Question about Intel Motherboard
Continuous Long Beeps, No Video During Boot - GA-M61VME-S2 MB
I decided to upgrade my system. Home built GA-M61VME-S2 MB with a 700W ATX PS. 3.5Floppy is connected, IDE connector has the DVD and CD Drives. Ultra 133 PCI Card for my 120GB HD in the bottom slot. CPU is an AMD Anthlon 64.
I'm running Ubuntu 8.04LTS and added two 750GB SATA drives without any problems.
Here is where my problem is:
Old memory Kingston 1GB stick (KVR533D2N/1G). New memory is Kingston 4GB DDR2 PC2-6400 800MHz (KVR800D2K2/4GR).
Old video is on-board from the MB. New video is a GeForce 8600GT PCI Express, 512MB DDR2, 128bit.
When I boot the computer I get continuous long beeps (DRAM error?) and no video on the monitor.
I put the old memory back in, left it out, and get the same problem. I have taken the video card out and switched back to the on-board video with the same results. I have taken the CMOS battery out to reset the BIOS (will replace later today). I'll also start the gambit of taking the PCI card out and disconnecting the drives when I replace the battery.
Any ideas? TIA.
  • longbow32198 Jan 18, 2009
    It’s fixed, WOOHOO!
    Here’s how I did it: I put the 1GB stick in memory slot #2 (DDRII_2) with everything disconnected/removed. The motherboard reset itself. Video came back, one short beep during power-up, and the computer whined about nothing connected.
    I did change the CMOS battery. That most likely didn’t have anything to do with my problem. The remove/install drives and cards made no difference before installing the 1GB stick in slot #2.
    After the reset I put each component back in one at a time, rebooting without any further errors or problems.
    Both solutions fixed the problem. THANKS!
  • 741 Answers
You don't need to take it apart the long beeps are corrupted RAM. Either it was zapped with Static electricity or your motherboard is frying your RAM or it is not seated properly. I have seen this problem before, where the motherboard is frying the RAM cause it is getting to much electricity. You'll need one more new RAM stick, and install it with nothing else, no PCI cards, no cd rom. You just want to get past boot until you get the single beep. Then add one card back at a time until you find the problem. Or you can do the reverse, leave the RAM in, and take one piece of hardware out at a time, reboot, until you find what is causing the problem.
Don't forget to rate this solution before you log out.
Posted on Jan 17, 2009
  • 98 Answers
Hi.
Continuous long beeps indicate memory fault. You can try and put your memory in each of the slots. After all, maybe memory slot is faulty, not the memory itself. Clean the slots with a brush and try again. There is no need to remove PCI expansion cards nor any other hardware. If the beeps continue even with memory that you are sure is working, then it is a motherboard problem. You also tried resetting the BIOS and that's good solution. Hope it helps.
Your responses are intended to improve the level of service provided. Please rate your experience.
GA-EP41-UD3L problem with SCSI/IDE
Sounds like the motherboard bios is only capable of booting from drives connected to the motherboard's ide connector and not additional / or external ide connectors. Looks like you would have to have 1 HDD and the CDRom Drive on the built in ide connector and the other hard drive on the extra ide connector you added. Although that would probably stop the other HDD from booting. Have you thought about putting both operating systems on the same drive. I do it all the time.
Feb 11, 2012 | Computers & Internet
Gigabyte GA-965GM-S2 motherboard keyboard, mouse, monitor won't work.
You need all the drivers, each peripheral has it's own driver that needs to be loaded.
Nov 28, 2011 | Gigabyte GA-965GM-S2 Motherboard
I have a GF615M-P33V2 - how can I get Windows Server 2003 drivers and software? Also, IDE CD/DVD only work intermittently. Is there any way I can connect a CD, DVD and a floppy. I've already an IDE HD...
Hi, the download site is here:
http://www.msi.com/product/mb/GF615M-P33.html#/?div=Driver&os=All
But there is no drivers for windows 2003.
The 32 bit driver for windows xp will sometimes work
if it is a 32 bit system.
You can buy an external floppy drive and a cd/dvd drive to
connect the usb.
But the mainboard has a connector for the floppy drive.
Try to install the chipset drivers first and unzip the file before installation.
Consider to buy a mainboard compatible with windows server 2003
I will recomend a ASUS mainboard.
Sep 17, 2011 | MSI GF615M-P31 AM3 NVIDIA GeForce 6150SE &...
I am having one long beep and two short beeps on my gigabyte m61pme-s2 motherboard when i try to boot up...
That is an error code for the video card / device.
Turn off and unplug the computer.
If possible remove and reinsert the video card.
if you have a shared video ( connected permanently attached ) remove and reinsert the memory chips.
Aug 30, 2011 | Gigabyte GA-M61PME-S2 Motherboard, AM2,...
There are five capacitors next to the CPU cooling assembly on my Gigabyte GA-M61VME-S2 motherboard. One is leaking and two are bulging. Can these bad capacitors be replaced or do I need to replace the...
Hi,#
Yes they can be replaced if you were thinking of doing it yourself, desoldering the old ones is the hard bit, however if you were looking to get someone to do it for you I suspect the price may well go at least around the same price as simply replacing the board as its available
http://www.kikatek.com/product_info.php?products_id=37836&source=froogle
£37 (around $50 if your stateside)
Jul 11, 2011 | Gigabyte Motherboard, GA-M61VME-S2 + AMD...
What is the specification for my GA-K8N Pro motherboard?
CPU
  • Socket 939 AMD Athlon™ 64 X2 / Athlon™ 64 FX / Athlon™ 64
Chipset
  • NVIDIA nForce4 SLI MCPs (media and communication processors)
  • Super I/O: ITE IT8712
  • CICADA VSC 8201 Gigabit LAN PHY
  • T.I. IEEE1394b
  • AC'97 Realtek ALC850
Memory
  • Dual channel DDR 400 / 333 / 266 184pin
  • 4 x DIMM slots up to 4GB
Expansion Slots
  • 2 x PCI Express x1
  • 2 x PCI Express x16, supports two PCI Express interface Graphics cards with SLI mode
  • 2 x PCI slot (PCI 2.3 compliant)
Internal I/O Connectors
  • 1 x CD in
  • 1 x FDD
  • 2 x IEEE 1394b (supports 3 ports)
  • 2 x UDMA ATA 133/100/66 Bus Master IDE
  • 3 x cooling fan pin headers
  • 3 x USB 2.0/1.1 (support 6 ports)
  • 4 x SATA II 3Gb/s
Back Panel Connectors
  • 1 x COM
  • 1 x LPT
  • 1 x RJ45 LAN
  • 2 x USB 2.0/1.1
  • 6 x audio ports (Line In / Line Out / MIC In / Surround Speaker Out(Rear Speaker Out) / Center/Subwoofer Speaker Out / Side Speaker Out)
  • Coaxial SPDIF input/output function
  • PS/2 (Keyboard/Mouse)
H/W Monitoring
  • H/W detecting and reporting for case open, CPU voltage and fan speed
  • System health status auto-detect and report by BIOS
BIOS
  • 2 x 4 Mbit flash ROM
  • Award BIOS
CPU/AGP/DIMM setting
  • CPU HT / Multiplier / Vcore Voltage adjustable via BIOS
  • DIMM Voltage / Clock adjustable via BIOS
  • PCI-ExpessX16 Voltage / Clock adjustable via BIOS
Unique Features
  • @BIOS™
  • Download Center
  • NVIDIA Firewall
  • NVIDIA SLI multi-GPU support
  • Q-Flash™
  • Xpress™ Install
  • Xpress™ Recovery
Bundle Software
  • Norton Internet Security™
Power
  • ATX power connector and ATX 12V connector
  • Power-off by Windows 98/Me/2000/XP shut down and switch
Form Factor
  • ATX
  • 305mm x 244mm
Remark
  • Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website
  • This product does not support Win9X/ME, due to most hardware/software vendors no longer offer support for Win9X/ME. However we still offer available related drivers to serve our customers.
Jan 08, 2011 | Gigabyte GA-K8N Pro-SLI Motherboard
Can Vantec CB-IS100 IDE to SATA converter works to convert Motherboard ide port to sata or it made only for hard drives,cd-roms and DVD rom ?
It attaches directly to the drive, whether it be IDE hard disk or CD/DVD, and is used in boxes that already have sata connectors on the MB. Connector attaches to drive, cable from connector attached to drive to sata connection on MB.
Note: Sometimes these may not work (for a variety of different reasons).
Here is a link to one seller of the converter, read through the reviews. While it works well for most, sometimes there are issues.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812232004
Dec 26, 2010 | Vantec CB-IS100 IDE to SATA converter IDE...
I lost my MOBO driver can you help me find one
You can download the drivers from Gigabyte WEB support site, select your model motherboard to download :-
http://www.gigabyte.com.tw/support-downloads/support-downloads.aspx
Sep 14, 2010 | Gigabyte GA-M61VME-S2 Motherboard
What is fastest cpu I can put into a GA M61SMES2
this 1 was a hard 1..... took me all of 10 minutes
AMD Athlon 64 FX / Athlon 64 X2 Dual-Core / Athlon 64 / Sempron processor
your manual can be found here http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Jul 16, 2010 | Gigabyte GA-M61VME-S2 Motherboard
My Gigabyte GA-945GZM-S2 motherboard is not detecting any CD/DVDROM attached to the ide port. it is also not detecting the rom in bios. cable and rom ate both working fine there have been tested on other...
IF THERE IS ANOTHER IDE PORT FOR A SECONDARY DRIVE i WOULD TRY TO SWITCH OVER TO IT . IF NOT THE MOBO MAY HAVE A PROBLEM WITH THE IDE PORT. VEIRFIED THAT THE DRIVES ARE CORRECT AND TRY TO CHANGE THE BOOT ORDER IN BIOS .
May 15, 2010 | Gigabyte GA-945GZM-S2 Motherboard
Intel Motherboard Logo
879 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
