Question about Mitsubishi CS-40503 TV
Narrow blue horizontal line across screen on intial power up
The picture comes in after about 30-45 seconds, still crystal clear after power up. If the TV is warm this does not happen with power up, only after sitting 6- 8 hours. Mitsubishi CS-40503
  • 55 Answers
You have trouble with the vertical deflection circuitry. Probably something in the driver circuit or power supply to the driver. Maybe even a cold solder joint since it comes up after a little warmup.
Posted on Jan 17, 2009
The picture is smashed down to a narrow horizontal line
Check solder on the vertical output or change it. Dont know # but look for IC screew on heat sink with about 7 to 14 pins.
Apr 28, 2010 | Jensen TS2050J 20" TV
Less than 24 months old. Power up, has 3
sorry to say but your LCD panel is failing, and will have to be replaced sonys panels are expensive
Dec 05, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Horizontal blue lines with a slight blue wash in the screen
Its because of Over Voltage of Screen (G2) to Blue CRT.
Take off front lower cover (speaker grill) and unscrew board. There you will need to find Focus Block mounted having 6 control knobs. 3 knobs are for Focus control and 3 are for Screen volts control. Find Blue Screen control knob and turn is Counter Click Wise slightly until bluish shade disappear on screen including few blue horizontal lines.
If you select AV input to adjust that will be fine as you do not need to wait for dark-scene.
Apr 09, 2009 | Sony KP-65WS500 65" Rear Projection...
No picture, only a horizontal line across the screen
Hi and welcome to FixYa,
Your described problem indicates failure at the vertical deflection circuitry. Almost always, this would be a defective vertical IC. In some instances, this could also be caused by the absence of Vcc (supply voltage) to the said IC. This is a relatively easy/quick repair. What would be more challenging is identifying the IC, removing it, and replacing. Replacement would be readily available from most electronics part stores including Radio Shack.
Good luck and thank you for using FixYa.
Feb 24, 2009 | Zenith Televison & Video
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Horizontal Lines and Blue Tint on my Sony KDP 57XBR2
ok,your porblem is very simple,reheat or resolder the main board your tv.
Oct 22, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Televison & Video Logo
100 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
