Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Our oven smells of gas and takes forever to heat
We do have a flame, but it smells very strong of gas and heats extremely slow.
  • jason182 Jan 17, 2009
    I have the same problem. I will be troubleshooting today and will post if i figure anything out.
  • Anonymous Jan 19, 2009
    me too
It may be that the heating element is dirty and consequently, is not igniting the gas. Mine was doing the same thing and was also making a big BOOM sound which was the sound of the gas in the oven igniting after too much gas was released.
I called a friend who gave me these instructions and it worked...I was able to fix it in about 30 mins.
1. Remove the floor of the oven...there are two screws along the back wall of the oven holding the oven pan (the floor of the oven) in place. remove these two screws using a Phillips screw driver. The oven floor pan will then pull out.
2. Remove the thick steel plate next which is located in the center...just under where the oven floor pan sits. Remove the the right and left screws located along the outside edge of the oven floor rim and the center nut. I used a cresent wrench for the two screws and the center nut...didn't feel like finding the right socket size and don't have the special screw driver fitting.
3. You will see an aluminum pipe that runs down the center from the front to the back. Near the back and mounted to right side of the aluminum pipe there is the heating element. It is protected by a metal casing. There are two screws securing it to the housing. With your wrench, remove the two screws and gently pull it back. The heating element is made of a ceramic material and is delicate. Using a tooth brush, gently brush the heating element to clean it.
Posted on Jan 20, 2009
The oven emits a strong odor of gas the entire time it is in operation?
The oven has 2 igniters. One for the broiler and one for the oven. We had a similar problem but the oven had no flame. The broiler worked fine. If there is no flame than you are going to smell gas since it is not being combusted. The oven igniter is in the bottom of the interior oven. The bottom plate is removable. Since there are openings in the panel sometimes debris falls through and some debris can accumulate.In our case there was some aluminum foil blocking the igniter and a simple cleaning fixed the problem.
Aug 23, 2014 | Electrolux Ovens
Strong gas odor only when oven is in operation?
If you're talking about the acrid smell immediately after starting the oven, that's aldehyde gas, a byproduct of cold gas combustion where the flame contacts the cold metal oven surfaces. That smell should disappear within the first minute or two, and it's entirely normal for a gas oven. If you're talking instead about the smell of fuel gas, then your burner may need to be adjusted; it may be running much too "rich".
Whirlpool super capacity 465
Call a gas engineer at once. Gas is extremely dangerous.
Jul 19, 2013 | Ovens
Magic Chef oven won't lite. The ignitor glows red hot but no flame. After about 10 minutes of being on I start to smell gas. Not a strong smell but its in the air. I'm thinking gas valve. I did a...
The problem with your oven is that ignitor is weak and not drawing enough amprage to open the gas valve, the gas you smell was since the ignitor does come on it allowed the gas valve to open a wee bit but since ignitor is weak it wont allow gas valve to open fully. I know you going to doubt that what i'm telling you is correct, i base my diagnosis on my 30 years experience as a appliance repair technician.Replace ignitor and enjoy your baked meal
Gene
Jul 30, 2011 | Magic Chef 9122 Gas Single Oven
Have a frigidaire gas stove has worked great for 6 years. Now we are getting a strong smell of gas when it is heating up or cooking. Have checked to make sure flame is on and it is. It also seams like it...
Try changing out the regulator for the stove. Does the flame seem weaker than it used to? If so, your regulator is probably going out and the gas you smell is the residual leaking out when the stove is on.
Jul 01, 2011 | Frigidaire Ovens
Oven won't stay heated, clicking noise like its trying to ignite, and gas smell.
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Problem -
Gas flame comes on first few times then quits and igniter keeps cycling on and off but never lets the gas go.
Answer ( most common ) -
Replace the coils on the Gas Valve.
Problem -
No flame, no igniter glowing at all,
Inspect igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter when dryer should be calling for heat.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 10, 2010 | Ovens
We have the smell of gas when the oven is pre-heating
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
May 02, 2010 | Ovens
Frigidaire gas oven not heating
replace the bake ignitor its getting weak
Jul 01, 2009 | Frigidaire FGB24T3A Gas Single Oven
Maytag gas oven slow to ignite,makes poof sound
sounds like the safety valve gas regulator (its where the main gas line attaches in the bottom back)
Mar 25, 2009 | Maytag CWG3100A Gas Single Oven
Strong Foul smell coming from oven only when I turn it on
do you have mice.they will tunnel in the insulation.you know what they do next,well then you heat that up and theres your smell
Dec 31, 2008 | Magic Chef 9122 Gas Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
199 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
