posted by nilonicss on Jun 21, 2007
after having the unit run for a few minutes on cool set it will start blowing water out of the vent in the front. i have to empty the water and will be able to use the unit again.
Best Solution
posted on Jul 15, 2007
Assuming this is a window unit, make sure it is level. If so, the drain tube between inside & outside may be plugged. This is often visible with the front panel off, & the tube can be cleared with a piece of coathanger wire. The tube is usually only a couple of inches long. Check for damage to the water tray under the cooling coil as well.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for DeLonghi Pinguino PAC-02 Air
Email this problem
Email this problem
Can you Help with these Air Conditioners problems?
DeLonghi Pinguino PAC-02 Air Conditioner
air conditioner
air conditioner
my carrier air conditioner is... Answer This...
replace exhaust hose
I would like to find iut where... Answer This...
Delonghi PAC 02 A?C
Delonghi PAC 02 A?C
need to replace exhaust hose.... Answer This...
Repair Service
Find Air Conditioner Repairman Near You:
