Question about Kenmore 22422 Top Load Washer
I heard a splash sound from my washer (it's less than 4 months old) and when I went to look there was soapy water behind is and things on top of the washer was wet. We has a bucket on the top and it had 1/2 inch of water in it. I turned it off and cleaned up the floor, but am not sure where the water is coming from and how to fix it...oh and it's a front loader.
  • littlepapaya Jan 22, 2009
    Thanks! What's strange is that we tried it again and nothing happened. We used it 4 more times on that same cycle that had the problem and again, no water came out...any ideas on why it happened just once? (I did not look where you said before trying it 4 times)
  • 101 Answers
I don't quite understand exactly what you mean in this but my guess is that something is stuck in your pump if water is going everywhere. With front load washers you have to make sure that you remove everything from your pockets and in between each load make sure you run your hand between the front door boot. (That's the black rubber thing that is between the basket and the door.) Socks and under ware like to get stuck in there and that is what leads to your pump. These front load washers have a common problem with things getting sucked down into the pump if not properly taken care of. If the pump is clogged with something it won't drain and water will go everywhere sometimes. You will need to remove the front panel that is below the door. You will find you screws between the door and the panel that you need to remove. Once off the pump is right there. Make sure you clamp it off with hose clamps or you will have water everywhere. Then remove it and check for anything stuck in there. If there is a sock or something don't get to surprised, it happens all the time. Just remove the obstruction and put it back together. Make sure though that you check that boot every time you use it or soon it will damage your pump and you will need to get a new one. Let me know if you have any other questions and good luck.
Posted on Jan 21, 2009
  • Dan Harris
    Dan Harris Jan 22, 2009
    What might have happened is that whatever was in your pump at the time made its way out and passed through. That will happen sometimes. You just want to be sure that you really check that front door boot after every wash. It is really a common nuisance with those front load washers that has been happening since they first came out on the market. I remember when I worked for Sears shortly after they came out with the new Kenmore washers I went to a woman's house and found 4 pairs of under ware stuck in the pump. The older Kenmore's are worse. I used to pull tons of money in change out of them daily at customer's homes. Just make sure to always check that boot for clothing and always make sure pockets are empty before putting them in. Hopefully you don't have any other problems with it. If you do have any other questions though let me know.
There is not enough water in my machine?
On mine, it does not swim clothes in water, but certain parts of the cycle, you do see water in the machine.
1) are the clothes damp at the end of the wash?
2) more importantly, are the clothes clean?
3) do you see / hear water enter on cycle start?
My suggestions:
1) loosen / remove the fill hose and verify you have water pressure in the fill hose.
2) read on this forum for test cycle proceedure. Run tests.
3) if it truly had no water, I am sure there would be an error code. Look that code up.
4) Download the manual, and follow their test / fix steps.
Note: the test proceedure, error codes and manual are mentioned by helpers in posts where I have had questions. See if you can look up my previous posts.
Sep 13, 2014 | Whirlpool Duet GHW9150P Front Load Washer
5 month old Whirlpool Cabrio washer has moldy smell. Tub seems to empty well. Any ideas?
Smelly washers are common. Cabrio washers are HE and therefore use less water. By using less water, it doesn't rinse ITSELF as good as an older non-efficient machine. Things you can do to solve the problem. Buy a cleaner from Whirlpool called Affresh. It's 3 tablets that you throw in the washer without clothes and run it on the longest heavy duty cycle possible. Use the hot water setting and the longest duration. For existing smells use all 3 tablets. Then use 1 tablet every month to prevent reoccurring odors. You can also try the same type of cycle on hot water with a half of a gallon of bleach in the tub, or try it with a half of a gallon of vinegar. One of the 3 should do the trick.
May 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have had my washer for almost 4 years. one month after the warranty was up it broke. I called the repair man and they went ahead and honored it but then 2 years later it did the same thing. The code...
sounds like its an "L" code ? which is a lid switch error code....the lid switch is either broken or stuck open possibly soapy water got in the switch located under the lid there is no remedy except to replace it or try and test it
Sep 28, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Zunussi zwf1437w Keeps stopping during programmes
This sounds like a drainage problem. First thing is to check the filter behind the flap on front of machine.
Please post back your findings for further assistance.
Thankyou for using Fixya.
Jan 23, 2009 | Zanussi ZWF1430W Front Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
Makes a grnding sound when washing(not always) & does not spin all the water
This problem happen to me a few months back--washer was 6 months old. A technician came out and told me that I must have loaded the washer after the water was in the tub. He stated that I must load my washer prior to running the water in because the water fill amount is based on weight; therefore it was now weighing too much. Go figure...have always loaded the washer with water first and clothes last. I always put clothes in first then the water--I must say, the problem has not reappear.
Hope this helps.
Nov 03, 2008 | GE Profile WPRE6100G Top Load Washer
Dishwasher Leaking
Hello jferguson29.
Welcome to fixya.
You said, water splashing over tub into door panel. It leaks with or without being loaded with dishes.
You checked the lower wash arm but found no visible cracks or breaks. The leaking water is clear not soapy.
What is the brand and model number?
And how old is it???
There are a couple reasons water may be leaking out the door of a dishwasher.
1. The water is most likely coming out the bottom of the door where there is no rubber seal.
2. The rubber seal is around the door jam on top and both sides and not on the bottom. This means if the dishwasher has to much detergent in it the soap suds push only the water higher than the front edge of the wash basin and out the bottom of the door where there is no seal!
3. Fill only the soap cup that can close for the secondary wash. The open cup is a pre-wash and mostly not needed unless the food is baked on.This just wastes money to fill both of them every time.
4. And if you are using liquid detergent you only need half the amount from the powdered soap!
try less soap. Remember to much soap too can cause the water overflow.
5. And the last would be that the drain is clogged and caused a back up large or small and then the overflow!
is there water in the bottom when the wash is done?
Soap is usually the culprit, not that there can't be a leak in an old drain or water supply hose!
Go with the soap idea first!
Let me know how you are!
How old is the washer ?
Please remember to leave a rating before you go!
Thank You ,Huuum
Here is an interesting report I just read!!!!!!!!!!
Repair or replace?
When to pull the plug on your old washer
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your washer,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your washer is under warranty or less than four years old ,
paying for a repair makes sense.
Note that washers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your washer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washer
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of washers you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not forget to give a rating before you sign off!
Oct 03, 2008 | Dishwashers
Maytag washer
The lock at the center of spinner fallen /return it and tight it.
Dec 18, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore 22422 Top Load Washer Logo
44 people viewed this question
Sal De
 Brian Main
Brian Main
