Question about HP PSC 1510 All-In-One InkJet Printer
Message of cartirdge is blocked (thus will not print doc) however
Upon checking I can see nothing impairing the travel of the cartridge, but the message continues to appear what should i do
  • 2 more comments
  • dc7830 Jan 17, 2009
    The message say's the print cartridge cradle cannot move. Does antone know how to solve this issue?
  • smjaslklda Jan 19, 2009
    identical problem - please notify with solution
  • rdunker7 Feb 08, 2009
    I keep getting warnings that the cradle cannot move. It's been doing it for 6 or more months and the printer was about a year old when it started happening. I have to move the cradle and sometimes it works but most of the time it takes a few times to work. It's frustrating. We figure it's best to just buy a new printer rather than getting this one fixed but we don't have any extra money to do either...
  • jhudgins93 Feb 25, 2009
    I have the same problem and it seems if I move the cartridge by hand it might work, but then it stops working after a while.
I think I corrected this for myself.
First of all check http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01370198&lc=en&dlc=sv&cc=se&product=3742502&lang=sv
Here are the steps that helped me:
  1. open front cover
  2. disconnect power
  3. move the cartridge to the left
Using a flashlight I saw a black shiny bump (about 1/2 inch height) below where the black cartridge normally rests. It almost looked like it was part of the printer, but when I got a screwdriver it came of easily as it was a hunk of leaked black ink. I had used a refilled cartridge and maybe this had something to do with it. After removing the mass of ink, everything is working great!
Posted on Feb 25, 2009
  • calcio Jan 08, 2011
    jhudgins93, IT WORKED!
    Just like you said it looks like its suppose to be there but it is just a big hunk of ink
    thanks
Unable to print . Message says ' Black cartirdge
Disconnect power for 5 minutes then power up to reset printer, make sure cartridge is secured properly. If it still happens, see my related solution on Error code #46.
sincerely
rover620
Sep 08, 2010 | Brother DCP-330C All-In-One InkJet Printer
Won't print black and white
This happend with some printer models that both cartirdge should be there for proper printing.in your case this may be due to that some printing you do may be in gray scale printing that type of printing use color cartridge for printing.thats why your color cartridge get consumed.so pls replace color cartridge or refiel it.
Aug 17, 2009 | Lexmark C530dn Laser Printer
I have put a new Cyan ink cartirdge in put it will not print
Make sure the cartridge is full y inserted if not will not print and it will aslo not display.
Aug 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Hp officejet 6110
If machine does not print the colors it cannot align. Try changing the color and try again
Apr 03, 2009 | HP OfficeJet 6110 All-In-One InkJet...
OFFICE JET 7410 PRINTER
Check the cartiridge if it is sitting nicely on its place. it seems you dint place the cartirdge properly
Apr 02, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Do I have to install a color cartirdge (CL-41)?
Some will allow printing with just black & others will not. You may need to put a color cartridge in to print. Check your owners manual or canon website to make sure but if you do need a color cartridge you can buy a generic brand that works with your printer to save some $$. Hope this helps.
Feb 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Hp 920c tech support
check your print cartridge has not plastic strip stuck on bottom side of it.
recoonect all connection then try.
Nov 24, 2008 | HP DeskJet 920c InkJet Printer
LEXMARK X5150 CARTRIDGE ERROR
Try this --
Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges
Nov 18, 2008 | Lexmark X5150 All-In-One InkJet Printer
Printer will not work after installing a new cartridge (name brand)
I put the original almost empty cartridge in again and printed one page. Then I took it out and put in the new one, after wiping the contacts with a piece of plain paper. it worked!
Feb 09, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Hp printer officejet 5510
To fix this problem, you need to go back to the store where you bought the new cartridge, they need to replace it. You have to make sure that you have the same label of the cartridge and have them test it if possible so you don't have to go back if needed.
Hope this helps!
Feb 03, 2008 | Office Equipment & Supplies
HP PSC 1510 All-In-One InkJet Printer Logo
571 people viewed this question
Seeker5211
Seeker5211
