Question about Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
How can i connect my sony psp to wifi network
I am in india i wanted to know how can i connect my sony psp to wifi network and which broad band service can i use on my psp pleassss
  • Anonymous Jan 18, 2009
    how can i connect my psp to wifi
  • 63 Answers
Go connect the psp to a wifi network and surf the web do the following
go to the browser, type a web address like yahoo.com and network connection will show up select [new connection] then select scan and it will scan for nearby networks and if you find one you can use it, if the security shows up as none then just select ok untill you reach the end if there is a wep key or wap key then you need to obtain the key from the owner of the network.
hope i helped
Posted on Aug 02, 2009
  • 20 Answers
U must hav wireless modem
Posted on Jul 11, 2009
  • 34 Answers
If u want 2 use the internet, u have 2 search 4 da servers. Make sure u hve a gd connection. To connect and access it u need the wep key or password unless it says none.i hope dis helped =)
Posted on Jul 10, 2009
  • 38 Answers
Ok just scan via your psp and connect on which ever network pops up with the strongest signal. You will need to know the security code if it is a private network.
Posted on Mar 14, 2009
    President:
  • 1,566 Answers
You have to be on the wifi range or wifi access point.
Posted on Jul 21, 2009
IMEI Number :012448002022058 I want to unlock my
You can get the SIM network Unlock PIN for Sony Ericsson E15i Xperia from the site SimpleUnlocking.com and easy step by step unlocking instructions from MobileUnlockGuide.com .Using that you can unlock your phone easily.This is the safe,fast and permanent unlocking method.
Sep 04, 2013 | Sony Ericsson Sony Ericson XPERIA X8 E15i...
I have a new psp and and to connect to the internet i need a ssid code but i didnt get one when i bought it
A service set identifier (SSID) is a name that identifies the network. To connect to a wifi network with your PSP follow these steps:
1. Flip the WLAN switch to 'ON'
2. Select Network Setup from the main menu after that select the Network Settings
3. Select Infrastructure mode > Create new connection
4. Select Scan and choose your WiFi`s SSID (name)
Mar 17, 2011 | Sony PlayStation Portable (PSP) Console
Every time i try to connect to my wifi network on my psp it wont connect
1. Turn the WLAN switch on the PSP to "on" (it's a silver slider switch on the lower left *edge* of the device)
2. Access to a wireless Internet network that doesn't have a password.
Then you should be able to 'scan' for networks, pick out the one you want to use, and go online.
[Note: While the PSP supports various wifi password schemes, notably WEP, I haven't had any luck with password-protected sites myself and haven't heard from others that it worked either]
Sep 09, 2010 | Sony PlayStation Portable (PSP) Console
Can not get psp to connect to wireless router
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Steps Turn on your PSP.
Enable wifi by flipping the WLAN switch to the on position.
Select network setup from main menu, select network settings (press "X").
Select infrastructure mode.
Create a new connection.
Select scan to look for your WiFi network.
otherwise if you know all of your network settings, you can do it maually
Select your wifi networks SSID.
Enter your security settings(if applicable)(WEP, WEP TKIP, Shared Key).
Select "easy" in configure network settings to obtain ip address.
Confirm the settings.
Test the connection.
Go back to the main menu, select the broswer & enter a web address (www.google.com etc.). Your PSP's internet is ready to be surfed out wirelessly.
the psp, unless you have a hack installed, will not be able to browse sites such as youtube, or facebook, or twitter because they require flash/java/enhanced memory[this is not the memory stick]it can however use facebook mobile or myspace mobile by typing in m.facebook/m.myspace.com -- Tips:
  • You may have to do this every time you are in a new area or surrounding that has wifi hotspots
  • Go to www.youtube.com for tips, tricks and hacks.
  • Go to your favorite cheat code website for cheat codes.
Things You'll Need
  • Sony PSP
  • Internet
  • Wireless router
Jun 11, 2010 | Sony PlayStation Portable (PSP) Console
I need to know how to upgrade my psp
If you are near a WiFi area you can setup the PSP WiFi settings under network connections.
After that, go to the top of the same level XMB menu to updates and click. It will connect through the network and check Sony's servers for an update.
Or you can download the update directly from the Sony website and connect the PSP to the computer and put it on the memory card that way.
If you mean "How can I hack my PSP to play ISO or CSO downloads or bame backups?" That is a different story...
Feb 01, 2010 | Sony PlayStation Portable (PSP) Console
Can someone please tell me how to connect to the internet so I can send text messages on my psp?
For this you need a broad band connection.Now switch on the psp go to settings go down fully and enter network settings and enter infrastructure mode.There select [New Connection] and you will enter WLAN settings there select scan.While doing this remember to do this switch on the broad band so that the psp will be able track it while scanning.After it finds your WLAN it will show you the SSID,Security and signal strength.Then press 'x' and type the SSID and press the right arrow to continue.Now you mus type the security code if you have one otherwise press none.Then select the address settings to easy or custom and keep going front until you find the sentence 'Press the x button to save settings'.Now you can browse the internet with the connection.But remember to switch on the broad band when you want to browse the internet.
Jan 27, 2010 | Sony PlayStation Portable (PSP) Console
"how do i connet to the internet on my psp"
You need to have a WiFi network or be on a WiFi hotspot. If you are connecting to a secured network, make sure you get the passkey from the WiFi admin. If you want to setup a WiFi network at your place. You need to buy a Wireless router. Usually costs around $50-$60. This will share your internet connection wirelessly.
May 01, 2009 | Sony PSP (Piano Black)
IP adress dosent work.
You need to match the security settings on the Wifi router. I do not know what security is set up on your Wifi, so I cannot accurately solve this problem. I have my router set to WEP with a passcode. On the PSP, I tell the network setup that the wifi is WEP and put in a passcode to match the Wifi routers security. If you have the passcode wrong, the IP address part will fail. Just find out the security type and passcode, then set up the PSP's network connection to match.
Dec 30, 2008 | Sony PlayStation Portable (PSP) Console
PSP
Well it look like you might not have a WiFi network connection set up yet on your PSP. So This is what you want to do if you have DSL at home and a WiFi router. When you search for a new network connection and you find the one from your home, you will still need the WEP key wich is the most inportant in order to allow you PSP to use that WiFi connection. That must be why you are getting this error messege
Aug 30, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Slim (PSP-2000) Console Logo
218 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
