Question about Maytag PAV2300 Top Load Washer
My washer was working fine and now does not go through the cycles
It seems like the switch possibly the timer? is not working. It does not go through the cycles. If you move tje switch manually it will go to the next cycle and drain. My model # is LAT9356AAE Maytag
  • 640 Answers
The timer is not advancing by its self...defective timer replace..onthejob
Posted on Jan 18, 2009
My Kenmore washer drains after the rinse cycle but won't spin at the end of it's cycle. If I manually set it to the spin cycle, it spins just fine. Desperate!!! The lid switch was just replaced about
Possible there is problem with the timer controller unit. It seems that the stepper motor is not moving to the next cycle until you manually move it to the spin. You can use some contact cleaners on the switch and also carefully try to see if the timer moves within , replacement is a costly issue and must be debated
Nov 20, 2013 | Washing Machines
Kenmore elite HE31 front loader will not start but has power
This seems to be a problem in the start switch diode. If all works fine, but will not push and start and all cycles seem to work when working it manually, this is in the switch timer electronic diode is not working properly. Sometimes a code will not come up, because cycles are still working when manually changing wash cycles. There is seperate switch or electronic trigger that starts the machine, and has probably worn out or not making good contact. If you can unplug machine and then take off panel, trying spraying behind start switch with electronic cleaner to free up any possible dust or dirt. Might get lucky.
Apr 07, 2012 | Kenmore Elite HE5t Washer
No voltage to water inlet valve, overfill switch seems ok and door switch seems ok. I am thinking the timer, but everything else seems to work fine is there something i am overlooking?
  1. Verify wire harness connections to inlet valves, pressure switch, flow meter, and Central Control Unit (CCU).
  2. Check all hoses for possible leaks.
  3. Plug in washer or reconnect power.
  4. Verify pressure switch operation.
  5. Verify flow meter operation by blowing air through the part and measuring the resistance.
  6. Verify CCU operation by running a Diagnostic test or any wash cycle.
5 & 6 above are the most likely culprits.
Oct 24, 2009 | Roper Dishwashers
Washer will not engage in final spin cycle.
the timer switch is defective...contacts that activate the final spin cycle is probably corroded or burnt up bad enough that it will not make good enough connection to activate the cycle....I usually take the timer switches apart to clean them but unless you know how to yourself, I suggest you just have the timer switch replaced
Aug 15, 2009 | Frigidaire GLTF2940F Front Load Washer
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Roper RAL6245AW0 Washer Won't Drain or Spin
We have a Kelvinator Washing Machine that just won't drain , but fills , agitates , & spins just fine. What shall we do?
Oct 13, 2008 | Washing Machines
Maytag LAT9706AAM Washer - Spin Cycle problems
If the timer is advancing but won't spin out, it is possible that the spin contacts inside the timer are faulty. A technician will normally isolate and confirm this diagnosis witth a special power cord hookup to the motor. From the way you describe your complaint, I feel that a timer would correct your problem.
Hope this advice is helpful!
May 27, 2008 | Maytag Dependable Care LAT9706
Washer won't drain
The switch located to the top which is activated by the lid is bad. replace that and your washer will be fine.
Feb 19, 2008 | GE Spacemaker WSLP1100D Top Load Washer
GE Washer wbsr3140d5ww water problem
Hello Chad
Welcome
Sounds like the cold water knob or switch is not switching and may be faulty.
I have a problem with my washer
For some reason when I try to start the washer and I have it set to cold it does not work if I put it to hot then its fine
The cold water does work though because if I change the washer to a later cycle cold water comes out just fine.
So it almost seems like its the timer knob
any ideas?
Thanks
Please remember to leave a rating
Jun 04, 2007 | GE WBSR3140D Top Load Washer
Asko w6221 front load washer stops after wash cycle
Do all of your cycles work when you turn them manually? If one cycle does not work when you turn the dial on it then it will be your timer (The dial assembly $100-up) If all your cycles work manually, then it could be your timer motor which is attached to your timer assembly. If you turn the dial pass the wash, on to the rinse, does the dial automaticly move (when finishng the rinse cycle)to the spin cycle? If so then your timer motor is ok. The only wires close to the bottom are the motor, but these should be high enough out of the way.
Apr 01, 2007 | Asko W6221 Front Load Washer
Maytag PAV2300 Top Load Washer Logo
200 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
