Question about Karcher G3025OH Pressure Washer
Karcher 3000 psi won't start.
I have a Karcher 3000 PSI very litle use ,the unit is hard to start and if it does will go off inmediately, I noticed the gasoline is getting into the oil tank, it seems like a gasket issue .please help.
Thanks
  • 2,176 Answers
It sounds more like a carb problem flooding and dumping some gas into the oil. This unit probably has a low oil sensor and the gas could be affecting this. I would have somebody look at the carb and find out why doing this, change the oil and try again. I have one that leaks gas because of float problems, that has done it since new, waiting for spring to remedy. Good luck, Also you can go to Karcher.com for a parts explosion and manual if needed.
Posted on Jan 23, 2009
    New Friend:
  • 22 Answers
Drain the oil, remove and clean spark plug, remove carb and air filter. Thoroughly clean carb with carb cleaner and compressed air. Replace all of the gaskets that was removed during procedure, then re-assemble torquing bolts to specs, replace spark plug and add fresh oil. Give her a couple of tugs and fire her up. If that does not work and your engine does has the same symptoms then your diagnosis description was inaccurate and you need to add more information. Every little thing matters.
Posted on Nov 16, 2013
What should the persure be for a hds 750 karcher
These units are variable, while the pump has a operating pressure of 1450 psi (100Bar) they can be taken down to 290 psi (20Bar) for steam cleaning.
Hope this helps:)
Brad
Jul 17, 2014 | Karcher Garden
Mitm power washer won!t start
you might have left gas in the carb an its solidified some in tank an lines.
remove spark plug
see how the engine turns now w/o spark plug ,should crank very easy.
an squirt some gas 1oz in cylinder an close an leave it a day to soak in.
then.
see if there is a screw with spring wrapped around it ,under a metal bulb on side of engine remove the screw an clean it . look for a tiny hole in the side of the screw its hard to see . its clogged.
check you oil for water an correct level not too much or its hard to crank.
Jul 13, 2014 | Karcher 2500 PSI Pressure Washer
Rope hard to pull
if there is an auto shut off adjust the cable its not pulling all the way open
Mar 08, 2014 | Karcher 2500 PSI Pressure Washer
White smoke. when it won't start, raw gas comes out of the exhaust GS190 honda Karcher 3000 PSI
Sounds like it's flooded. Close the throttle and open the choke if equipped. Pull it through a few times and then open the throttle a bit.
May 24, 2010 | Northstar Pressure Washer 3000 PSI
Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Aug 17, 2009 | Karcher 2500 PSI Pressure Washer
Honda GC190 engine shuts down on my Karcher 3000 PSI PW
Well would you believe that I have the very same problem. I suspected that the pump was seizing up, so we tried the pump on another unit and it worked fine. On inspection of the motor we found the cam (which also operates the decompression mechanism) was worn out. It's made of hard plastic. It is only about 7 dollars too, so cheap enough to fix. I have mine ordered now and feel pretty confident that that should fix it.
Aug 13, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2600 psi pressure washer wont stay running
Remove and clean the carburator. Sound line a stuck needle on the float.
Apr 22, 2009 | Karcher 2500 PSI Pressure Washer
How can I start the soap syphon feature on the Karcher Model 210 - 1200 PSI unit ? Does the line need to be primed ?
If there is a check valve in the little line that you put into your soap tank, it doesn't need primed. I have very large 5000 psi units and have enough suction without one. If you can't get it going, you can always remove the hose end near the pressure washer end and fill it by immersing the tubing in the soap, but that shouldn't be necessary. Sometimes the little fitting with the check valve in the bottom get plugged up as well, so that might be your problem. Hope this helps you, Rick
Apr 03, 2008 | Karcher 2500 PSI Pressure Washer
Karcher G3025OH Pressure Washer Logo
683 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
