Question about RCA HD52W58 52" TV
Need to clean the backside of the plexiglass
How do you take off the plexigass.
    Genius:
  • 1,030 Answers
Removal of the screen for the rca itc222 is rather simple remove the t-20 torx screws on the backside of screen and tilt forward
Posted on Feb 18, 2009
    Genius:
  • 1,199 Answers
You dont!!!! You remove the back upper panel screws and remove the back of the TV to access this area to clean! Wile your in there you might as well clean the lenses and the mirror too ( will see a big differnce in the picture!) be carfull with the back when removed! the mirrir is connected to it!
I think this will fix ya up!
Please rate this free response!
THANK YOU!
Posted on Jan 17, 2009
As the previous story relates I also was cleaning my bottom shelf in Luke warm water when all of a suddent it exploded into thousand of pieces. which flew across the room which took a couple of hours to...
Probably not. There are many reasons why tempered glass explodes. Age is the leading reason. If over time the shelf gets a tiny scratch on it, that will guarantee it will at some time fall to pieces. You don't have to replace it with expensive tempered glass either. You can get a plexiglass shelf cut to the dimension you need by finding a local glass shop that has plexiglass.
Jun 26, 2017 | Kenmore 62232 / 62234 / 62239 Bottom...
Broken front plexiglass rca 52 inch tv
Hello
Contact the nearest authorised service center for RCA at your town.
Mar 06, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
I need to replace a broken plexiglass dome cover for the webber chill
Buy a plastic cutting board. Cut it into a 16 inch circle and put a handle on it. Works better than original, keeps things colder!
May 21, 2010 | Weber Chill 05-161 Beverage Cooler
Broken plexiglass screen
If your TV is anything like mine (which I expect it is, since they’re the same brand), all you have to do is use a T-20 screwdriver bit to remove all the screws from the back of the frame around the plexiglass. Once the screws are out, the frame just pops up and the plexiglass is easily removable.
Mar 20, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
The screen on our 52 inch TV needs cleaning-inside and out
The outer screen is a protective screen. it is just glorified plexiglass. just use a soft cloth slightly damp.
Apr 09, 2009 | RCA D52W19 52" Rear Projection Television
Backboard is broken and need it replaced.
I had a steel plate made, to go behind the plexiglass and bolted that plus the plexiglass that was broke back in place, it works fine now, drawing attached, I had it made of 16 ga. S.S.
Dec 08, 2008 | Harvard Single Shootout Basketball Arcarde...
Cracked cover D52W19
i have used plexiglass for customers in the past. it has work just fine. rca call this thing supersheild and charges about 200 dollars.
Jan 12, 2008 | RCA D52W19 52" Rear Projection Television
RCA HD52W58 52" TV Logo
56 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
