Question about Dell Dimension 2400 PC Desktop
Hard drive I have a dell dimension 2400 it came with a cd drive is it possible to add a dvd drive to my computer
    Scholar:
  • 57 Answers
Yes, it is possible to do so. Adding a DVD is pretty much the same for most PCs. I suggest getting an 80-wire cable. The simplest solution is to replace the existing CD drive and cable with a new 80-wire cable and a DVD drive. You'll have to get drivers for it as well as software to use it (if the drive doesn't come with any). If you want to add it and use the existing CD, then you'll need to open the case, add the 80-wire cable (in addition to the existing cable) into the second IDE cable connector on the motherboard. Check these instructions from Dell. (Note they suggest connecting it to the existing cable, but that may or may not be possible.) Go to:
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/drives.htm
Posted on Jan 23, 2009
Is wd1200jb-00gvc0 hard drive compatible with dell dimension 2400
That is a western Digital Hard drive compatible with most computers even Dell Computers
May 15, 2014 | Dell Dimension 2400 PC Desktop
Hard drive boot failure
what is the error message? If operating system could not find, try you original windows installation CD, during you boot from the CD there is a repair option, follow the wizard to complete.
Sep 03, 2012 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 What is Targeted Read Test WHD-20-2RQ and Smart Short Self Test WHD16-FTD and how do I fix it if it said they failed
These are results of two sections of Dell Diagnostics tests which can be run by pressing F10 at startup.
You would have to watch them run to see what has failed during the test.
From Targeted Read Test WHD-20-2RQ failed, could be failure to read RAM (memory), CD/DVD Drive, or Hard Drive.
Something failing within Smart Short Self Test WHD16-FTD could literally be anything within the computer, without seeing what has actually failed during the test.
Sep 05, 2011 | Dell Dimension 2400 PC Desktop
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
Does the dell dimension 2400 burn dvds?
Hi budliteman36
Dell Dimension 2400 series will not bur DVD, see the link blow for specifications.
http://reviews.cnet.com/desktops/dell-dimension-2400-pentium/4507-3118_7-30824846.html?tag=mncol;rnav
You can replace the CD-RW drive with a DVD writer. Here is a list od DVD-R-RW writers.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=89&name=DVD-Burners&
Cheers!
Mike
Mar 31, 2009 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 does not recognize cd/dvd drive
Dear Minita,
please follow these steps.
1. Click on START button, the click on RUN
2. Enter REGEDIT and press enter
3. When REGEDIT starts, open up the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325 -11CE-BFC1-08002BE10318}
4. After clicking on {4D36E965-E325 -11CE-BFC1-08002BE10318} you should see two settings on the right-hand side:
"Upperfilters"
"Lowerfilters"
Click on each of them, press DELETE and click YES.
Then close REGEDIT, shutdown & restart your PC
if you still having problem or any other questions, please do not hesitate to contact me.
Many Thanks.
Regards,
AJoshi
Mar 18, 2009 | Dell Dimension 2400 PC Desktop
DEll 2400 - cd-dvd drive stopped working
try to clean the lens using lens cleaner...
Dec 02, 2008 | Dell Dimension 2400 PC Desktop
DVD drive bay
yes you should be able to play CD on the DVD reader.
Dimension 2400 have drive slide mounted on the side of the hard drive, cd drive and floppy. they are different for each device. you need the 2 side mount for the dvd. in order to mount them in the Dell.
the drive is inserted from the inside of the box toward the front. The front panel will prevent the device from pop out.
yes, 3 party DVD, CD drive will be shorter and fater that what Dell porvide, but it will work, al long as the opening is accessable.
get the HP DVD driver.
Nov 04, 2008 | Dell Dimension 2400 PC Desktop
Dell dimension blue screen stop error
When you start up computer press F12 to force computer to load from CD/DVD rom . Once it detects cd follow on screen instructions. If for some reason it doesn't work then try another cd , might need cleaning or try another CD/DVD rom if you have more the one in you system.
Aug 03, 2008 | Dell Dimension 2400 PC Desktop
Hard Drive Installation
The Dimension 2400 does not have SATA ports. Therefore, you need to purchase a SATA card to do this. Something just like this.
Jul 05, 2008 | Computers & Internet
Dell Dimension 2400 PC Desktop Logo
103 people viewed this question
Alun Cox
