Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
Can anyone give me step by step instructions on how to remove light engine from sony kdf60wf655 tv thanks
  • yons Feb 15, 2009
    where is the projection lamp located on sony rear projection lcd 60 inch tv?
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    are you TV tech?
  • 3 Answers
I have the same Sony TV and just replaced my bulb. I ordered the bulb from sony.com and the package included the allen wrench you will need and simple step by step instructions are also included. There are two hand tightened screws on the lower rear corners of your TB. Remove these screws by hand and remove the botton gray panel of the TV. You will see the light package in the bottom center. Remove the hand tightened screw and swing the metal holder away. The gray cover now will come off by pulling lightly on the bottom. This will expose the lamp. You will need the allen wrench supplied with the bulb to remove the allen screw on the left. Once removed, the plastic cage containing the bulb will slide straight out. Push the new bulb in and tighten the allen screw. Replace the gray cover and swing the hold back in place the hand tighten the screw that holds it in place. Replace the gray bottom panel and hand tighten the two screws on the lower rear corners. That's the whole deal.
Posted on Mar 30, 2009
BLACK SCREEN WITH RED ON TOP RIGHT ON SONY WEGA TELEVISION
Optic Block failure. Lamp wont help you there unfortunately. The KDF60WF655 was a good TV back in its day. Don't waste your money on repair and return the lamp if you can.
Jan 04, 2018 | Televison & Video
If i turn on tv i here clicks and red light starts to flash 6 times in a row and just keeps flashing can i fix this my self ?
Hi, there are numerous flashing codes for these sets so I included a web page dedicated to the Sony flashing light and you can look the forum over and try and pinpoint the number of flashes and the related causes. I also included the cuase for the 6 blinks and this can be fixed if this is the only issue.
Usually, the problem resulting in 6 blinks, pause, 6 blinks, etc. is a defective thermal "fuse", which is actually a bimetalic temperature switch. You may find the "KDF55WF655 6 blinks/KDF42WE655, KDF50WE655, KDF55WF655, KDF55XS955, KDF60WF655, KDF60XS955" information package of value. See the "Frequently Asked Question for Sony Products" forum "Television Troubleshooting Infromation Packages" thread for more information.
Once you get to this site request the troubleshooting package. It has step by step on how to replace the thermal fuse and where to get the parts.
I believe this fuse is right next to the light housing
http://www.agoraquest.com/searchbb.php?term=SONY%20KDF%2042WE655&addterms=all&forum=all&submit=1&sortby=p.post_time http://www.agoraquest.com/viewtopic.php?topic=31806&forum=70 If you find this helpful a vote on the thumbs up would be greatly appreciated for this free advice and thanks for using Fix Ya
Aug 16, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a sony tv, model number KDF60WF655... i turn the tv on and it turns on for about 1 min then turns off, the green light flashes several times then turns itself on again. the process keeps repeating...
Replace lamp in tv as this symptom shows existing lamp is near to end of its working hours life span and need to be replaced.
Lamp replacement procedure is easy and would be written in user manual.
Buy Sony original lamp for good picture in tv.
Thanks.
Jul 20, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
My kdf60wf655 has blue dots all over the screen. Any idea why?
you have a bad light engine Sony was replacing these free of charge but that ended in 2008 sorry.
Oct 18, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Blue tint color on the lower corner of the kdf60wf655
you have a bad light engine get the model and serial number off the back of the set and call Sony to see if it is on there extended warranty list.
Aug 27, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Light Engine for Toshiba 62HM95
Hello thuertam,
I would first suggest that you spend $19.00 for the schematic and service manual for this device. In the service manual you will see the factory approved instructions on how to remove the light engine. This is the best course of action, because even though some here can give you excellent instructions, the warranty on the parts might be voided if you install incorrectly. In addition if you have the service manual it can guide you through steps that might be left out with secondhand guidance.
A good sight to get schematics frrom is http://www.servicemanuals.net and http://www.manualsparadise.com
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 12, 2009 | Toshiba 62HM95 62" DLP HDTV
Sony kdf60wf655 tv have sound but no picture after turning on for
Its symptom of weak lamp, please replace lamp. Lamp replacement procedure is written in user manual and always buy original Sony lamp for replacement.
Feb 12, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony kdf60wf655
sound like a lamp you can easily check this there is a door on the left side of the tv open it reach in thump on top finger in the loop squeeze and pull.
Jan 20, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony KP-46WT510 wont turn on
8 blinks means that the High Voltage Block is shorted - part# 8-598-955-32 (about $80)
Sep 10, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
KDF60WF655 Popping, Cracking, Squeaking sounds?
the outer screen case screws need to be tightened.
Feb 24, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
185 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
