Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Intermittent loss of red color
I have a 5-year old Hitachi 57 inch rear-projection TV.  In recent weeks, we have episodes lasting a few minutes to hours in which the red colors are lost from the image.  Faces are green.  Blue colors are still normal. But there is no red.  The problem resolves on its own, but is getting more frequent.
  • regansmd Jan 21, 2009
    This is a rear-projection TV -- not DLP. Is there a separate red color tube? Can I replace this myself? Where can the part and instructions be obtained?
    Thank you.
    Genius:
  • 1,199 Answers
Yes there is a seprate color tube in your set! if you have electronic experence you can do it your self if not have a pro do it!
Posted on Jan 21, 2009
    Genius:
  • 2,920 Answers
Your red color tube is going out you need to replace it
Posted on Jan 17, 2009
  • Ronnie Houston Jan 21, 2009
    yes it has three tubes and the part can be ordered from any tv repair shop and it would come with instructions on how to change it out
54inch Hitachi TV has double figures and colors red, yellow-not normal. Set approximately seven -eight years old. Lost remote control and direction book in moving. Is the set worth getting fixed? Generally...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Hitachi 57F500 57" Rear Projection...
The color is screwed up
The projection TV has 3 color guns that focus to produce a single image. The 3 colors are red, green and blue. It sounds like the blue gun went out. You should be able to remove the back panel of the TV. If doing so, use caution as there is a mirror attached to the back panel. Once removed, you can confirm that the gun is not working. The fix, unfortunately is neither easy nor inexpensive. The problem could be simply a poor connection to the circuit board up to needing the replacement of a new light or perhaps a new gun. Unfortunately, there is no magic button to press and nothing you are doing wrong. This is a very nice TV and it may be worth getting an estimate to repair it. Or, perhaps this is a good excuse to go out and get a new 50" plasma! Hope this helps. If you can think of anything else I should know, please comment.
Apr 20, 2009 | Hitachi 57F500 57" Rear Projection...
Dark Color on TV. Can't adjust the color correctly
Having same problem now for a second time on a 57T500. First time was a bad green bulb that was covered under warranty. Only lasted 2 years....currently debating wether to fix or buy a new set. Bulbs cost about $300. Set is only 5 years old, so very dissapointed with quality.
Feb 01, 2009 | Hitachi 57F500 57" Rear Projection...
Hitachi loses color
you are losing one of your color tubes for it to be goiing to black and white.
Jan 27, 2009 | Toshiba 57H82 57" Rear Projection...
All color guns out of alignment
Needs convergence amps replaced. Sometimes resistors burn and need to be replaced. This repair requires soldering/desoldering equip. and a trained eye, but usually can be done for 175.00-325.00 at a reputable service center. Good luck, Russmann.
Nov 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Sony projection tv 5 years old
you will need to call an electronic repair shop to get this problem resolved
Oct 30, 2008 | Sony KP-57WV700 57" Rear Projection HDTV
Sony 57" rear prijection TV has a fast flashing light and will not turn on
turn on tv, after a few minutes picture goes black, but still have sound. red light blinks 5 times,turn set off same thing happens when you turn set back on. some times it want do it for 10 min.
Apr 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Color issues on my Hitachi 57 inch rear projection
Your convergence ICs need to be replaced. You can get replacements at the following link and they provide free tech support as well as installation instructions so you can do the repair yourself. It takes about 45 minutes from start to finish.
http://servicemanuals.vstore.ca/
Apr 11, 2008 | Televison & Video
SONY 57' HDTV color projection TV, red color dominance on-screen
these tv's have a problem with bad crt's you could try to replace the red but a better choice would be all three
Oct 22, 2007 | Sony KP-57WS500 57" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
46 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
