Question about RCA RTD160 System
RCA RTD160 Progressive scan activated now cant see screen to change it back , need to reset the system how do I do it. THe method of pushing the subwoofer button for 5 sec did not wok.
Try pushing and holding the subwoofer button again as I had the same problem and now it is resolved thanks to you
Posted on May 31, 2009
I AM ANGRY. I NEED TO HAVE MY PARENTAL CONTROL ON MY DIRECT TV BUNDLE CHANGED. MY CHILDREN HAVE THE CODE AND I CANT GRT INTO IT TO GHANGE IT. DONT SEND METO GOOGLE HUMOR IM NOT LAUGHING!!
When the receiver is on and the disc tray is opened, press SUBWOOFER for 5 seconds until the screen goes black, then the initial language selection menu will appear.
All system settings will be restored to default, the parental password will also be reset.
Dec 16, 2010 | RCA RTD160 System
About half way through a movie the picture stops and holds then continues on. sometimes it skips scenes when starts again . it seems that the progressive scanning quits (IMHO) and player starts over again...
It sounds like it's reacting to the layer change on the disc. It could be due to dust on the lazer, so would sugest cleaning it.
However if it has always done it, the player could be set up wrong, so may need to go to a proffessional/ service center.
Oct 12, 2009 | RCA RTD160 System
I have a HD TV with cable and a go video DVD/VHS player hooked up. I went to change the time and accidentally changed the setting on the DVD player from auto scan (I think) from off to on and now when I...
It sounds like you may have enabled the progressive scan output on your DVD-VHS combo. This is a correct setting if your TV support it. However most DVD players that support progressive scan will not support an interlaced signal and a progressive signal at the same time.
It would appear that you are using a composite type cable (3 RCA ends. 1 for video and 2 for audio) for this hook up. This means you have two choices.
#1 Look in the manual for the unit for the FACTORY Reset option. Its usually a combination of plugging the unit in while holding the power button or something similar to that. Without a model # I can't help any further with this option.
#2 Use a component video cable (3 RCA red/green/blue) to plug your DVD/VHS player into a compatible input on your HD TV. Your TV will pick up the progressive scan output from the unit and give you back your on screen display. At this point you can go back into the menu and disable progressive scan. And now just reverse the process to plug the DVD player back in using the composite cable.
It should be noted that if you have a progressive scan TV which HD TV's support you will get a better picture if you use the Component video cables instead of switching back to the composite cable. If you decide to use the component cables you will still need to run audio cables though.
Best of luck.
Trevor
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
Turned progressive scan on, can i turn it off without being able
Try these methods for resetting the scan on your dvd."To reset the VIDEO OUTPUT, turn Off the player, turn back On, open the disc tray and press and hold the Stop button on the player for 10 seconds to reset the scan mode." The Reset procedure doesn't seem to work on all versions but you can sometimes get a usable B&W picture allowing you to get to the menu and change the settings by connecting the composite video input of your display to the Red Pr/Cr or Green Y component output jacks on the rear of the cabinet.
You can also go into the Menu and set it blind with the following key presses on the Remote:
1. With the unit Stopped, press Setup.
2. Press Enter.
3. Press the Down Arrow 3 times.
4. Press the Right Arrow Once.
5. Press Enter. Hope this helps you with your problem
Apr 14, 2009 | Cyberhome CH-DVD 300 DVD Player
Showing red image
Make sure red is matched up to red, green to green, and blue to blue first. Then, try a different set of YPbPr (component) cables if you have a set available. If it still shows up red, then read this:
If you are using a Progressive Scan TV
(TV must indicate Progressive Scan or
ProScan capability), to activate TV
Progressive Scan, please refer to your TV
user manual. For DVD system Progressive
Scan function, see page 28.
Helpful Hint:
– If your TV does not support Progressive
Scan, you will not be ab le to view the picture.
Press and hold OPEN/CLOSE button and
press ‘1’ to deactivate progressive scan.
Progressive Scan - turning on/off
To select this item, you must set “Video
Output” to Y PR PB and ensure that your
TV has progressive scan (See page 11.)
Follow the steps of “Using the Setup
Menu” and select :
> PROGRESSIVE
OFF
ON
PROGRESSIVE SCAN OFF
TV SHAPE
TV SYSTEM
VIDEO OUT
PROGRESSIVE
SCR SAVER
SMART POWER
OFF
Select this to disable Progressive scan
function.
ON
These are pp. 11 and 28 of your owner's manual for the HTS
If these methods still fail, try turning your TV's progressive scan off or on.
-Tha Mp3 Doctor
Jan 08, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
How do you turn off the progressive scan
I own this model and do have the manual; however, standard AV and S-Video connections do not transfer progressive scan video images. If you hookup a progressive scan output to a non-progressive scan TV input, you will not get an image, so it is probably the way you have your machine connected to your TV that is the problem. If you are trying to watch regular TV through your machine, you will probably need to use a standard Coaxial Cable. I hope this helps.
Nov 03, 2007 | Avion AV-DVR100 DVD Recorder
Question on setup
If you set Progressive Scan to
ON in error, you must reset the DVD/VCR. First,
remove the disc in the DVD/VCR. Next, press STOP
and hold it for 5 seconds before releasing it.
Oct 18, 2007 | Sanyo DVW-7000 DVD Player/VCR
DVD player
unplug it and plug it back in and press the progressive button to turn it off, should work. Yeah that blue screen sucks, i would have thought you can get to the menu no matter what but that's sanyo for you, well most other brands also...
Jul 21, 2007 | Sanyo DVW-5000 DVD Player/VCR
RCA RTD160 System Logo
99 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
