Question about NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614)
Installation cd missing for wireless router
Hi. i am using a netgear wireless router. however, i do not have the installation cd. once i plug in the router, it prompts me for a password (no username, just a password). this password is usually generated by the cd software. how can i use my router without the installation cd?
thank you
  • kh_bilaltari Jan 17, 2009
    i have tried this. however, after resetting the router, my laptop does not recognize any network.
    the router seems to be working, but since i resetted it, there is some issue.
    i have tried all the basic things, resetting it again, rebooting the laptop, checking all connections.
    kindly assist .thank you.
  • 258 Answers
You do not need the disk
While it is powered up look for the reset button on the back and put a pencil or other non-metallic onto the button and hold it in for 10 seconds
It will reset and set the username to "admin" and the password to "password" or "admin"
If this does not work do not put in a username but enter "admin" for the password
You can then use the setup wizard to connect the internet broadband
Posted on Jan 17, 2009
  • Peter Conway Jan 17, 2009
    Have you tried connecting with a network cable direct to the router???
I have a netgear wna3100 wireless adapter and have been trying to install it. I have ran the netgear CD that came with the package, but once it gets to the stage of detecting adapter and I plug in the...
You can manually access the routher by typing 192.168.1.1 into the web browser once it has connected to the internet. You then can set up wireless access points and set a WEP, etc for security. This would also allow your adaptor to connect to the router once you have set everything up. The default username and pass for routers is usally: User: admin ...password: password
Please accept if this has helped you!
Mar 03, 2011 | Computers & Internet
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
I can't find my CD to set up the router. I have cable internet modem set up and working fine. I can't locate free driver download without getting stuck in a "free" service that charges for...
I found the below information at Netgears website http://kb.netgear.com/app/products/model/a_id/2590.
I hope it is helpful,
Shawn
Lost or Unable to use Router Configuration CD NETGEAR does not replace lost or broken CDs because the Smart Wizard installation and configuration utility on the CD is already built into your router management software. There is no need to download anything to replace the CD - everything you need is in your router. This is true even if:
  • the CD that shipped with the router has been lost or cannot be read, or
  • errors occur when running the configuration program, or
  • the router is not connected to a computer using the Windows operating system.
To access the Smart Wizard installation and configuration program on your router:
  1. Connect your router to a computer by plugging one end of an Ethernet Cable into any of the four LAN ports on the back of your router.
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. To install your router, simply click on the "Setup Wizard" link at the top of the left-hand navigation menu once you are logged into your router.
A video walk-through of installing and configuring your router using the Smart Wizard is available at http://kb.netgear.com/app/answers/detail/a_id/12873.
Jan 29, 2011 | NetGear WGR614 Wireless Router
Dont know how to install a password so other wireless computers cant log on I have a netgear WGT624
Hi dude check this would be useful
http://kbserver.netgear.com/pdf/wgt624v3_ref_manual_25Apr05.pdf
Things You'll Need:
  • Ethernet cable
  • Cable or DSL modem
  • WGT624 Installation CD
  1. 1 Plug the Netgear WGT624's AC adapter into a wall outlet. Plug an Ethernet cable into the yellow Ethernet port on the back of the Netgear router. Attach the other end of the cable to the Ethernet port on the back of your modem.
  2. 2 Insert the installation CD that was included with the Netgear WGT624 into your computer's disc drive. Click the language option you want to use and then click "Setup."
  3. 3 Follow the setup wizard's onscreen instructions and then click "Finish." The wizard will automatically detect your Internet settings. Open a web browser and navigate to "http://192.168.1.1."
  4. 4 Type "admin" in the Netgear's "User Name" text box and then enter "Password" in the text box labeled "Password." Click "OK."
  5. 5 Click "Yes" and wait for the latest firmware upgrade to install. Double-click the upgrade file and follow the onscreen instructions to install the upgrade.
  6. 6 Click the "Wireless Settings" link if you want to password protect your wireless network. Click the "WEP" radio button and then type in the password you want to use for your network in the "Passphrase" text box.
  7. 7 Click "Apply" and then close the web browser.
Sep 27, 2010 | NetGear WGT624 Wireless Router
Lost aol start up cd for my router
Sep 26, 2010 | NetGear DG834G Wireless Router
Hi there, where could I get a setup cd for netgear WGR614 router?
You don't really need the CD.
Use an Ethernet cable to connect your computer to one of the LAN ports on the router.
Connect from your web-browser to the web-server "inside" the router.
If it asks for ID or for password, try a "blank", or try 'admin'.
Once connected, you can run a "Wizard" to configure your wireless network, i.e., pick an SSID, and pick a password or pass-phrase, and enable encryption.
Apr 08, 2010 | NetGear WGR614 Wireless Router
I connected my new netgear as per the cd, and now it's not going into wireless mode, I still have to plug my ethernet into the computer to get networking... None of the DSL, Internet or Wireless lights...
you have a modem /router setting page if you ring your isp give them your model number they will tell you how to check your router settings it will load up in internet explorer for you 2 veiw
Aug 04, 2009 | NetGear DG834G Router
I need to download the netgear g wireless cd to install ity on an
Netgear provides all images. Just scroll down the page until you find what you need.
http://kbserver.netgear.com/kb_web_files/n101649.asp
use the manual listed below and follow the instructions
http://kbserver.netgear.com/pdf/wgr614v6_ref_man_20Apr05.pdf
Chris (ziraffa)
Dec 25, 2008 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
How to install with out the cd?
Are you using XP? You shouldn't need the CD.
http://www.netgear.com/Home/Products/Adapters/GWirelessAdapters/WG111.aspx
Gives you information about the USB adapter.
http://www.netgear.com/Products/RoutersandGateways/GWirelessRouters/WGR614.aspx
That gives you information about your wireless router.
Do you need a manual to set this up? It looks like there are different version of this wireless router. Which one do you have? This can be identified on the package or the unit's bottom label.
Once we know which version you have we can continue.
Dec 11, 2007 | NetGear WGR614 Wireless Router
NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614) Logo
161 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Brian Sullivan
Brian Sullivan
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
