Question about Sony Handycam DCR-VX1000 Mini DV Digital Camcorder
VX1000 Cassette Compartment Jammed
I just bought a used VX1000 and I've never used one before. The cassette compartment is jammed, it does not open all the way when I press the eject button. It looks like from the manual that the compartment opens up at about a 45 degree angle, mine goes up vertically about a half inch and stops. I think this is a common problem with these cameras, can someone tell me what to do? Thanks, Erik
  • kiet Sep 25, 2008
    I have a same problem.Is it any way to reset and to recuperate a tape?
    Philippe
SOURCE: Cannon ZR 60 camcoder Cassette copartment does not open
Try these steps: 1. Open the tape cover fully until it clicks open. 2. Turn the camcorder on to "VCR Mode." 3. With the cover still open and the camera in "VCR mode," take out the battery. 4. Put the battery back in--out should pop your tape. Although this worked for me, I then inserted and used a head cleaner tape which then became stuck as well. Tried the same trick to eject it, and it did come out after several tries. I will take it for a repair estimate before inserting any other tape.
Posted on Mar 25, 2007
SOURCE: Cassette Jam
I had this problem, and here is how it was resolved.
My cassette would not pop out when I opened the door with the camera turned on. When I turned off the camera and opened the door, it slid out much further, but still failed to pop open so that I could remove the tape. Then it slid back in.
Remove the battery, and have the camera off, but make sure the power cord is connected. Open the door until the tape slides out further than at other times. (Note: It intermittently slides out further when the camera is off. Sometimes it will not slide out any further than when it is on.) When the tape is slid out as far as it will go, quickly remove the power cord. The tape will stay in the slid-out position. Now, at the bottom side of the tape door there is a curved channel for a small pin to slide in. This channel has a 90% curve at the bottom of the channel to catch the pin, which holds the door closed. Push that pin back a little (toward the lense) to get it to go around that 90% curve, and the door will pop open so you can remove your tape. The ribbon of your tape will be jammed in the camera a little, so you will have to be careful and move the ribbon around a little until you can get it out freely.
This worked for me twice. I did not try putting a tape in again.
I hope this helps.
Posted on Oct 23, 2007
SOURCE: Canon MV800i tape would not eject.
Put pedalfoot in camera, shake vigorously.
Posted on May 13, 2008
SOURCE: camcorder cassette holder stuck/won't eject
Try taking the battery out...
Posted on Jun 30, 2008
bluelikealex
  • 52 Answers
SOURCE: TAPE COMPARTMENT KEEPS POPPING OPEN
I Had The Same Issue And Fixed It :o) I Have A Sony Handycam CCD F-730A 8mm. I put the tape in and close it but it would not load the tape down. It just pop back out. If I took the tape out, it works perfectly and would loaded the tape doc down and close.
1st: I unscrewed and removed the door to the tape. Where the tape can be seen. 2 screws hold it down. Without the tape inside. I Saw a Clear Small Plastic in the inside of the camera where the tape sits on each side. On Both Sides, Left and Right are clear plastic like sensors. They look Like Glass and are small.
2nd: I Cleaned them both with a Q-tip and rubbing alcohol. It Worked. The tape loaded and worked nicely.
It was strange. If i touched one of the small glass like sensors. the mechanism the loede the tape would not work. When The Glass sensor was blocked by the tape or just by my finger in front of it, it would not load. Very strange.
Bluelikealex :o)
Posted on Dec 02, 2009
How do I remove a jammed cassette from a Sony camcorder?
hi,
if you left it without work for a long term, the loading motor may be struck, if so a contact cleaner spray is helpful to start the motor, spry it very carefully on the grove of the loading motor, don't allow the liquid to go on the head, give power, (do not power switch ON), just push the eject button,try several times, then will be OK, if the motor failed, must replace it.
Dec 08, 2015 | Sony Video Cameras
How do I fix the tape holder system on my camcorder? The door won't lock, and the cassette won't get inside the compartment.
hi,
is it close without a cassette ? if so the reel sensor in the cassette compartment may be faulty. if the head drum not rotates the cassette drive will not work correctly, if so please loosen the head drum with a plastic rod or some tools like that. do not put your finger in hence sometimes will jam your finger. remember don"t touch the scanning chip of the head.
Oct 26, 2015 | Panasonic Palmcorder PV-GS12 Mini DV...
Cassette tape has jammed inside while playing, and the cassette door will not open...suggestions of how to open the door - without dismantling / destroying the unit - much appreciated. Thanks.
This is a messy situation - I've had a few. The best thing to do really is take it to a repairers where they will be able to retrieve your cassette without damage to it or the deck.
Sep 26, 2011 | JVC UX-D66 Shelf System
Cassette compartment cover blocked
have you try to open it and see for any loose spring parts.?
thanks
Apr 23, 2008 | Cameras
Tape stuck in uvw1800 beta cam sp
Use menu system to access "manual eject". Hold left arrow key and press menu to access menu. Follow from there.
Feb 22, 2008 | Sony Betacam SP Small Videocassette 30...
Jammed cassette compartment
This unit is very common for the mode switch to be bad, but to replace this, the entire mechanism has to be taken apart and reassembled and realigned. Probably not worth the money or the time, as we used to get 250 to 300 to repair this problem. Good Luck
Jun 15, 2007 | Canon ES410V Camcorder
Cassette Jam
The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds.
Sep 04, 2005 | Canon Optura 400 Mini DV Digital Camcorder
Cassette Jam
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
Cassette Jam
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Cassette am
To unload the videocassette from the cassette compartment, the camcorder needs to be connected to a power source (either an electrical outlet or a charged battery). Please refer to the following instructions. Connect the camcorder to the power source or insert the fully charged battery pack, and then slide the EJECT switch to open the cassette compartment cover. The cassette compartment cover will open, and then the compartment will open automatically.
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Sony Handycam DCR-VX1000 Mini DV Digital Camcorder Logo
648 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
