Question about Microsoft Sony VAIO 3544501 Notebook
Sony Vaio Micro Cmputer Back Screen with lines at Startup
I turned on my computer for the first time in two months and it gave me a black screen on the left side and color vertical lines on the other. I can hear it operating and booting up but can not see anything but the black and color vertical lines..What is happening, The only way to power it off was to remove battery. I have n't used it much but I just loaded itunes on it. Ihope its a simple fix.....HELP!
    Problem Solver:
  • 15 Answers
Either of 2 things.
1. The ribbon cable that connects the screen to the board may have become loose. If you have tools it should be a quick fix.
2. The screen is smashed.
Posted on Jan 24, 2009
My Sony Vaio VGN SR26GN has a black screen when I turn it on.
Your video may be dead. If you have a VGA port or HDMI connector in the back, try connecting it to an external monitor or TV.
Oct 14, 2012 | Sony VGN Computers & Internet
When I startup my Sony Vaio Netbook, it boots slowly, but never gets to the startup screen. The screen is black with the cursor being the only thing showing (meaning that the screen my be fine). When I...
reboot the system, wait for the VAIO logo to appear, and then start pressing F8(keys depends on the model ) . The Advanced Boot Options screen will appear shortly. Use the arrow keys to highlight the “Repair Your Computer” option and press Enter.
Oct 15, 2017 | Sony Vaio P VGN-P530H Netbook
I have a Vaio PCV-W20, and a few months ago the screen went black. The problem is that now I only get a visible screen for a few seconds and it goes black again. For example this is what I see when the...
Ok try this, at boot up press F8, when the Menu comes up, choose Safe Mode, but this time instead of going to the desktop, choose System Restore, follow instructions, and when the Calender type window comes up, simply choose a time BEFORE, the time it went faulty. This should completely restore you to working again. As long as there are NO other problems. -
Jul 21, 2010 | Sony VAIO PCV-W20 PC Desktop
Black screen with curser
It is what is called the "Black Screen of Death (BlSod)/(KSOD)" if you are using Vista or the later Windows 7. There are many causes for the BiSod/KSOD... some may say it is due to Micro**** updates and patches or as what Micro**** claims that is is due to malware infection, most likely something from the Daonol family of Trojans.
Google for it or I'll share you this site to give you some insights of the BiSod/KSOD.
here's one of many you could read:
For a fix you may follow these steps:
After the black screen with cursor appears, press the shift key several times (5 to 10 times). A window should appear that reads “Go to the Ease of Access Center to disable the keyboard shortcut.” Click on that item, then follow these instructions:
  1. In the explorer window that appears, clear the address entry and type MSCONFIG then press enter. Run MSCONFIG.
  2. Uncheck the two items in selective startup and press apply, then restart the computer.
  3. The computer should start normally. Now click the Start button and type MSCONFIG again, then press enter. Uncheck Windows Event Log and Windows Event Collector, then restart the system.
This may or may not work on your state but your last resort is to extract your hard drive and back-up to another unit before re-installing your OS.
Hope this helps. Don't forget to rate.
Jan 06, 2010 | Sony VAIO PCG-K35 Notebook
Problem with Sony Vaio pcv-rx860 (screen goes black at startup)
I would suggest first to try to take one stick of memory out and try to boot up the pc. Sometimes, one or both of the memory sticks can go bad or the memory slot on the motherboard itself can go bad. If that is not the case I would then remove all of the usb connected to the computer and last i would test the power supply.
Apr 16, 2009 | Sony VAIO Digital Studio PCV-RX860 PC...
Cannot start Sony VAIO PCG-5J2L /Goes to black screen only
During start-up the computer will go to a black screen for awhile and then the pointer arrow will show alone, and then the system will come up.
If you think it's a hibernation problem, pull the ac plug and battery out for about 1 hour and then plug back in.
If this didn't work, then try the F8 Key and choose "Last Know Good Configuration".
Nov 30, 2008 | Sony VAIO PCG-K23 Notebook
Won't boot
Try pressing F8 as your machine gets ready to start windows. Keep tapping it until you get a menu. You can try "most recent settings that worked" or failing that try starting Windows in safe mode. If it will start in safe mode regress it to a point before your failed download using System Restore. If it won't start at all, you may need to reinstall Windows.
May 26, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
Black Screen
Jan 16, 2008 | Sony VAIO VGC-V617G PC Desktop
SONY VAIO notebook freezes on xp splash screen every 2-4 mos.
first, ensure your system restore is turned on and make a restore point right now!...assuming you have run a thorough disk check and de-frag. then, trust the system restore. I have used it with success 100% of the 20 or so times I have used it. Next, start using the "Hibernate" power down mode. I have found this to work wonders with third-party driver problems. It seems that once a good startup happens, then freeze it (and continue to get a good startup) with hibernate from then on. Last, check about every month for the quantity of restore points that have taken place automatically by Windows. Sometimes, depending on the size of the hard drive, too many points can begin to encroach on your free space that you want for virtual memory or data. So for example, I see 15 restore points in the last month, I will dlete them all by cancelling system restore. Then I use "clean disk" scandisk and defrag. Then I turn restore back on.
Jun 12, 2007 | Sony VAIO VGN-FE790GN Notebook
Microsoft Sony VAIO 3544501 Notebook Logo
412 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
