Question about Epson Aculaser C1100 Printer
A stripe all the way down the page
The stripe runs from top to bottom. It appears on all pages whatever is being printed. I've cleaned using the side pull out cleaner with no improvement.
  • nrum Jan 24, 2009
    So do you need to replace the drum unit?
    Genius:
  • 2,120 Answers
You probably have a bad cleaning blade inside of the drum unit
Posted on Jan 17, 2009
I am getting a blank stripe top to bottom on every printed page
You write "I am getting a blank stripe top to bottom on every printed page". You didn't say copy or scanned pages. Change the toner cartridge.
Feb 04, 2011 | HP LaserJet 3050 All-In-One Printer
Lines on print. There's are three lines on picture print only. Can't see the line on document. It's about 1/4 inch wide and going throught top to bottom.
Have ou gone into your menus. Into troubleshooting, then image quality.
You will want to run both the eliminate light stripes and eliminate smears procedures. that will purge the print head, blow air through the jets and hopefully resolve the problem. I do believe the 8550 has a Jet Substitutin procedure where you can do a workaround and make other jets make up for the light areas.
here are some directions, Will forward more
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Troubleshooting Print Quality Page], and then press the [OK] button.
  4. Evaluate the 'Light Stripes Test' page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. The 'Light Stripes Test' page is the last page of the Troubleshooting Print Quality Page that printed.
    WARNING: To avoid injury, do not touch the sharp metal strip attached to the clear rubber wiper blade in the Maintenance Kit.
  5. Use a clean lint-free cloth or a new paper coffee filter to gently clean the maintenance unit's clear rubber wiper blade, use only a wiping motion across the entire length of the wiper blade, and then empty the waste tray. A dirty maintenance kit wiper blade can cause white lines and weak or missing printhead jets.
  7. Repeat step 3 to reprint the Troubleshooting Print Quality Pages. If there are no missing or partially missing color bars then the print quality problem has been resolved. If there are missing or partially missing color bars then the printhead cleaning procedure will need to be performed. Continue with the next section.
To clean the printhead using the basic eliminate light stripes procedure:
  3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Basic], and then press the [OK] button. The printer will perform a head cleaning, which will take about five minutes. The printer will then print a cleaning page and a light stripes test page.
  5. Repeat steps 1 - 4 one more time. If there are no weak or missing jets then the print quality problem has been resolved. If there are still weak or missing jets after two basic light stripe cleanings, continue with step 6.
    NOTE: Do not try the Advanced Eliminate Light Stripes Cleaning mode without performing two basic cleanings first.
    To clean the printhead using the advanced eliminate light stripes procedure:
  6. Press the [Up] or [Down] arrow button to select [Advanced], and then press the [OK] button.
  7. Select the missing jet color and number. If necessary, check the light stripes test page to determine the color and jet number of the missing jet.
    NOTE: Only perform the advanced light stripe cleaning once. If weak or missing jets still persist, continue with step 8.
  8. Print the Troubleshooting Print Quality Page. Evaluate the Light Stripes Test page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. If necessary, perform the basic eliminate light stripes procedure one more time. If the Advanced Eliminate Light Stripes procedure does not resolve the weak or missing jets, perform the Enable Jet Substitution Mode. See the Related Items below.
Feb 05, 2010 | Xerox Phaser 8550DP Printer
Cannon multipass F60 scanner/printer striped color printing
What you have is a dried up color cartridge. You can try to use the <clean print heads> in the diagnostic tools section of you priner software. (usually, just try to print something & the window will appear) Sometimes you have to clean heads, then print test page like 2 or 3 times before it clears up. If that doesn't correct it, don't worry. Have your color cartridge filled (staples, office depot, & other stores do it cheap) - or - replace it with a new cartridge. You may have to run the clean print heads program after installing a new cartridge, but this will definitely fix your problem.
Jul 26, 2009 | Canon PIXMA MX850 multifunction InkJet...
I changed the black toner cartidge for the first time and immediately got a multicolored stripe all the way across from top to bottom on the middle of the right side of the page. I replaced the toner
Vertical streaks or bands appear on the page.
One or more print cartridges might be low or defective. If you are using non-HP print cartridges, no messages appear on the device control panel or in the HP Toolbox. Replace any low print cartridges
Marks repeatedly appear at even intervals on the unprinted side of the page.
Internal parts might have toner on them. The problem typically corrects itself after a few more pages. The paper path might need cleaning. Clean the device. The fuser might be damaged or dirty. Clean using instructions in HP Toolbox.
Contact HP Customer Care.
Read this HP document:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=446153&prodTypeId=18972&prodSeriesId=446153&objectID=c00316826
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 25, 2009 | Office Equipment & Supplies
Pages printing blank
Resolving white, light lines or streaks (eliminate light stripes)
From the printer, print the Troubleshooting Print Quality Pages.
With Troubleshooting highlighted, press the OK button.
Scroll to Print Quality Problems by pressing the Up or Down Arrow button. Press OK.
Scroll to Troubleshooting Print Quality Page. Press OK.
Evaluate the Light Stripes Test page for missing printhead jets (missing cyan, magenta, yellow or black color bars).
Clean the maintenance unit's wiper blade and empty the waste tray. A dirty maintenance drawer wiper blade can cause white lines and weak or missing printhead jets. Using a clean lint-free cloth or a paper coffee filter, gently clean the blade with a wiping motion across the entire length of the wiper blade.
Dec 20, 2008 | Xerox Phaser 8400 Laser Printer
Why does minolta copier print white stripes?
TRY TO CLEAN AND CHECK MAIN CHARGER AND TRANSFER CORONA FOR VOLTAGE LEAKAGE,AND CHECK DEVELOPER GEAR AND DEVELOPER DRIVE GEAR
Dec 03, 2008 | Minolta EP1030/1030F CS/PRO Copier
Printing quality suddenly deteriorated
You could have printhead problems but I would offer that you do a deep clean and consider replacing cartridges with OEM
Nov 13, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
PIXMA Ip4000
I assume you're using photo paper.
Go to File/Print. Click Properties. Click Media Type and chose the photo paper you are using, whether it's Photo Paper Pro or whatever. If you're printing using Plain paper and you have photo paper in the printer, you'll get the stripes.
Hope that helps
Oct 22, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Sqeaky paper feed
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=238800&prodTypeId=18972&objectID=c00001617 the HP site for your printer Over time, particles of toner and paper accumulate inside the HP LaserJet 2300 series printer. This can cause print-quality problems during printing. Cleaning the printer eliminates or reduces these problems. Clean the paper path and print-cartridge areas every time that the print cartridge is changed or whenever print-quality problems occur. As much as possible, keep the printer from dust and debris. Cleaning the outsideback to top of page Clean the outside of the printer with a cloth that has been dampened with water. NOTE: Do not use ammonia-based cleaners on or around the printer. Cleaning the paper path and print-cartridge areasback to top of page Over time, particles of toner and paper accumulate inside the printer. This can cause print-quality problems during printing. Cleaning the printer eliminates or reduces these problems. Use the following steps to clean the paper path and print-cartridge areas: 1. Turn the printer off and unplug the power cord. 2. Open the top cover. Figure 1: Top cover opened example 3. Remove the print cartridge. Figure 2: Print cartridge removed example CAUTION: To prevent damage to the print cartridge, do not expose it to light for more than a few minutes.Be careful not to touch the transfer roller (the black, rubber roller located underneath the print cartridge). Skin oils on the roller can cause print-quality problems. 4. With a dry, lint-free cloth, wipe any residue from the paper path area and the print cartridge cavity. Make sure not to touch the transfer roller with fingers, as the oil can contaminate the roller, resulting in print quality defects. Figure 3: Paper path area and print cartridge cavity example 5. Reinstall the print cartridge and close the top cover. Figure 4: Print cartridge reinstalled example NOTE: If the print cartridge is difficult to reinstall, make sure that the registration plate has been flipped back down into position and that the print cartridge is pushed firmly in place. 6. Plug in the power cable and turn on the printer. Cleaning the fuserback to top of page Run the printer cleaning page to keep the fuser free of toner and paper particles that can sometimes accumulate. Accumulation of toner and particles can cause specks to appear on the front or back side of print jobs. To ensure optimum print quality, HP recommends using the cleaning page every time that the print cartridge is replaced or on an automatic pre-established interval. The cleaning procedure takes about 2.5 minutes to complete. A message (either CREATING CLEANING PAGE or CLEANING) appears on the printer control panel display while the cleaning is taking place. NOTE: Use plain paper to print the cleaning page. Please note that this is a two-step process. First print out the cleaning page using the following directions, then follow the directions on the cleaning page itself to reinsert it back into the printer to perform the cleaning. Use the following steps to run the cleaning page: 1. If the printer model includes a duplexer, open the rear output bin. 2. Press example(Select button) to open the menus. 3. Use example (Up button) or example (Down button) to scroll to CONFIGURE DEVICE, and then press example (Select button). 4. Use example (Up button) or example (Down button) to scroll to PRINT QUALITY, and then press example (Select button). 5. Use example (Up button) or example (Down button) to scroll to CREATE CLEANING PAGE, and then press example (Select button). 6. Perform the following to complete the cleaning process. 1. Remove all paper from Tray 1. 2. Use example (Up button) or example (Down button) to scroll to CONFIGURE DEVICE and then press example (Select button). 3. Use example (Up button) or example (Down button) to scroll to PRINT QUALITY and then press example (Select button). 4. Use example (Up button) or example (Down button) to scroll to PROCESS CLEANING PAGE and then press example (Select button). 5. Load the cleaning page created in step 5 above into Tray 1 with the print side down and the arrow towards the printer. 7. If the printer model includes a duplexer, close the rear output bin. Let me know if that helped. Good luck, Tim
Mar 14, 2007 | HP LaserJet 2300 Printer
Epson Aculaser C1100 Printer Logo
146 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
