Question about EPoX EP-8KDA3I Motherboard
My 2themax mpotherboard EP-8KDA3I displays FF on the board while it runs but does not show anything on the monitor. I originally had a 512 DDR1 RAM and tried to put on 2 more RAM each 1GB. Was that what was causing the problem?
  • cheungary Jan 17, 2009
    Thanks for your comment. It's probable that my motherboard does not support all 3 at the same time because after trying different module combinations, I received FF shown on the motherboard with only the original 512 MB installed. It represents normal functioning right? However since I am not sure if my monitor is also functioning properly (it's been unstable for quite a while), I cannot tell if it is really back working normally. So showing FF should mean it's working but probably it's the monitor's problem I cannot really tell, is that correct?
  • 98 Answers
Hi.
Most probably yes, if it started happening after you installed new RAM modules. There are to possibilities:
  • one or more of RAM modules is faulty and will need to be replaced or removed
  • the motherboard does not support this layout of the modules which means that you will have to remove 512 MB module
I suggest you remove one of 1 GB memory modules and see if it works. If it does, than put it back and remove the other 1 GB module. If it works again, than motherboard does not support having one 512 MB module and two 1 GB modules at the same time.
Your responses are intended to improve the level of service provided. Please rate your experience.
Posted on Jan 17, 2009
  • Nikola Malesevic
    Nikola Malesevic Jan 17, 2009
    Monitor cannot display anything that is not sent to it by graphics adapter, other than OSD. So if you're seeing "FF" and other codes on the monitor, that's motherboard doing some tests. If it halts at "FF", something's not right and it stopped running or is running in a loop, constantly showing "FF". This can be only motherboard, processor or memory failure, but most possibly motherboard, as it is running internal tests. These tests are common on some Intel motherboards, not sure for Epox though.
    I understand that "FF" is shown on the monitor, but reading your post I am not sure anymore. Can you explain this "FF"?
I wish to know if DDR2 RAM can be used on the motherboard. The vendor has supplied me with one DDR1 RAM 512MB DDR400 CL2.5. I am having 2 pieces DDR1 RAM from my old machine 128MB EACH. I wish to know if...
No you cannot use it .... *********** board will not support DDR2.... but if have the slot for both DDR1 then you can use DDR1.. but i will suggest you to use Ram for same memory .. But you can use 521 & 128 together , no problem.
thanks for rating Good luck
Jan 14, 2011 | Asrock 939SLI32-eSATA2 Motherboard
I am going to upgrade ram to 1 gb. can i use ddr2 1 gb ram to upgrade .motherboard is microstar model ms-6526 ver: 2 . present ram is ddr1 400 MHz, 512 MB
If your computer has two RAM slots on the motherboard, i would recommend trying it. The computer will run on the 512MB stick alone and just not recognise the other stick. And if it works it works.
I have searced for support documentation and came up with none for the original MS-6526
I run my original version MS-6526 on a 512MB PC2300 (DDR1) and a 512MB PC3200 (DDR1) and it runs just fine for games and videos.
Personally I would recommend trying the DDR2 first and if that fails, return the card and get a DDR1 card. They are expensive, but at least they work.
Oct 08, 2010 | Intel Microstar MS-6526 Pentium 4 ATX...
Where can I get drivers for EPoX EP-8KDA3I?
http://www.epox.com/product.asp?id=EP-8KDA3I
Mar 21, 2010 | EPoX EP-8KDA3I Motherboard
Can I replace 256 MB SD RAM with 512 MB DDR1 ram in intel 845 glly mother board?
I have installed RAM of 256MB each (2slots total 512MB ) and system BOOTS UP, but it keeps restarted on every 5 minutes.
Please advice
It is 845 GLLY Original and 1.7ghz.
Dec 27, 2009 | Intel D845GLLY Motherboard
I have an asus k8v-mx motherboard running only 512 mb of ram what type of ram would suit this mother board and could i fit a 1 x 2mb ram instead of 2 x 1mb?
Dear Sir,
*********** board is Asus old p4 Mother board.It supports maximum 1GB RAM of DDR 400(DDR1). According to your post your computer having only one 512 MB working RAM. If you want good purformance you can upgrade your computer by purchasing another 512MB DDR400 RAM and install it on another RAM slot.If your computer have only one working RAM slot,you can purchase 1GB DDR400 RAM & install it on older RAM place. I think it solves your problem.if you have any problem come back with more information. I will try to assist you more accurately.
good luck
Aug 05, 2009 | ASUS K8V-MX Motherboard
Intel D865GBF Ram related questions
here are the specifications of *********** board go through it...
Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
So it will support DDR2 and you can upgrade upto 4GB...
Sep 28, 2008 | Intel D865GBF Motherboard
Memory Upgrade
ask for ddr1 ram of 1 gb.also take your old ram which is at present in your pc to match the locks with the new ram.
it will cost u near to 50$.
thanks.
Sep 18, 2008 | Intel D101GGC Motherboard
can you give more details of your pbrolem
Apr 01, 2008 | EPoX EP-8KDA3I Motherboard
EPoX EP-8KDA3I Motherboard Logo
513 people viewed this question
Top EPoX Computers & Internet Experts
David
David
Alun Cox
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
