Question about Vanguard International Blue Flame - Large Open Flame Mid-Size Heater
Heater makes my smoke detector go off.....
When I turn on the Vanguard propane heater in my living room, it makes my smoke dedector go off. I wonder why and what can I do about it?
  • the_griz2 Jan 18, 2009
    Thanks for the response!
    I appreciate it!
    New Friend:
  • 70 Answers
Gary, it sounds like the heater needs to be cleaned. Sounds like the heat exchanger is full of dirt bunny's.If you have a manual it will tell you how and what all needs cleaned. If you do not have manual i would call a heating/cooling repair company and have them come out and clean and inspect it. Then you can watch how the tech. does it then you will know how it is done if you want to do it next time. The heater should be cleaned every year they say but you might be able to go every other year
Posted on Jan 18, 2009
1st panel on Vanguard 22,000 btu ventless propane wall unit has overshooting flame causing strong exhaust-like odor in house. Has black residue coming out of top vents. No fan on this unit.Help!
good thing that you turned it off as it is now not operating as designed and that makes gas dangerous
call an accredited gas fitter to properly diagnosed the problem and repair/ replace it
Jan 01, 2017 | Vanguard Heating & Cooling
Problem is with my Rinnai propane gas heater in my LIVING ROOM, not car. Please see previous question. Thanks.
Turn it off. Check connections and hoses with very soapy water for leaks (it will bubble)
If you can't find it... I would either return it if possible... or go take it to a propane professional for testing.
Dec 20, 2012 | Rinnai Energy Saver Direct Vent Wall...
I have a vanguard propane wall heater, 5 burners Model#vp2600c that the two middle burners flame goes above the burners and now has started to burn through at the top, what all parts do i need to replace?
The burner and anything else that was damaged. You might want to get the advice of a local professional. Remember, this thing runs INSIDE your home, where you live, eat and sleep. You want it to be safe, my friend.
Thanks for your question at
Jan 06, 2010 | Vanguard International Blue Flame - Medium...
How do you shut down
the pilot light always stays on, its designed to allow your heater to turn on by itself without you needing to light a match every time. if the pilot light is burning you have nothing to worry about. its when the pilot light goes out that a small amount of gas leaks into the room. and by small i mean smaller than a hand held lighter... if you still want to shut the entire thing down you could turn off the gas line feeding the heater or possibly the whole house, otherwise the pilot light will stay on. as far as the actual heater turning off, thats probably controlled by some sort of thermostat somewhere. if you set the temp to very cold it should stay off. if that doesn't work then you may need a new thermostat.
Dec 31, 2009 | Vanguard International VN18B Infra-Red...
I turned my propane fireplace on and it set my smoke alarm off. We have lived here for three years and never had this problem before. Please advise.
check to see if the flame is pure blue. if not you have incomplete combustion letting CO or CO2 into the room. The flame will look yellow if this is the case. An orange flame indicates dust and dirt around the burner assembly. If it is yellow, the should be 1-2 set screws on the back of the burner assembly that will let you adjust the primary air being mixed with the propane.Adjust until you get blue flame and tighten set screws.
Dec 05, 2009 | Vanguard International Blue Flame - Large...
When the flame goes out, So does the pilot light
what kind of heater do you have? is is a vent less heater because if it is the main reason it would shut off is the ods(oxygen depletion sensor). make sure that the heater is not too big for the room. also purchase a carbon monoxide detector
Nov 06, 2009 | Vanguard International Blue Flame - Large...
Smokes up ceiling above heater and in room
sounds like it is dirt in burner causing air to fuel mixture problem needs to be serviced
Sep 04, 2009 | Dyna-Glo Heating & Cooling
1600c vanguard propane heater, big flame on middle grate
Make sure the grate is in the holder like the others, and nothing is blocking the bottom of it. They often slip back where the fire misses the inside where it should hit.
Dec 22, 2008 | Vanguard International Infra Red - Large...
Reddy heater model 28725
propane heater uses a hot surface ignitor. this operates off 120 volts and glows red/orange when actuated. it stays lit throughout the heater on operation.  on the backplate of the combustion chamber is a high limit with two wires coming off it.  these two wires connect to the spade connectors on the flame detector cappillary.  Once you establish a fire, the flame detector generates a 750 millivolt signal which is applied to the pilot/main valve assembly.  My diagram will show this. 1fa8284.jpg
Oct 12, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Vanguard International Blue Flame - Large Open Flame Mid-Size Heater Logo
1,675 people viewed this question
Top Vanguard Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Vanguard Heating and Cooling Expert? Answer questions, earn points and help others
