Question about Timex T311T Clock Radio
Need operating instruction
I lost my instruction sheet and can't get the item to work. Can you tell me where can I get an instruction sheet?
  • 1 more comment
  • Anonymous Nov 09, 2007
    I also lost my instructions and need information on how to operate the alarm.
    thanks
  • pauldavid Nov 09, 2007
    I also lost my instructions and need help with the alarm.
    thanks
  • Anonymous Apr 06, 2008
    lost instruction
Operating Instructions can be found at http://www.timexaudio.com/pdf/T311IB57574_35.pdf
Posted on Jan 21, 2009
Go to http://www.timexaudio.com/support.asp and choose your model from the pull down menu.
Posted on Jul 01, 2007
SOURCE:
Guess I'm not too bright. Have a pack of GBC SelfsSeal Laminating Sheets, 9 x 12. Instructions say "Center item face sown on the clear non-adhesive." "Peel away the liner and...
It's not you, it's the instructions. They are just wrong and will not work as directed. However, I have found a way to use these sheets that works for me, but it is still not particulary easy.
Step 1) Lay the 1st sheet on a flat surface, adhesive side up. Pressing down on the small 1/2" strip of backing, peel away the large backing sheet exposing the adhesive. Holding the sheet you want to laminate face down and at an angle to the work surface, carefully align the material by "bumping" it up against the edge of the 1/2 strip. Once aligned, carefully and gradually lay the item onto the adhesive. Like I said, not particularly easy, but if you are careful, it will work.
Step 2) If you want to double laminate, which I usually do, the second laminate sheet seems easier to me. Leave the Step 1 laying flat on the work surface. Take a second lamination sheet and again, hold it down on a flat surface and peel away the large backing sheet, leaving the small 1/2" backing attached. Take this 2nd sheet and holding it over the 1st, face down and angled up from the work surface, align the 1/2" strips of both sheets together and again carefully lay the 2nd sheet over the first single-laminated item. The two 1/2" strips don't stick to one another allowing a bit more flexibility for alignment.
Press all of this together and work out any bubbles or wrinkles. Once that is done, pry the two sheets apart at the very edge to remove the two 1/2 strips.
Unless you are incredibly lucky the edges will never align 100%. I use a paper-cutter to trim off any irregularities after I finish laminating.
Apr 11, 2011 | Gbc Selfseal Letter-size Laminating Sheets...
TEVION TV does not work with a universal remote control
You will need to set the remote control to match the TV first. You can't just point and go...You will need the operating instructions for the remote control to be able to get the code for the TV, and the instruction sheet will also tell you how to set it. If you have lost the instructions, I suggest you chuck it, and buy a new one. They are very cheap these days. But before you decide which one to buy, check and make sure that it is suitable for your brand of TV...Please don't forget to rate this answer for me...
Feb 22, 2010 | Televison & Video
Lost instructions
wiilll u pls tell the whichh phone model. if it is nokia thn go to nokia site
Aug 12, 2009 | Cell Phones
I have the same problem, I called the company but they want to charge you $8.95 +S&H, said that I would figure it out on my on. But here is the number. 323-727-4240
Jun 23, 2008 | Teac SRL50 Clock Radio
Durabrand HVC-22
You can purchase items on Ebay cheap for these items and you can look on line and sometimes you can find a free download of a manual.
Apr 08, 2008 | Rainbow E series Canister Wet/Dry Vacuum
I dont know where to find an instructions booklet but I can help with setting the time/date:
To set the time and date (you have to do them both together):
  • First press and hold the 'CLOCK' button until it beeps then let go.
  • You will then be required to select the year by scrolling up or down with the 'TIME SET' rocker switch on the right hand side.
  • Once you have the right time, press the 'ENTER' button, to the right of the rocker switch once.
  • You will then be required to select the the month. Do this by once again using the 'TIME SET' rocker switch and then pressing 'ENTER'.
  • You will need to repeat this to select the date (day).
  • You then use this same process to select the time, starting with the hour and then the minute.
  • After you have finnished selecting the minute, press the 'ENTER' button once and then the set time, with the day in the top left corner will be shown. You do not need to press anything else. Your clock is now set.
REMEMBER to press the 'ENTER' button after selecting each thing to move you on to the next thing to set.
TIP; Beside the 'CLOCK' button there is a button which says 'D.S.T SUMMER T'. This is the button which automatically switches your clock from british summer time to winter time and back again. It means that you do not need to reset your clock every time. Make sure that it is in the right setting when you set the clock otherwise it could get confusing. You will know if it is on british summer time because a small sun with a clock face appears in the top right corner of the screen.
Good Luck x
Mar 16, 2008 | Sony ICF-C273 Clock Radio
Timex T311T Clock Radio Logo
712 people viewed this question
Top Timex Audio Players & Recorders Experts
Gyula Lacz
Steve Allison
Steve Allison
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
