Question about Estate TAWS800JQ Top Load Washer
Water keeps going and going and going!
Hi my washer keeps filling with water. If I have it in any cycle the water keeps flowing out and never shuts off. When I shut off the water on the laundry sink thats when it stops filling. Could it be the water level switch? Please help...Tim
  • 1 more comment
  • Anonymous Apr 02, 2009
    With my washer it's the hot water that doesn't stop filling, the cold stops normally. It believe it to be the valve between hot water hose and washer. Getting a new valve probably won't help; it will get broken soon due to vibrations from washer due to worn-out shock absorbers.
    Anyway, I think it's time to replace the washer; it's about 38 years old!
  • Anonymous Mar 19, 2014
    when filling washer keeps shutting off
  • Anonymous Mar 23, 2014
    GW512 keeps filling up when it should stop
  • 883 Answers
The water is draining back to the ocean. The drain hose was not emptied properly from its last use. Put the machine in spin cycle (about 5 minutes) only to spin out the water from the outer tub completely and retry washer. If still problem, then visual check drain hose that it still has a "rising" section higher in altitude than the water level of inner tub (when working properly) before it makes a U-turn downward to send back to the ocean. You can also test the drain hose by putting machine in fill mode and crimping off the hose (fold hose over) to simulate a good drain hose. At this test, you should not "feel" water running through the hose if successfully crimped.
Posted on Jun 21, 2007
The wash cycle puts in too little water and ends up with an oL signal
there is an over fill switch in the washer,,there is a pipe leading up to it when water go.s into the tub the water presher fills the tube up and when the presher is right it turns off the flow,,, if it "times out" becouse it took to long to fill up it shuts off the water flow if this tube is blocked up with gunk??? it wont work very well,,,if its gone fulty it also stops the flow of water ,,,hope this help you out?
Jun 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
WATER IN WASHER WONT SHUT OFF
Hi and welcone to FixYa. I am Kelly. When water wont shut off no matter what you do the problem is inside of the water valve assy. Usually there is a small bit of debris in the diaphram center hole that is holding the water passage open.
Here is what you can try to do to clear if BEFORE replacing the eater Valve.
1. Get a bucket
2. Turn off both water supply hoses momentarily
3. Set the water temp to warm
4. Remove ONE hose from the wall connection and place the hose in a the bucket.
5. Turn on the remaning connected hose/
6. Start machine fill cycle and tap the hose connection at the water valve on the back of the machine with either a screw driver or hammer handle.
Timer OFF
REVERSE HOSE CONNECTIONS ON THE WALL CONNECTION.
7. Place the other hose in the bucket
8. Start Fill cycle.
9. Again tap the hose connection at the water valve
10. Stop timer.
11. Reconnect both hoses and test for water flow with timer off.
12. Start fill cycle
13. Rapidly select hot and cold wash water.
14. STOP fill cycle.
15. Remove each hose individually from the water valve one at a time.
16. Use a knive blade and remove the inlet screen from the water valve. Wash screen under slowly running water rubbing it clean with your fingers. Re install screen. Reconnect water hose.
17. Repeat step 16 for opposite hose and screen.
18. Turn on water supply.
19. Test for proper filling and water stopping by starting and stopping fill cycle.
If it works you got lucky. If you still have the problem you will need to change the water valve. Either one of these water valves will work on your machine:
http://www.repairclinic.com/Appliance-Parts?s=t-PAV2300-%3d%3dc292d509361
Thanks for using FixYa.
Kelly
That is about it
Jun 05, 2010 | Maytag PAV2300 Top Load Washer
Washer seems to cycle fine but the water will over fill
Hello, fill the washing machine with water and when the water is about 1/2 full of water,unplug the washers power cord from the wall outlet.if the water keeps flowing into the washing machine with the power cord pulled the "fill valve"(where the hot and cold hoses are attached to the washer) has mechanically stuck open and will have to be replaced. if the water shuts off when you remove it's power cord from the wall outlet,try plugging the washer in and out a couple more times and if the water stops each time the fill valve indicates as being good.
Thanks
May 21, 2010 | Washing Machines
My washer goes through the cycle but the cold
This sounds like your water fill valve is bad and will need to be replaced.
Feb 01, 2010 | Maytag LAT2300 Top Load Washer
The water valves didn't shut off. the washer over flowed. when i changed the cycle the vaslves shut off and the pump empties the washer. when i start a fill cycle, the washer over flows
Check for a faulty water level switch. It's a diaphragm-like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the tube and when it reaches a certain level, it activates the switch to shut off the water and signals the timer to start the appropriate cycle. Check for any obstructions in or damage to the plastic tube. The switch can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad switch. Sorry for your trouble and I hope this helped. Best wishes.
Sep 10, 2009 | Maytag PAV2300 Top Load Washer
My washer keeps filling with water even after the cycle is going. I put it on small load, it fills to the right level for a small load, the cycle begins and soon the washer is overflowing. Even after final...
hi there......wow !! your using a lot of water...sounds like you have a failed inlet valve resulting in water flowing continually into the machine.....remedy relace the inlet water valve
regards Sir Galahad
Aug 12, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Washer over flows with water and does not go into spin cycle
water level sensor is not working properly
with your solenoids to shut off water
Jun 02, 2009 | Washing Machines
Keeps filling up with water
Hi, the water valve is defective, to make sur unplug the washer 117 electrical corde from the wall and look if it still fill up, if yes then u can be sure that the inlet valve is defective, juste replace the valve and ur home free.. wish u well, Alain
May 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag washer PAV2300 water over flow
from what I am reading on-line, it is the mix valve, aka water valve. Unplug the washer, then see if it still fills. If so, it's most likely stuck open, and needs to be replaced. about $22.00
Feb 21, 2008 | Washing Machines
Estate TAWS800JQ Top Load Washer Logo
288 people viewed this question
Top Estate Washing Machines Experts
Marvin
Marvin
Bobby G
Bobby G
Hjalmer Lamminen
Hjalmer Lamminen
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
