Question about Maxon MCB-40 40-Channels Handheld CB Radio
Help with cb
I hav a maxon cb with noaa wathr on it but it wont pick up noaa and i have trid verything any help
    Problem Solver:
  • 19 Answers
Open up the radio and look inside of it towards the front of the unit, there should be a small circuit board mounted either in the front center or to either side of the radio. This will be the board for the weather channels, check the all the wires coming from this board and make sure they are connected on both ends, if they are then look on this little circuit board and you should see some small components with tiny slots for a screwdriver to fit. these are the adjustments for the receive function of the weather channels, slowly turn the little slot with a small screwdriver little by little one by one and you should notice some kind of change in the receive on these weather channels if so keep slowly adjusting them until optimum receive level is obtained. If you feel this proceedure is beyond your skill level then I suggest that you carry it to a local CB radio repair shop. If you dont have a local repair shop just go to a truck stop along any interstate and ask the employees or even a trucker if they know where a cb repair shop is and I feel sure there will be one within a few miles of your location. Good luck with your problem.
Posted on Aug 01, 2007
SOURCE:
My Maxon 30 cb want pick up signal when i want to talk
throw it away and get a real radio.I have a maxon 45 that I am trying to repair for over three years and Every time I come close ,it not the problem.Radio is to old just save it for parts or junk it but get a new one.
Jun 17, 2014 | Radio Communications
With my cobra 29 wx nw st I can not pick up any weather channels. I have the k30 antenna. Do I need a dual band antenna?
Do you hear static when you turn on weather? If so there are just none in range of you. There are not weather radio stations everywhere. You would not use a dual band antenna on any CB. Only an antenna designed for the 11 meter band. Which is the 27mhz CB radio band.
You can go here and see if you have NOAA All hazards weather radio coverage in your area.
If the CB radio is working otherwise it is most likely that there is just not a NOAA transmitter near you.
Aug 09, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
My maxon cb radio model MCB-10A wont change channels it stays on channel 9
Hi, my name is John. Try to press or flip the button or EMG. That should do the trick.enjoy....hope this was very helpful....
Sep 01, 2010 | Maxon MCB-40 40-Channels Handheld CB Radio
Can not hear anything
Take the cover off, hook the antenna up and turn the unit on. Take a pencil with the eraser end and press around on the circuit board, look for cold solder joints....hope this helps..
May 17, 2010 | Radio Communications
Is my maxon mcb-30 pa capible
According to the page below, it does not have PA capabilities.
http://www3.dealtime.com/xPF-Maxon-MCB-30
Aug 22, 2009 | Maxon MCB-30 40-Channels Base CB Radio
Can a maxon mcb-60 professional series mobile cb radio be changed from am to fm, many thanks alan.
Alan I believe ther is a board that can be placed inside to add the FM Feature. But with out this added board I honestly dont think So. Let me know if this Helped. Best wishes to you. Try googling FM boards addon for CB radios.
Jul 04, 2009 | Maxon Radio Communications
BATTERY CHARGER HCB-30A CB MAXON
you can get that charger aftermarket at radio shack take the walkie with you to get the right power supply the voltage should be close to where the external power plug goes into the radio.
Mar 13, 2009 | Maxon HCB-30A CB Radio
I have a Maxon handheld cb - it squeals when keyed can not talk.
sounds like you are getting a feedback squeal.. try taking a wire and attaching to you handheld and grounding it to something.. that might work.. i know i have to have my mic on my cb grounded to my radio or i get a feedback squeal...
Jan 02, 2009 | Maxon HCB-10C CB Radio
Radio Communications Logo
79 people viewed this question
Top Maxon Radio Communications Experts
Van Allen II
Van Allen II
Mike Charette
eradiostore
eradiostore
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
