E000 in canon ir 1600
Sir i have a error code E 000 in canon ir 1600. what is service mode? how can i reach service mode?
  • walid07 Feb 18, 2009
    canon ir 1600 problem e000
  • Anonymous Feb 24, 2009
    thanks it realy helps me solving e005
I have one canon ir 400 that mc showing eror e004 how to slove this problem
Posted on Mar 17, 2010
    Problem Solver:
  • 8 Answers
Hi..i ll try to solve this prob, since i ve encountred this code b4...
e000-e005 most of it, from fixing unit.
to reset it..u can go to service mode by pressing *and #
go to clear (number 16, if not mistaken)--> err
if still appear, go to clear-->all
switch off the machine n then back on
note: if u "clear all", the setting will go back to factory setting (u need to re-setting everything)
Posted on Jan 19, 2009
I've solve the problem that occurred on my iR1600 canon photocopier as wiliyanto shared. I pressed * and # then find clear which is in number 12 and select clear all, switch off machine and start. The problem fixed and I re-set my machine.
Posted on Jun 15, 2015
Sir, i have question- error code E000 IN CANON iR 1600 i have copy macheine i wsh you help me
E000 : fusing problem ,check the thermistor, therm fuse and heater lamp then try to reset it by reset error code.
Jan 15, 2011 | Office Equipment & Supplies
E000 IS DISPLAYED IN THE MACHINE
E000:
The main thermistor reading does not reach 40ºC 14 sec after the fixing
heater goes ON. (fixing low temperature error).
First you need to try reset the error code and the procedure for that is:
SERVICE MODE entry: MENU and #
If E000 through E004 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and turn
off and then on the power switch to clear the memory: #7 PRINTER>#4
PRINTER RESET>YES=(*).
If the error is still present after clearing, you need to dismantle fixing unit and check with universal voltmeter the lamp, by putting the DVM to buzzer mode and each ends of dvm probes put on ends of lamp, if it buzzs that means that there is connection and lamp is OK, so you need to focuse on thermistors and thermofuses or ... call service.
Hope that helps!
Aug 19, 2010 | Canon iR 1600 Laser Photo Printer
When its switched on it shows me system error 000. send me a solution immidietly.
it is a fiser related error, you need to reset error code servie mode.
* 28* will put you into service mode,
then choose copeir, option, clear, then clear error, highlight that press ok,
then restart machine.
May 12, 2009 | Canon imageRUNNER 1023iF Black and White...
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
Error code E OOO in canon iR 1600
press * press id (#) then goto service mode 7 sub mode 4 (printer reet) then pres ok key trun off machine on agine it'll be ok now.
Sep 08, 2008 | Office Equipment & Supplies
Ir 2000, system error E000
The main thermistor reading does not reach 40°C 14 sec after the fixing
If E000 is indicated, the RAM on the image processor will
turn off and then on the power switch to clear the memory: #7
PRINTER>#4 PRINTER RESET>YES=(*).
Entering service mode: press "aditional function" and after "#(ID)"
Jul 16, 2008 | Canon ImageRunner 1600 Copier
Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
May 17, 2008 | Canon imageRUNNER 1600 Laser Printer
Copier canon ir 1600
Problem with fixing Unit, simple simulation will help. otherwise need to change fixing unit,, contact ur service engineer
Nov 03, 2007 | Canon imageCLASS D860 All-In-One Laser...
2,659 people viewed this question
k24674
