Question about Westinghouse 24 in. MDP531 RF Free-standing Dishwasher
Powder not dispersing
Our Westinghouse freestanding dishwasher (906) doesn't disperse the powder properly. When the cycle finishes the powder is all caked together and stuck in powder holder. I think it might be that water is getting to the powder holder before it opens and that makes to stick in there or maybe the lid of the powder holder isn't opening at all during the cycle. Any help/advice would be great.
  • Anonymous Jul 22, 2008
    We have cleared all the filters, removed rotator arms (found no blockage) and replaced.
    President:
  • 1,462 Answers
Possible the wash arms are not rotating - a common cause of powder not being taken. check by opening the door when in use and look to see if arms rotate. if not, then remove the arms and clear the jets especially the angled jets at the end which cause the arm to rotate
Posted on Jun 21, 2007
SOURCE:
My washing machine does not clean clothes properly and washing powder residue is left after wash on clothes I have Daewoo Dwd F1243
start a wash with a load and after he machine fills with water check to see if the drum rotates this is usually the problem if you get powder residue on wash with no drum action the powder does not disperse also check to see if the machine spins if it does check belt tension if not check belt tension and motor brushes
Mar 04, 2014 | Washing Machines
My dishwasher model FFD612EMBGS keeping half of the detergent in its location it dose not take it fully and some detergent powder snag on the dishs
Check to make sure you are not blocking the soap dispenser door with a large platter or pan in front of it. The water will not be able to wash out of it.....
Jan 29, 2014 | Frigidaire FFD612EMBGS DISHWASHERS FOR...
Dishes come out feeling gritty. Using Finish doesn't help
If you open the door immediately after the dishes are washed, and before the "dry" cycle, is the water hot enough to have "steam" coming out of the machine?
You should be able to feel the heat.
If not, perhaps the water is not getting hot enough to dissolve the dishwashing powder.
Could you try using a liquid soap once and see what happens?
Be blessed.
Feb 17, 2013 | LG Dishwashers
Printer showing TONER LIFE END even there is 70% of powder balance
go to this site and read carefully http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_list.html?reg=us&c=us&lang=en&prod=hl2170w_all&Cat=7
then gently remove the drum , place it in a plastic bag -- seal the bag , so you do not get powder all over you .. with both hands holding each end of the bag , rock it lightly back and forth. this will allow the poweder to be equally dispersed inside the drum .... remove the drum from the plastic bag. You may need to clean off the black powder from around the toner before placing it back to avoid powder in the printer area.. use old and very damp cloth then place it back into the printer ..
i hope this helps -- please rate me
Nov 02, 2010 | Brother HL-2170W Laser Printer
Soap powder will not dissolve in tray
Make sure you have the powder in the correct compartment, and that there is no blockage or obstruction to prevent the powder going down, to prove this, pour water into the tray with some powder in , and see if it takes it down.
Also make sure that there is adequate water pressure to take the powder down
These are really the only things that could prevent dispersal of the powder.
Hope this helps.
Dec 19, 2009 | Hotpoint Ultima WF860 Front Load Washer
Every time I use my Zanussi Aquacycle, the water does not disperse from the washing powder drawer. This means I have to keep taking the drawer out, draining it off and putting it back before I use the...
It sounds as thiough the hose that lets the water into the drum from the dispenser is blocked with undesolved soap powder, you need to remove the top cover, and clear the blockage in the hose.
Please rate my solution.
Thanks.
Nov 09, 2009 | Washing Machines
Simpson brand dishwasher won't disperse detergent tablet
The soap dispenser drawer is supposed to open during the cycle. Try first to understand if the drawer is opening or not during cycle.
If the drawer is not opening, then check if the opening mechanism is stuck, if it is blocked by dirt and soap, if it is broken, or if something, for examble a basket too close to dispenser drawer is preventing the drawer from opening.
Some dishwasher works only with powder, in that case indications are given on the owners manual.
If the drawer opens and the table, or powder is still staying stuck in the drawer, then that means that the spray does not have enough power to solve the tablet.
In that case check spray arms and impeller pump.Also check water temperature.
If the problem is also happening with powder, then it is probably a drawer not opening on cycle.
Feb 18, 2009 | Dishwashers
Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Nov 07, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Dispensing tray is not opening at right time in cleaning cycle
unlikely to be dispensor opening at the wrong time. the powder is washed out by water squirting from angled jets at the end of the spray arm. check no blockage in spray arm - sometimes difficult to see. you may find also that the spray arms are not rotating for the same reason
Mar 21, 2008 | Neff 24 in. S5453X1 Built-in Dishwasher
Dishwashers Logo
351 people viewed this question
Top Westinghouse Dishwashers Experts
GPEC
Level 1 Expert
The GreyOne
The GreyOne
Tom Chichester
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
