Question about Amana ARSE66MB Side by Side Refrigerator
Compressor makes "clunking" noise when it turns off
Every once in a while the compressor on my 12 year old GE Profile side by side makes a clunking noise as it shuts off. Sometime you don't hear it for a week or two and then some days it clunks every half hour or so. Is this terminal?
  • Preble Feb 25, 2009
    IN have the same problem with my profile and wonder if it means it's goinf to quit soon.
No I did not get any replies on my GE Profile refrigerator problem. Your question said "Amana".
Posted on Jan 20, 2009
Hotpoint fridge makes clunk-clunk-clunk noise when it shuts off
You need a new compressor. Probably time for a new frig.
Nov 18, 2011 | Hotpoint Refrigerators
We have an 11 year old fisher-paykel fridge .For past 6 months several times a day it makes a loud knocking noise
If this noise happens when the compressor turns on and shuts off it is called a compressor knock. All the internal workings of the compressor are supported by springs, over time the springs wear out and become weak. When the compressor stops or starts the tourq causes the internal parts to hit aginst the casing of the compressor. Sounds like a clunk clunk clunk noise. If you can deal with the noise do not go out and replace the compressor cause it will work just fine like that.
Sep 01, 2011 | Refrigerators
Ge profile fridge tfh22pr. everthing is working ok, but when compressor shuts off a very loud clunk type noise is heard. happends amost evertime compressor runs. fridge is approx. 15 yrs old
Hello
The compressor, which is the heart of the sealed system, is that big black steel ball in the back of the unit. Inside is a little pump that is suspended by three or four springs. One of your springs is broken, and when the compressor shots off it bangs against the inside of that ball.
A replacement compressor is no longer available, and even if it were, the repair would cost would be too much to put into a 15 year old unit. ($600-700 min.)
There's no way to tell how long it will run. I've heard stories that ranged from days to years. This should give you time to do a little research on a new unit, and formulate a plan for immediate food transfer if it fails.
There are a lot of sources for the research, but I always suggest people call a couple of service centers that are factory authorized on several brands. You can usually catch a road tech in the shop shortly after opening time, and they will have an opinion to share. I favor the plain jane mechanical twist-the-knob thermostat vs electronics, no water/ice, thanks. But that's just me.
Also check the warranty. Most have gone to the one year and then you lose. Extended warranty?
More research there.
Hope this helps you out, and good luck.
fil
Mar 06, 2011 | GE Profile 21.6 cu. ft. Side-by-Side...
I have a 1995 24.5 cu. ft. GE Profile refrigerator. When it shuts off there is a loud clunk. I think it could be the compressor turning off. Other than that it seems to be working fine. Is this a serious...
The compressor is sitting on springs inside a metal case. When it stops, the centrifical force is absorbed by these springs. If one or more springs become weak or break, the compressor hits against the outer case a time or two. (CLUNK CLUNK clunk) There is really nothing you can do about it, short of replacing the compressor. (read big bucks) NOTE: If you take a new compressor and give it a shake, you will hear the same clunk. If the noise is really bothering you, I'd say after 15 years, it's time to move that refrig to the basement and get a new energy star model for your kitchen. (the old one most likely has several more years worth of clunking before it truely dies)
Sep 25, 2010 | GE Refrigerators
The GE Profile of 13 years old makes a loud bang sometimes a few times a day after running awhile -- does it mean it is the compressor and time for a new refrigerator or could it be something else -- we...
Good day,
If it makes the clunk or banging noise when the compressor is shutting off, then yes, internal spring or springs inside the compressor have broken.
Only solution to that problem is a new compressor.
P.S. these things can run a long time with this condition, but ultimately .....
Thank you for using FixYa
Dec 25, 2009 | GE Refrigerators
Frig shutters and makes noise when the cooling cycle shutoff.
It is probably caused from one or more of the four rubber bushings that mount your compressor to the refrigerator frame. The bushings wear over time and causing the compressor bracket to have a little play. Then when the compressor stops it moves the frame slightly bumping against the mounting bolt causing a slight to moderate sounding clunk when stopping, Also check a lines and cords as a cord refrigeration line near the compressor or fram can also cause the problem.
Oct 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
http://appliancepartsse.blogspot.com/
Aug 25, 2009 | GE Refrigerators
Clunking noise every 5 seconds
You should check the compressor compartment and see if the fan motor (if it has one) is hitting something. Possibly a dead mouse?( I have seen this before) Also check if compressor mounts are secure. Hope this helps.
Jul 28, 2009 | GE Profile PSI23NCR Side by Side...
Refrigerator makes a clunking noise when the compressor shuts off.
My GE Profile about 15 yrs old is also clunking.. fixed about 4 yr ago and doing it again.. Think the compressor motor is loss and when it shuts off it vibrates.. any other solutions please post if you had it fixed..
Dec 18, 2008 | Refrigerators
Amana ARSE66MB Side by Side Refrigerator Logo
851 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
