Question about Bissell SpotBot Robotic Wet/Dry Vacuum
Cracked hose for Bissell SpotBot
Is it possible to replace just the hose on the Bissell Spotbot? The plastic on the hose has cracked. I only found one website that made reference to the hose and it was "out of stock".
I found a site that carrys them, not sure if they are out because just as I was about to order one I decided to try and fix mine since the crack was right up next to the handle. http://www.svcvacuum.com/bissell/steamer_hose.htm
All I did was unscrew the two screws where the button is for releasing the water on the hand piece. I thin squeezed the clamp together to remove the water hose. Once that was removed I cut the hose and then PRYED out the part of the hose in the hand piece. I then cut the hose down where the crack was. Feed the "water hose" back through the hole in the handle (I heated it with a lighter just a tiny bit to make it soft and worked it through the hole which I just enlarged a slight bit) and with pliers work it back on. Don't forget the clamp. Next just work the outter hose back into the handle but make sure to use a glue or silicone sealer or both.
Even if you get a new hose Im not sure it will come with the handle. To connect the hose to the Machine part just push in that little plastic "dot" and pull out the hose at the same time. Then remove the old hose by the directions above. There is no need to remover the inner clear hose from the machine part, only the handle
Posted on Jun 07, 2009
SOURCE: Trouble with Spotbot
Just found out that the Bot I gave my daughter for Christmas LAST year didn't spray either - almost a year and she's never used it (and didn't let me know). Got them for two other daughters - those worked fine. I was pretty skeptical, but I tried the solutions above (holding down trigger in manual mode - and also removing and resetting the tank several times even though I didn't see bubbles). Voila - another success story. Have two daughters' bots going on MY carpet now - hmmm...why didn't I buy one for myself?
Posted on Dec 07, 2007
  • 556 Answers
SOURCE: User guide
You will need Adobe Reader to read/print these manuals
Use the following link and click Get Adobe Reader
http://www.adobe.com
There appear to be two models the user guides are in the right column -- be sure the models are right the model numbers 1200-a and 1200-B appear under specs
http://www.bissell.com/Bottom_Menu/Product_Search.aspx?Criteria=spotbot+1200
Posted on Dec 22, 2007
SOURCE: Spotbot is leaking...
either the "duck valve" on the dirty water tank or the clean water tank valve (in the screw top) are leaking. you can buy either or both from bissell for a few bucks.
Posted on Jan 07, 2008
SOURCE: SpotBot: Brushed do not rotate
I have the same problem. I took the thing apart and tested the motor and it works just fine. The voltometer is telling me that there is no juice going to the motor. I tested the voltometer on other contacts in the vacuum and it's working fine. It seems every moving thing in the spotbot runs on 120v AC 60mhz, but like I said above; for some reason the spot bot isn't sending any electricity to the motor that makes the bristles go around. It has to be a controll board problem as the wires go strait from the board to the motor. Personally, I'm not even going to bother getting it fixed. I'll just stick with the hand cleaning tool. The darn automated cleaning cycles use too much solution anyway.
Posted on Oct 01, 2008
  • 3 Answers
SOURCE: bissell spotbot: leaking the dirty
I had the same issue. After some research, I determined I was missing a black "duckbill" gasket on the bottom of the dirty water collection tank.
This caused reduced suction, and for the water to pool at the botom of the spotbot, thus leaking.
I purchased the gasket at Bissell for 1.39. The part number is 203-6646.
I purchased my SpotBot new from Target, and never remember seeing this black gasket, but the difference is night and day.
Posted on Aug 14, 2009
Tip
How To Replace The Hose On A Bissell Spot Bot, SpotBot, and Little Green...
Replacing the Suction Hose on a Bissell SpotBot can be a challenging repair. We frequently get this question, how do you remove the old hose, so we decided to shoot a video repair demonstration on how to replace the hose assembly.
This repair works for all Bissell SpotBot models in the 1200 Series, as well as the 7887, and some Little Green Machines.
If you need to purchase a new Hose Assembly, you may find it on our website below:Bissell SpotBot Hose Assembly Part 203-6665
Here's the video showing how to replace the hose:
Please feel free to email us with any questions or clarification requests, and please be so kind and rate the video helpful if you found it to be.
Thanks so much,
Chris JonesGoVacuum
on Jul 26, 2011 | Bissell 12005 Spot Bot Handheld Vacuum
The top of my Spotbot separates from the bottom when picked up
There are a few screws that hold the two parts together. Check the housing and see if cracked around those screws.
SpotBot Supplies
800-775-6586
GoodVac com
Feb 22, 2015 | Bissell SpotBot Hands-Free Compact Deep...
Spot bot is blowing not sucking
This problem may be the same as I am having. The SpotBot recirculates the vacuum air back into the brush area when it is using the circular brushes. There is a short flexible hose deep inside the unit that connects from the clear plastic nozzles in the round brush unit to the end of the clear vacuum hose outside. Mine had a large tear in that flexible hose. This causes air to enter the hose and reduces the vacuum action, like cutting a hole in the side of your regular vacuum hose. The bad part is that I have not been able to find a replacement hose. It also takes a bit of repair experience to even get inside to where this hose is. Given the number of references to this type of issue, it appears that Bissell has a design flaw that causes the hose to break prematurely. Any response Bissell?
Jul 06, 2014 | Bissell SpotBot Robotic Wet/Dry Vacuum
SPOT BOT NO SUCTION
Hey Courtney! Sorry to hear about the suction problem on your SpotBot. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1040&cid=ccsocial
Jan 04, 2013 | Bissell SpotBot Robotic Wet/Dry Vacuum
My Bissel Spotbot will only let me use the Manual Mode, when I try to push "Set in Stain" or "Surface" stain the light won't turn on. My children were playing with it, but I...
There is a small magnet in the end of the hose. Under the phillips screw and plastic cover. Mine rusted to bits and stopped tripping the switch. A bit of a super strong hard drive magnet siliconed back in the end of the hose and all was fine.
May 26, 2011 | Bissell SpotBot Robotic Wet/Dry Vacuum
No Power on Bissell Spotbot
board likely not available, contact Bissell dealer.
Jim
Jul 27, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell SpotBot Robotic Wet/Dry Vacuum Logo
513 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
