phone being switched off?
    Scholar:
  • 86 Answers
No known workaround on this really. But you can bring phone to service technician and have it resetted in there. They will upgrade firmware as well if phone is still working and revivable.
Bad news is, just like on a PC if it gets interrupted in the middle of a firmware upgrade (BIOS) it could cause the motherboard to crash and render it unusable.
Thanks and good luck!
Posted on Jan 17, 2009
My mobile nokia n72 hang up it does not start how to flash it
try this
switch off your mobile press and hold these buttons
*+3+call button(green butten) by holding these buttons start your mobile
Jun 01, 2011 | Nokia N72 Cellular Phone
Tip
Nokia N900 Firmware Update
Nokia N900 Smartphone Firmware Update v3.2010.02-8 (PR 1.1.1)
If your Nokia N900 smartphone is freezing, hanging or acting up I recommend you update the system software / firmware of your device. Erratic behavior can often be corrected by a firmware upgrade.
Here are the instructions for updating your N900 smartphone:
Over the Air (OTA) Update
  1. From the phone's home screen key in *#0000# or go to Device manager
  2. Select Options then Check for updates
  3. Follow the prompts on the screen to complete the update
Update via a Windows PC
  1. Download and install the Nokia Software Updater
  2. Connect your N900 to your PC with the supplied USB Cable
  3. Open the Nokia Software Updater application
  4. Follow the on-screen prompts to update your device
Update via a Mac
  1. Download the 770Flasher tool
  2. Download the latest available N900 firmware image
  3. Turn the N900 off
  4. Connect the N900 to your computer via USB cable (with the device turned off)
  5. Run the 770Flasher application
  6. Drag the firmware you downloaded in step 2 to the 770Flasher application (you will get an error regarding a USB device not being found, ignore it)
  7. Turn the phone on
  8. The update process will now begin automatically once the N900 boots
  9. You are safe to disconnect your phone from the computer when you see the normal desktop reappear on the N900 display
Update via a Linux PC
  1. Download and extract the Linux Flasher tool
  4. Connect the phone to your computer via USB cable (with the device turned off)
  5. Open a Terminal window and run 'sudo ./flasher-3.5 -F -f -R' (you will get an error regarding a USB device not being found, ignore it)
  6. Turn the phone on
  7. The update process will now begin automatically once the N900 boots
  8. You are safe to disconnect your phone from the computer when you see the normal desktop reappear on the N900 display
I hope that helps.
on Apr 02, 2010 | Nokia N900 Smartphone
Hi i am using nokia n72. problem is hang and stop
It seems that your firmware has got corrupted for some reason. You will have to get it reinstalled. HOW???
Fully charge the battery. Take a backup of the phone data. Connect through the USB cable only. Start Nokia Software Updater (if you do not have then you can download it through Nokia PCSUite), Follow the instructions and you will have a brand new phone. Restore the data to the phone.
If you feel this is too taxing then take the phone to the nearest Nokia Care and ask them to reinstall the firmware. They will not take more than half an hour. But may charge if the phone is not under warranty.
Updating the Phone Firmware (Nokia)
Dec 11, 2009 | Nokia N72 Cellular Phone
Any of the multimedia applications (Gallery, music player) are not responding on my Nokia N72
sir i am also using nokia n 72 !! it seems that there is some problem with your phone's firmware!! you should upgrade your phone's firmware!! it can be done at home using nokia pc suite and internet connection!!the firmware file is about 40 mb in size and you have to download it!! or go to nokia care !!they will take rs 200 from you and upgrade your phone's firmware!!
Upgrading at home is a little bit risky!!while upgrading if you accidentally sidconnect your phone, or there is a power cut off then your PHONE WILL BECOMES USELESS!!!
Oct 24, 2009 | Nokia N72 Cellular Phone
When i switch on my nokia n72 ,the white screen appears with nokia logo and it doesnt start further..its being hang for last..i was vexed with it up..plz kindly help me how to fix it. n 72 white screen...
i think that there is a problem with your phones's firmware!! it hangs repeatedly !!!you must upgrade it!! go to nokia care and they will do it for you for rs 200!!!
Oct 13, 2009 | Nokia N72 Cellular Phone
My Nokia N72 phone is hanging. It goes off and on. Sometimes, it hangs on "Nokia" logo at startup. What can I do to make it work again?
your handset needs a software upgrade,
use nokia pc suite to upgrade it OR:
take it in to be flashed.
BR
Jun 11, 2009 | Nokia N72 Cellular Phone
How to format my nokia n72 phone using manual procedure
Download Nokia PC suite, install on computer, connect phone via cable, upgrade/restore firmware.
Feb 03, 2009 | Nokia N72 Cellular Phone
To use my Nokia N72 cell as a webcam without installing a blueto
yes you can but for that you should download and install the usb cable driver for camera ..
gogle it
thankyu
Nov 19, 2008 | Nokia N72 Cellular Phone
NOKIA N72 FORMAT - REG
you can upgrade the firmware instead by downloading the "nokia software updater" from the nokia site given below it is free
http://maps.nokia.com/A4579163
first you must download that and then you can upgrade the firmware of your cell ...
NOTE: never disconnect or power off during the firmware update this will damage your cell phone completely and after that even if you visit the nokia also they cant help you with that , so while doing that do it carefully ..
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
have a nice a day
Sep 04, 2008 | Nokia N72 Cellular Phone
Lands Phones Logo
76 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
