Question about Zenith C27A24T 27" TV
I had a TV service man over to install a new Antennae and hook up my converter box. He was able to view the station name, channel # and signal strength which popped up on the screen on the right hand side. He was also able to use the EPG button which shows program schedules for the next few hours. I tried to do the same this morning and get nothing. I can activate the STB but then nothing. What am I possibly doing wrong?
  • ygreer Jan 18, 2009
    It did not help
  • 55 Answers
If you had any kind of bad weather last night you might try unplugging power from the box for about 10 seconds and plug it back in. That happens on mine every once in awhile.
Posted on Jan 17, 2009
Can my Olivia LCD LT26 be hooked to an indoor had antennae? Once antennae hooked up what are next steps?
Yes. Depending on your location depends on how well it will work. If you are in the US you can go to antennaweb.org and get a fairly accurate idea if an indore antenna will work and what you can expect to receive. After you connect your antenna you need to do a channel search.
Aug 24, 2016 | Olevia LT26HVX 26 in. LCD Television
Esa tv digital to analog
Hi.I assume you can watch some channels, using your indoor digital antenna. As far as I know, you need an intermediate "box", or interface between the cable TV coming in, and the decoder. This has to be installed by the cable company. Between the decoder and the interface, there are two connections. One signal connection and one UTP wire connection for communication between both units.At least, that's how it works in Belgium and most other countries.
Jun 24, 2014 | ESA ET427E 27" TV
Trying to hook up converter box to Westinghouse flat screen the converter is magnavox sdtv. I get autoscan but no channels are found. I do not have an antennae. Do I need one? Help!
If ur tv a LCD tv it is a digital tv.U do not require a Digital converter box to get the new DTV free air signal broadcasting tv channels stations.But u do require a good digital antenna for it to recieve a long an strong signals to recieve a DTV free air broadcasting tv channels stations.
Dec 07, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Cannot get tv to scan digital stations. I have a
test test 18:30
test test test 18:31s rthsr thsty 3456234
Jun 27, 2009 | Televison & Video
I have installed a Digitalstream DTX9950 converter box with my TV attached to a rooftop antenna. I can turn the TV off and on with the DTX9950 remote, but I can't bring in any stations, other than the DT...
Are you using the coaxial cable to connect the converter box to the set, or have you hooked it up with rca type video cables? The latter are highly recommended if you want a better connection and have audio/video inputs on the back of your television. But you don't want both A/V & coaxial.
Also be aware that some older antennae will not pick up digital signals well. Try to use a coaxial cable all the way up to the antenna junction. Find out where most signals are broadcast from in your area and aim the antennae appropriately. (Use a compass.) See helpful link here. Your converter remote should have a signal strength button that you can use to check the various channel strengths. If you're using a coaxial link to the tv and have little signal strength, expect a poor picture. You'll also want to select the Mono option for Audio Output in the converter menu.
Finally, depending on the age of your set, if you're using rca video inputs, use the TV/Video button or the AV button on the TV or universal remote to switch the input from the channel on your TV to the video 1 setting (or whatever picks up the digital converter signal) so you'll get that clear signal. Then you can use the converter remote to change channels, adjust volume, etc.
Jun 14, 2009 | Philips Magnavox 20MT133S 20" TV
I have an RCA converter box hooked up to an RCA TV and a Sanyo VCR. The TV and VCR are set on Channel 3. The converter box is set on Channel 4 and the TV is also switched to CH 4 when viewing digital...
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Feb 27, 2009 | RCA Televison & Video
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Digital tv not picking up digital signal??
According to the manufacturer, the EWL20D6 Television is not digital ready. If that is the case then you will have to use a converter box in order to receive the digital channels.
Dec 20, 2008 | Emerson EWL20D6 Television
No channels downloaded
The antenna must be hooked up to the converter box. The better the antenna, the better your reception will be.
Not everyone in the country will be in range of digital signals. Digital signals have a shorter range than analog signals do right now. It is possible (but unlikely) that you are not currently in range of any digital signals.
So make sure you are set up like this - Antenna--converter box--Television. Then scan for channels. You should still pick up any analog signals while the box is hooked up, you will just view them the same way you do now, by changing the TV station rather than the converter box station.
Dec 06, 2008 | Insignia Digital-to-Analog Converter for...
Trouble receiving local channels on TV using new Magnavox converter box
Your digital converter box probably does not have an analog pass through that allows the old analog channels to go through to the tv's analog tuner.
Jun 27, 2008 | Sanyo DS27910 27" TV
Zenith C27A24T 27" TV Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
