Question about Frigidaire FEF376 Electric Kitchen Range
HOW DO YOU REMOVE THE OVEN DOOR FROM A Frigidaire STOVE
OVEN DOOR
aborcass
  • 2651 Answers
SOURCE: Frigidaire ES340 clicking noise and display blinking when oven door opens
sounds like a bad door/light switch.it cant seem to tell if door is open -closed and clicking really fast betweeen the 2. replace the switch
Posted on Mar 02, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire stove model gles388dsb
sounds as if there is a problem with the latch assy, there are 2 switches mounted on the latch mechanism for monitoring positon of hte switches, seems as if one has gone bad, not recognizing the door lock positon therfore continues to rotate without stop.part number for the motor latch assy w/switch and bracket 318095957 . located behind rear panel
Posted on Nov 24, 2008
I believe the oven it has a power surge protector within the appliance. Try to unplug it and plug it back in. It should solve the problem.
Posted on Dec 20, 2008
  • 111 Answers
SOURCE: Frigidair Electric stove (MN) CFEF358EC
F90-Maximum oven door unlock time exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch. 2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary. 3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam. 4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, repl;ace Lock Motor Assembly. 5. (F90, 91, 92, 93 & 94) Lock Motor continuosly runs - if Micro Switch is open, replace Lock Motor Assembly. 6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch. 7. If all situations above do not solve probem, replace EOC.
Posted on Jun 17, 2009
jumptrout51
  • 3361 Answers
SOURCE: I have a frigidaire FEFL77ABH Electric Stove. The
1100 ohms.
Posted on Sep 06, 2009
How to remove the stove top on frigidaire stove model FFGS3025PS
IF you open the door to the stove, you will see screws under the lip of the cook top, take those out, check the back of the stove for screws and then lift the cook to. On some models you may have to remove the sides of the stove too.
Mar 13, 2016 | Frigidaire Stove/Oven/Range Cooktop -...
How do I remove my oven door from my stove it is a frigidaire about five years old
Open the door about thirty degrees towards you or a foot or so gap and pull up on it. It should just slide right off the hinges.
May 12, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire stove continuosly locks then unlocks
there is a small switch on the lock mech thats probly not making this is comon
Dec 25, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Have a dble frigidaire ovenand the right hinge is
Basically, oven hinges more or less work on the same principle. However, they do not normally pop out so I am reluctant to say what the problem is. Normally your handbook will tell you how to remove and replace the oven door.
If you haven't a handbook, try the manufacturer or repost under the Frigidaire section.
Nov 24, 2009 | Stoves 720EF Electric Double Oven
How to unlock the frigidaire oven range door and remove error F3?
How do you adjust the oven door on a Fridgedaire Gallery Series gas stove?
Jul 13, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire plgf390dc stove not working dispay wont go on
The oven door won't close because the oven lock is causeing the door not to close all the way. So is there another way to reset the oven so the oven door can close.
Jun 27, 2009 | Frigidaire PLGF390DC Stainless Steel Gas...
Oven door falling down on the Frigidaire stove
Try to replace the hinges the locking mechanism is going out
Feb 08, 2009 | Stoves 720EF Electric Double Oven
Frigidaire professional series electric oven door won't open
MY OVEN DOOR WONT UNLOCK ON MY FRIGIDAIRE PROFESSIONAL SERIES STOVE 31606390
Jan 22, 2009 | Electrolux Frigidaire Professional Series...
We have a frigidaire stove. The bottom element has broken in two. We have purchased the new element but cannot locate our manual to show us how to install the new element. Can you give us instructions?
Hello the first thing you do is unplug the stove before doing anything ,open the oven door remove 2 screws holding the element to the back wall pull element forward remove wires with insulated pliers attached to the element ,reattach wires to new element resecure to back wall and test. good luck
Dec 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Nov 24, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire FEF376 Electric Kitchen Range Logo
284 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
