Question about Pyle PLTS76U Car DVD Player
Plts76u started showing split screen. 2 of the same picture.
Hit reset. and unpluged fron wiring harness . did not fix problem. does it on dvd and radio screen. both little screens have solid white border around them
  • shacks_jean Mar 15, 2009
    yes i have the same problem pyle plts76u started showing split screen 2 of the same picture can some one help me
    Problem Solver:
To solve this problem go to the dvd preference page set up scroll down to defalt by using the remote control press enter on the remote and the system will reset to factory settinn
Posted on Mar 15, 2009
No videp playback on Pioneer AVH-P4000DVD only getting sound !!!
Just wanted to add my 2 cents for those who might be having the issue of no video but hear audio. I was having the same problem. I had completed the bypass hack with a single throw/single pole (SPST) toggle switch. I could bypass the warning message and hit the OK button but no video. I did hear audio. I searched everywhere but solution 4 worked for me. The thing for me was that next to the black wire on the harness wasn't empty. It had a purple/white wire with some sort of filter (labeled backup camera hook to reverse gear). I tied into this wire before the filter with another wire (I chose a black wire b/c I was grounding it) and grounded it with the black wire (ground) on the harness. I now have video! Maybe the 4 pole relay hack would have worked better but I had only done the toggle switch hack. I hope this helps others and most importantly thank you Salhi.
Mar 26, 2009 | Pioneer AVH-P4000DVD Monitor
Black and white
Unplug the home theater for about 2 minutes, and see if the default color has been reset once you replug it.
Mar 23, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
Pyle plts76u shows split screens how can i solve thi roblem
I wired my parking bake(brown wire) to the ground wire(black wire), and it allowed me to drive with the screem up
Mar 15, 2009 | Pyle PLTS76U Car DVD Player
How to drive with dvd playing PLTS76U
eASY... CONNECT THE BROWN BRAKE WIRE TO ANY GROUND IN THE VEHICLE....
Feb 12, 2009 | Pyle PLTS76U Car DVD Player
I doesn't work
gound pink wire in order to make video play
CONNECTING AN AMP
Amp is powered by a main power wire to the battery, ground to metal chassis, and a remote wire (usually blue) from the D player to the remote in on amp. RCA's from CD player to amp as well. Not sure what you mean by "no amp wire on harness". Let me know so I can give you a more definitive answer.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 24, 2009 | Pyle PLTS76U Car DVD Player
Pyle override park brake code
You can run the brown wire to a ground and that should work for you. Would you happen to know the importance of the pink wire?
Dec 30, 2008 | Pyle PLTS76U Car DVD Player
Diconected cable found please reconect black screen white lettering
check the harness at the back of the radio and check power to it sounds like a fuse or something
Aug 15, 2008 | Kenwood Excelon KVT815DVD Car DVD Player
JVC DVD player stuck in Split screen
the player is set to progressive scan mode.use relevant button on remote to reset to interlace mode. Duane,S/Africa
Mar 11, 2007 | JVC XV-N320 DVD Player
No picture but has sound
Hi If your t.v.has built-in blue screen when there is no signal, then the DVD may have been accidentally switched to progressive scan mode, or defaults to that setting if new. If your T.V. is not capable of displaying in progressive scan mode, you will just get a blue screen. If you have an older tv, without blue screen, then connect it to that, and if you get a black and white split screen when you turn on the DVD, then progressive scan is the problem. Check the manual for the DVD player for the procedure to get out of that mode, and it should then work. If you still have no video, and you are using the yellow composite video jack on the back of your DVD player, then it must be brought in for service. Good Luck!
Aug 14, 2006 | Zenith DVB312 DVD Player
Pyle PLTS76U Car DVD Player Logo
182 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
