Question about HP LaserJet 3380 All-In-One Printer
The panel on my laserjet 3380 says scanner erroe power off power
So we powered it off and then unplugged it and it continues to show that on the screen
  • 2 more comments
  • bdools Mar 06, 2009
    Same as everyone. First, "Scanner Bulb Warming Up", then scanner error, power off and power on". Then, after waiting, same thing. I don't use the scanner much at all, the frustrating thing is that it locks up the entire printer.....no printing, no faxing, no receiving faxes. AAAGGGH.
  • Legal3380 Apr 14, 2009
    I have the same problem, display says "Scanner Error Power Off" and the printer won't do anything until it goes away, printer was just over a year old when error occurred and has been sitting in a box for a couple years now but I'd like to get it back up and running if possible. Do you have a diagram or something that shows where/how to get to the scanner head?
  • audibelokc Apr 23, 2009
    Our Laserjet 3380 is showing the same Scanner error message that others have described. We tried cleaning the mirror as suggested with q-tips but the problem did not go away. This seems like a common problem with this 3380 so we hope someone out there will have the solution to the problem other than the repair man and down time.
  • Thomas F. Schneider May 11, 2010
    Tried to disconnect,uninstall and then reinstall with updated downloaded,drivers?
    http://h20000.www2.hp.com/bizsupport/Tec...
You need to clean the small mirror film. Repeatedly turning on and off the printer will move the scanner head to the left. When it makes it to it's final position remove the screw and using a qtip gently wipe the thin mirror film next to the light bulb. This will clean the dust that is causing the error. some say use alcohol on the qtip i never used it. Once it's clean the scanner will return to it's original position and resume function. return side glass and screw, and you should not have that error until it's once again dirty.
Posted on Mar 09, 2009
  • Anna Sotirovski
    Anna Sotirovski Aug 16, 2012
    Hi I have tried your method a number of times and nothing seems to be changing as I am still getting the same message.Is there anything else I can try?
HP LASERJET 3380 SCANNER PROBLEM
It will cost more to have it fixed than to buy a new one,
Oct 23, 2009 | Sport & Outdoor - Others
Hp laserjet 3380 - MS Vista - scanner error, copying is ok
clear glass, replace ribbon scanner cable if no result - replace scanner
Aug 24, 2009 | HP LaserJet 3380 All-In-One Printer
Scanner Error - Power On > Power Off
1) Unplug any connection to your computer from this device (usb wire, scsi, cat-5 cable)
2) uninstalling the drivers from the hardware menu
3) reboot your PC
4) confirm the printer is no longer installed on your PC by going to the printers section of your control panel.
5) Follow the installation proceedure ducumented for your printer.
6) restart your PC if requested, if not go to step 7
7) test that you can print to your printer.
If there are still errors, contact HP and describe your issue in full detail.
May 29, 2009 | HP LaserJet 3380 All-In-One Printer
Bad fuser Laserjet 3380
hii..
is u 3380 fuser fixing film ok...if ok try to change presure roller..it below fixing film....you can take out the fixing firm or presure roller.just check the size only.if same u can combine it.
2.try to clean paper pick roller at 3380 printer..
Nov 11, 2008 | HP LaserJet 3380 All-In-One Printer
Sounds like the scanner has died. Sometimes restarting can help out. If you can print try printing out the configuration page and let us know what the error codes are.
May 27, 2008 | HP LaserJet 3380 All-In-One Printer
Scanner error
usually this means that the scanner electronics has failed. If you can print from the control panel try printing out a configuration page and let us know what the error codes are.
Mar 25, 2008 | HP LaserJet 3380 All-In-One Printer
HP LASERJET 3380
You may want to remove the glass and clean the underside of the glass and the lamp, also whatever mirrors and lenses there may be. It sounds like it is not setting up properly and the glass and mirrors getting hazy can cause that.
Dec 07, 2007 | Office Equipment & Supplies
HP LaserJet 3380 All-In-One Printer Logo
1,225 people viewed this question
Seeker5211
Seeker5211
