Question about Canon imageCLASS MF5730 All-In-One Laser Printer
OFF Button? I have a ImageClass MF5750 series all in one. Other than the energy saver mode, how do you shut it off completely, we see no off button.
    President:
  • 1,901 Answers
Sorry, there is no On/Off switch on that printer. When plugged in it will automatically go to Standby.
The Energy Saver can be set anywhere from 3 to 30 minutes.
The only way you can remove all power to it is to pull the plug from the wall outlet.
PLease do not "shoot the messenger" here.
You asked, and this is the answer, so I would appreciate a Fixya rating.
(Is it really a problem using the Energy Saver?)
Posted on Jan 17, 2009
How do I get my Samsung fridge model #rs25hs5000bc off demo mode? I tried holding down energy saver and power freezer but doesn't work.
IT is three buttons not two. Cooling Off mode (also called Shop mode), is designed for use by retailers when they display refrigerators on the shop floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and the refrigerator and freezer do not get cold. To start Cooling Off mode, press and hold the Energy Saver button, the Freezer button and the Lighting button for 5 seconds during normal operation. The refrigerator chime sounds and O-FF appears on the display. To cancel Cooling Off mode, press and hold the Energy Saver button, the Freezer button and the Lighting button again for 5 seconds, until the chime sounds. Cooling Off mode is only available on refrigerators sold in the U.S. Instructions are on page 20=> HERE
APPLIANCE911
Apr 12, 2016 | Samsung Refrigerators
Is there a transparency adapter for canon imageclass MF5750 series?
Hey There,
Boy, this model is getting pretty old. Very basic as far as options out there.
I strongly suggest not running transparencies in this model. We have seen so many of these come in with them stuck and melted in the fuser section.
Apr 29, 2014 | Canon imageCLASS MF5750 All-In-One Laser...
My Canon image class MF5350d won't go into energy saver mode anymore
Odds are that some one did some panic button pushing at one time. You need to look in your owners manual or down load one from the web. Or you can go into the user settings and scroll down to were you see a setting for energy save. Good Luck
May 20, 2013 | Office Equipment & Supplies
How do i turn off energy saver toshiba e studio 203d
When u press the Energy Saver button, The machine will enter Energy Saver mode where all the display lamps are light off. Just leave Energy Saver mode, just press again the Energy Saver butto
May 18, 2012 | Toshiba e-studio 203sd
How can I turn on the energy saver on my LWHD2400HR air conditioner? There is no switch on the A/C, only an indicator light that says "Energy Saver"?
The Energy Saver mode is activated by using the hand held remote control, that comes with the unit. Pressing the Energy Saver button activates it. Once activated the fan will shut OFF when the the compressor does. After which, about every 3 minutes the fan will turn ON to check the room air to determine if cooling is needed.
It sounds like, you're missing the hand held remote control?
Jul 19, 2011 | LG LWHD2400HR Wall/Window Air Conditioner
Do not know how to use the energy saver feature
i have a problem for minolta di351 by code c009 pls help me
Feb 21, 2009 | Toshiba e-Studio 350 Copier
CLEANS ITSELF TOO FREQUENTLY- 2-3 TIMES EACH DAY
Try maxing out your power save timers. Here are the instructions. I suspect the machine is going into power save mode to quickly. Here is how you do that.
NOTE: To save energy, the printer enters a power saver, low-energy consumption mode after a predefined period of time since its last activity. In this mode, most printer electrical systems are shut down. When a print job is sent to the printer, the printer enters the Warm-up Mode. You can also warm up the printer by pressing the [OK] button on the Control Panel.
If the printer is going into Power Saver mode too often and you do not want to wait while the printer warms up, increase the length of time before the printer goes into the Power Saver mode.
Modify the timeout value:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Printer Controls], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Power Saver Timeout], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select the required timeout value (30 - 240 minutes), and then press the [OK] button.
    NOTE: Select a larger timeout value to extend the length of time before the printer goes into the Power Saver mode.
  5. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
Feb 02, 2009 | Xerox Phaser 8500/DN Printer
How to turn off the cleaning page feature in Xerox Phaser 8500
Actually what is happening is your machine is going into the power save mode and staying there for a long time.
What happens then is you get a full warmup. When the machine warms up, it will turn on the compressor and drain the resivour because Xerox wants a "fresh": supply of ink in the print head.
Its excruciatingly expensive and wasteful.
Here is something that can help. I am not sure you can completely disable the energy save mode. Thanks Al Gore...
Dec 17, 2008 | Xerox Phaser 8500/DN Printer
Canon imageCLASS MF5730 All-In-One Laser Printer Logo
213 people viewed this question
old marine
old marine
