Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
Tv shuts off after being on only about 30 to 35 seconds,green power/standby led blinks 30 seconds,then tv comes back on,power/standby led stays green. Then this repeats until you give up trying to watch anything. Any suggestions?
  • 4 more comments
  • gene gilbert Jun 21, 2007
    Green power/standby led blinks about 30 times during the 30 seconds it is off. (once per second.) When it comes back on it stays green.
    (no blinking)
  • tireman Nov 16, 2007
    this is happening to me also, any suggestions?
  • Anonymous Dec 20, 2007
    what i have to do
  • mimanud3 Apr 30, 2008
    tv light turns green, blinks for 10/15 seconds, then turns red, stays red for 10.15 seconds, and then turn green,. This cycle contunues, no picture at all.
  • davisesq12 May 05, 2009
    where is the air flow screen on the kdf60wf655?
  • davisesq12 May 11, 2010
    where is the air flow screen. My green light blinks 37 times and then turns on for 5 - 10 seconds then shuts. I already replaced the bulb once and would hate to do it again.
  • 3 Answers
I had the same problem with my SONY TV shutting down and the green power light blinking 35-38 times before the set came back on. My RED Lamp Light never came on, but the problem is the LAMP. I spoke to SONY Support on the web and on the phone. All they wanted to do was set up a service call for me. I ordered a replacement bulb from SONY and it fixed the problem. This is a very easy replacement and they send the allen wrench you need to remove the old bulb and install the new bulb. Simple replacement Instructions are included in the box. Thanks to www.FIXYA.com I saved a very expensive service call.
Posted on Mar 30, 2009
Sounds like you need to replace the bulb.
Posted on Dec 30, 2008
I too had the on/off on the KDF-60WF655
I removed the bulb, cleaned it and still the same on/off issue. Read more posts and saw the one re the dust on the air flow screen - and YES I had the same. Cleaned it and YES !!! .....up and running just fine .
Will likely order a bulb anyway as I am into year 5 with the original
Thanks for the help
Posted on Mar 15, 2009
My sony 32" television shuts of only after a few seconds of being turned on. After repeatedly turningn the unit on it will stay on ...........WHY. And how do I fix it?
Posted on Sep 30, 2008
    Problem Solver:
  • 7 Answers
I also had this problem, I removed the lamp, thoroughly cleaned it and then put it back in. Now works fine.
Posted on Mar 30, 2008
I had the same symptoms. I replaced the lamp and fixed the problem. But then I looked at the old lamp. There was a dust buildup on the screens which cover the cooling holes. I blew off the dust and put the old lamp back in- it worked fine!
Posted on Dec 25, 2007
We had the same problem and decided that it might be on some sort of timer. We removed the lamp, waited a minute, and put the same lamp back in and the television is working fine now. Maybe the lamp will have to be changed in the near future, but for now all is well.
Posted on Dec 05, 2007
    Problem Solver:
  • 5 Answers
This happened to me too... What solved it for me was to replace the lamp.
Posted on Aug 05, 2007
2 Suggested Answers
  • 373 Answers
SOURCE: Tv shuts off
can you go into the menu and rest it
Posted on Feb 10, 2009
TV goes to blank screen standby after one second of normal functioning green power light on. When in standby state, the TV is blank like it's off and the red standby light blinks FOUR times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 16, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
My tv will power up with the with no sound for about 60 seconds then shuts off with grin flashing light for about 60 seconds the red light comes on amid stays on. What is the problem? The fan comes on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Mar 30, 2014 | Mitsubishi Cinema WD-73640 73-inch 1080p...
TV will not stay on
Mar 10, 2014 | Sharp LC37SB24U 37 in. LCD TV
Sony KDL46V2000 TV. Screen comes on and goes off in continuous cycle
you have a leaking cap on your power supply /open up and check on just replace those caps that looks swollen
Nov 16, 2017 | Sony KDL-46V2000 46 in. LCD Television
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
AKAI LCT26Z4AD wont power up.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 10, 2017 | Televison & Video
Shuts off and has problems comming on
TV shuts off if it gets cold,this is the symptom of "cold solder" in power supply section and also in DM board section.needs to reworks or resolder the solder joint.
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
a3d2d2a.jpg You must do some checks first:LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067001 LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds . LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001.
Just click below for more information.; http://www.fixya.com/support/t838883-mitsubishi_wd_52825_tv_wont
Hope it may help you ;
Regards,
VOTIT
Oct 04, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Will not stay on
RED light is protect circuit = do not disable !
Look for C702 near flyback transformer - might be hidden in
glue = check it = if shorted, replace 102K / 2KV with 3KV =
Sony part # 1-161-754-00 and replace E994 pico fuse.....T.
Nov 08, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
1,210 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
