Question about Ovens
Fitting Base Element for SMEG DO4SS-5
Http://www.fixya.com/ThreadView.aspx?thid=1382771&prdid=0
Following on from the above problem I purchased a base element (turns out the grill element in the base oven was still working). Now I can't figure out how to replace it or if it even uses a base element. Is the fan element the problem? Any ideas?
  • Ovens Master
  • 3,463 Answers
Some fan assisited ovens do have a base element, some do not.
If there is no heat at all in the oven , then it is safe to say that the fan element has gone, replace that first, if it does not reach correct operating temp, then it probably has a base element as well that needs to be replaced, this would mean removing outer oven panels to access it.
Plz rate my soution.
Thanks.
Posted on Jan 18, 2009
Why is my oven not heating up?
Call an electrician. Sounds like a thermal cut out or a bad element.
Jul 17, 2014 | Smeg Ovens
Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
May 31, 2009 | Jenn-Air JJW8530C Expressions Collection...
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
Smeg oven
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Manual for Smeg SE398X
SMEG have all their manuals online. The SE398X series is at http://www.smegtech.com/site/smeg/myapp/libretti/index.php?model=SC110&lang=EN
Nov 07, 2008 | Smeg SE399X/5 Stainless Steel Electric...
I have a Smeg oven SA708, but all of the symbols on the front of the oven (functions / temperatures) have been wiped off by a previous tennant. Just after a picture or diagram of the front of the oven...
I have a Smeg Double Oven DO4SS-5 that I need to remove the control panel on
it. I've removed the 2 bottom screws but is still reluctant to come off. Help please
Apr 13, 2008 | Smeg S1100MFX5 Electric Single Oven
Lower oven button not working
Yes, this problem is a common one. And it's very easy to fix. Call Bosh support: http://www.fixya.com/Product.aspx?prdid=116504&mode=CNT
Sep 11, 2005 | Bosch HBN 755 Stainless Steel Electric...
Ovens Logo
358 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
