Question about Bissell 8910 ProHeat Clear View Upright Vacuum
No fluids at the rollers or the hand tool
The product turns on rollers work just no fluids, everything was fine during the previous use.
  • nasont Jan 17, 2009
    8920 proheat 2x is not getting spray to brushes , it just drips when you pull the trigger and the hand tool gets no fluid at all.
  • 66 Answers
I agee with MrScary66613 I had to do the same thing on mine.
Posted on Jan 17, 2009
    Sergeant:
  • 221 Answers
Http://www.patentstorm.us/patents/6481043/description.html just click the link and go through the procedure. thanks.
    President:
  • 1,990 Answers
Welcome to Fixya! no spray at the rollers. Seeing that the hand tool worked I checked the finger switch for continuity and it was good. Turns out the red spray heads that clip into the unit just under the water tanks were the culprit. I popped those off and ran a paper-clip through them from the front. I must have contaminated the fresh water tank while emptying the grey tank. Works better than ever now, just thought I'd share what my issue turned out to be.
    Sergeant:
    Scholar:
  • 199 Answers
As with all rollers, it takes a few minutes of use to reach optimum
performance whilst the fluid is absorbed deep into the pile core. Use of rollers
on rough surfaces can lead to some deteriotaion in performance. For best results
it is recommended to use one roller per tub.
    Scholar:
  • 108 Answers
There is a tube that carries the fluids from the tank to all regions. Make sure it is not pinched or obstructed.
Also make sure there is nothing clogging the outlet hole.
Hope this helps you out.
  • Michael Lucas
    Michael Lucas Jan 17, 2009
    The lines are clogged that dispense water and solution.You must make sure that there is some kind of liquid in the dispenser
    bottle at all times. This doesn't have to be soap. You can fill it with
    water, Also you must insure that the tube in the bottle is installed
    and pointing up into the highest corner of the bottle. This provides
    pressure on top of the liquid so no air may intrude into the fluid
    line. There is also a plunger just under the fluid flow control knob
    that must be installed correctly or air will get into the lines. There
    are different styles of brushes you can get. My old brush did the same
    thing that you describe. My new one has 5 rows of bristles all the way
    across the roller. Not 2 rows with a gap in the middle. This is
    probably the cause of the line.
Model UH70086 agitator brush won't rotate. the belt is fine and turns the wheels. replaced v belt because I thought it was stretched but new belt is the same size. everything turns, the belts and the...
The brush has to be able to rotate freely in order to work. If you remove the roller and its end caps you may find it is clogged with hair or other debris. Cleaning out the debris should allow the brush to rotate freely.
Nov 05, 2013 | Vacuums
Roller not turning when vaccuming
just had the same exact issue with mine - took everything apart - found that the swivel roller brush wasnt turning. it was not any belt issues or motor issues. took out brush roller - held in my hand by holding just the hand cap still - and tried turning the roller with my other hand. roller would not turn at all but is supposed to with no effort. on some models the end caps pop off but most are one piece and are just discarded and a new roller bought - seems to be $10-$20 for one for most dirt devils and under $10 shipping in north america. you can try something down the side of the roller and end cap like a razor - i did cut lose some crud and it works - but roller still stops on 2 of 4 settings on the rug because of this. i've already ordered a new one.
Mar 11, 2013 | Dirt Devil Vacuums
Hand held vacum suction stopped after 1st use. Was working fine, suction does work if onfloor but won't once turned to tool
go to the web page and see instructional video and maintenance help
http://www.bissell.com/how-to-videos/
God bless you
Jul 19, 2012 | Bissell 2X Proheat 9200 rug cleaner
I have a Dyson Telescope vacuum. Everything works fine, except the attachment used for floors. I can feel air and suction going through the attachment, but the brush doesn't rotate or move at all....
If you have suction as you say, the tool is faulty.
They come apart so you can clean them. remove all hair and debris from the roller brush (use a coin to split it using a quarter turn on the two/three screws). Try turning the brush with your fingers. If it is stiff, it needs attention to the bearings in the tool probably. If it turns OK, then the mini turbine inside is faulty -- replace the tool.
Feb 05, 2011 | Dyson DC14 Telescope Reach All Floors...
I took the cover off the brush so I could cut off all the hair that was wrapped around it (vacuum was working fine, I just noticed the hair). I pulled the brush/spinner thing off one side, cleaned...
the ends of the brush roller have to go in in a certain position.each end has a different look.make sure the match up to the seats on the roller guides and make sure the belt is centered.the belt will center itself by turning the roller by hand in one direction then the other.the ends of the brush roller ust set in their seats correctly
Sep 12, 2009 | Dyson DC14 All floors Bagless Upright...
Bissel proheat 2x main suction problems
bissel pro heat x2 does not suction up the cleaning fluid
May 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell 8920 won't release fluids at the rollers
I have an 8920 ProHeat 2x as well with the same issue - no spray at the rollers. Seeing that the hand tool worked I checked the finger switch for continuity and it was good. Turns out the red spray heads that clip into the unit just under the water tanks were the culprit. I popped those off and ran a paper-clip through them from the front. I must have contaminated the fresh water tank while emptying the grey tank. Works better than ever now, just thought I'd share what my issue turned out to be.
Oct 10, 2008 | Bissell 8910 ProHeat Clear View Upright...
I can't get the power brush belt on tight. Am I missing something?
I don't know what brand of vacuum you have, but the belts on most vacuums should be changed approx. once a year. The belt can look fine, but is stretched and won't have the necessary tension to turn the roller. It is possible that the roller is in need of servicing. If the bearings in the roller are fouled with dirt and hair, they will not turn properly and a new belt will not solve your problem. Take the roller out of the machine and turn the end caps by hand. They should turn freely. Once you've determined that the roller is o.k., install a new belt, turn the roller by hand to make sure that nothing is jammed and then try the machine again.
Feb 01, 2008 | Vacuums
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
