Question about Whirlpool Duet GHW9150P Front Load Washer
The Ariston ATVF 129 wash machine do not work and post F-02
The program do not work and post on the screen the F-02 (error). After this we can not open the door of the roll.
  • Whirlpool Master
  • 3,463 Answers
F02 is a indication that the motor has jammed, and or the tacho has come loose or broken.
The tacho is the magnet at the end of the motor away from the pulley., check this first, you may have to have a new motor fitted.
Plz rate my solution.
Thanks.
Posted on Jan 17, 2009
What does the error code 07 in an ariston amd 129 ?
the led flashes seven times? then pauses for 8seconds? this is how you determine the service code on a 129 there isn't a F7 code on a 129 on a 125 it's a heater relay stuck.... hope this helps~~
http://appliancejunk.com/forums/index.php?action=dlattach;topic=8959.0;...
Jul 15, 2014 | Washing Machines
Ariston artxf 129 error f02
F02: Blocked Motor, Short-circuited/Open Tachometry
Overhaul CNE
Overhaul Motor connector
Control CNE Continuity/Motor Connector
Control Motor Windings
Control Tachometry Windings
Replace Card
Dado
Jun 04, 2014 | Ariston Technologies AW 129 NA Washer With...
WHAT IS F12 IN A WASHING MASHINE ARISTON AQUALTIS AQXXF 129 H?HOW CAN I FIX IT?
F12 SPECIFIC FOR LVB2000 INDESIT EVOLUTION / DIALOGIC.
F12: Lack of Display card-Main Card Communication
1. Check the effectiveness of contacts on CNC Connector Card
2. Overhaul 8-way connector on Display card
3. Check continuity of CNC-CN 8 way connector
4. Replace Main Card
5. Replace Display Card
Dado
Apr 24, 2014 | Ariston Technologies AWD 129 NA Washer/...
Lavadora secadora ariston aqualtis aqm8d error f13
F13: NTC wiring harness disconnected from the dryer system
1. Check the efficiency of the terminals on the CNA connector board
2. Check NTC wiring harness
3. Check the wiring harness continuity of the CNA / NTC connectors
4. Replace NTC
5. Replace terminal board
Dado
Apr 08, 2014 | Ariston Technologies AWD 129 NA Washer/...
Ariston h20 errors
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
Jan 14, 2014 | Ariston Technologies AWD 129 NA Washer/...
Ariston AQXXF 129 Error code F 05 - What is this?
see this causes and fix it. God bless you
F05 Water temperature sensor error If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Replace failed component.
Sep 30, 2012 | Ariston Technologies Washing Machines
Ariston avxl 129 washing machine has stopped working.
This washer does not have a good track record. There are many many complaints out their on this brand in general. It is also not a cheap purchase.
1st. Suspect is the mother board followed by the motor.
Nov 20, 2011 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
391 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
