Question about Coffee Makers & Espresso Machines
After grinding no coffeee comes out
Saeco vienna digital, grinds for very long time then trys to come out but no water ever does, thus no coffee.
is the long grinding time because of oily beans or something else?
is it the water line is clogged or is it the pump?
Can a regular person change this without issues?
  • Anonymous Mar 08, 2009
    The grinder is turning bot it doesn.t grind any coffe. Hot coffe comes out instead af espresso !
  • 515 Answers
If you open the steam knob and make a cup of water (the), can you get any water comes that way?
If not then i think you have calcium in the system.
If the grinder goes for long time it can be oily beans or if you get damp into the grinder.
Let me know if you need more help.
Best regards
/Mirran
Posted on Jan 29, 2009
My Saeco Vienna Black Automatica Espresso maker will grind coffee only about one-fourth of the time. Other times, it makes whirring sound and then shuts off and red "coffee bean" light comes on.
Your grind is to fine. Turn the big knob in the bean hopper up 4 clicks and try again. It could be oily beans which would require the same solution.
Nov 02, 2010 | Saeco Vienna Espresso Machine
Weak coffee saeco vienna "not digital "
Hi
Has the size of you ground coffee changed? If it is not the size of granulated sugar then its your grinder. Check ebay completed listings. Saw one there couple weeks ago.
Nov 24, 2009 | Saeco Vienna Digital Coffee Maker,...
Saeco Vienna. Wet cofffee grinds in the dump box.
It could be the grind on the coffee or the red group o-ring and the 2 o-rings on the white plastic valve need to be replaced.
Nov 05, 2009 | Saeco Vienna De Luxe Espresso Machine
Hello. I have a saeco vienna superautomatic
This happens due to condensation caused by steam developed at the end of the grinding cycle. Make sure that the grinding chamber is completely cleaned and dried before using the grinder.
  1. Turn the whole bean chamber to the right until it can be lifted off the base. This will allow you to clean the grinding wheel. NOTE: Never use water or liquid for cleaning the lower grinding section of this appliance.
  2. Clean interior recesses with a soft brush (not provided).
  3. Wash the whole bean chamber and lid and the ground coffee chamber and lid in mild detergent and water. These items are only dishwasher safe on the top rack of your dishwasher. Wipe exterior with a damp cloth. Do not immerse mill in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  4. After completely drying, replace whole bean chamber. Important: when replacing whole bean chamber, screw on completely before setting grinding rate. Turn chamber clockwise (as viewed from top), until it will not turn. Fill with whole coffee beans for grinding and replace lid.
  5. Replace ground coffee chamber and lid, making sure it snaps securely into place.
Aug 02, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna grinds too much coffee.
Hi
If you have the Delux or Digital there are 2 knobs in the bean hopper. Turn the small knob back 1 mark and see if that will help.
Jul 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna de luxe no coffee comes out
The brew unit is blocked, remove unit and then remove the screen located at the top, clean screen and reassemble.
Jul 03, 2009 | Saeco Vienna De Luxe Espresso Machine
Hot water
Grinds are too fine and or the coffee chute is clogged.
Feb 19, 2009 | Saeco Vienna SuperAutomatica Coffee...
The water is not adding to the ground beans , is it plugged?
I haven't seen a Vienna in a long time so I cannot remember if there is a door for preground coffee, if that option is there, open door and press button to make a coffee if you get water, then adjust the grind and dosage on the grinder and try the auto function.
Jan 17, 2009 | Saeco Vienna Digital Coffee Maker,...
Saeco vienna deluxe espresso machine
Clean the ball and valve assembly located in the Brew Group. It ocassionally gets "dirty" and needs cleaning. Be careful you don't lose the glass ball which is very small. Use a q-tip or small wire for cleaning the tubular area.
Sep 18, 2008 | Saeco Vienna Espresso Machine
Coffee Makers & Espresso Machines Logo
211 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
